 drivers/iio/gyro/bmg160_core.c | 86 +++++++++++++++++++++---------------------
 1 file changed, 44 insertions(+), 42 deletions(-)
diff --git a/drivers/iio/gyro/bmg160_core.c b/drivers/iio/gyro/bmg160_core.c
index 2493bb1..b2b1071 100644
--- a/drivers/iio/gyro/bmg160_core.c
+++ b/drivers/iio/gyro/bmg160_core.c
@@ -95,7 +95,6 @@
 #define BMG160_AUTO_SUSPEND_DELAY_MS	2000
 struct bmg160_data {
-	struct device *dev;
 	struct regmap *regmap;
 	struct iio_trigger *dready_trig;
 	struct iio_trigger *motion_trig;
@@ -137,11 +136,12 @@ static const struct {
 static int bmg160_set_mode(struct bmg160_data *data, u8 mode)
+	struct device *dev = regmap_get_device(data->regmap);
 	int ret;
 	ret = regmap_write(data->regmap, BMG160_REG_PMU_LPW, mode);
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_pmu_lpw\n");
+		dev_err(dev, "Error writing reg_pmu_lpw\n");
 		return ret;
@@ -162,6 +162,7 @@ static int bmg160_convert_freq_to_bit(int val)
 static int bmg160_set_bw(struct bmg160_data *data, int val)
 	int ret;
 	int bw_bits;
@@ -171,7 +172,7 @@ static int bmg160_set_bw(struct bmg160_data *data, int val)
 	ret = regmap_write(data->regmap, BMG160_REG_PMU_BW, bw_bits);
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_pmu_bw\n");
+		dev_err(dev, "Error writing reg_pmu_bw\n");
 		return ret;
@@ -182,18 +183,19 @@ static int bmg160_set_bw(struct bmg160_data *data, int val)
 static int bmg160_chip_init(struct bmg160_data *data)
 	int ret;
 	unsigned int val;
 	ret = regmap_read(data->regmap, BMG160_REG_CHIP_ID, &val);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading reg_chip_id\n");
+		dev_err(dev, "Error reading reg_chip_id\n");
 		return ret;
-	dev_dbg(data->dev, "Chip Id %x\n", val);
+	dev_dbg(dev, "Chip Id %x\n", val);
 	if (val != BMG160_CHIP_ID_VAL) {
-		dev_err(data->dev, "invalid chip %x\n", val);
+		dev_err(dev, "invalid chip %x\n", val);
 		return -ENODEV;
@@ -212,14 +214,14 @@ static int bmg160_chip_init(struct bmg160_data *data)
 	/* Set Default Range */
 	ret = regmap_write(data->regmap, BMG160_REG_RANGE, BMG160_RANGE_500DPS);
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_range\n");
+		dev_err(dev, "Error writing reg_range\n");
 		return ret;
 	data->dps_range = BMG160_RANGE_500DPS;
 	ret = regmap_read(data->regmap, BMG160_REG_SLOPE_THRES, &val);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading reg_slope_thres\n");
+		dev_err(dev, "Error reading reg_slope_thres\n");
 		return ret;
 	data->slope_thres = val;
@@ -228,7 +230,7 @@ static int bmg160_chip_init(struct bmg160_data *data)
 	ret = regmap_update_bits(data->regmap, BMG160_REG_INT_EN_1,
 				 BMG160_INT1_BIT_OD, 0);
 	if (ret < 0) {
-		dev_err(data->dev, "Error updating bits in reg_int_en_1\n");
+		dev_err(dev, "Error updating bits in reg_int_en_1\n");
 		return ret;
@@ -236,7 +238,7 @@ static int bmg160_chip_init(struct bmg160_data *data)
 			   BMG160_INT_MODE_LATCH_INT |
 			   BMG160_INT_MODE_LATCH_RESET);
 	if (ret < 0) {
+		dev_err(dev,
 			"Error writing reg_motion_intr\n");
 		return ret;
@@ -247,20 +249,21 @@ static int bmg160_chip_init(struct bmg160_data *data)
 static int bmg160_set_power_state(struct bmg160_data *data, bool on)
 #ifdef CONFIG_PM
 	int ret;
 	if (on)
-		ret = pm_runtime_get_sync(data->dev);
+		ret = pm_runtime_get_sync(dev);
 	else {
-		pm_runtime_mark_last_busy(data->dev);
-		ret = pm_runtime_put_autosuspend(data->dev);
+		pm_runtime_mark_last_busy(dev);
+		ret = pm_runtime_put_autosuspend(dev);
 	if (ret < 0) {
-			"Failed: bmg160_set_power_state for %d\n", on);
+		dev_err(dev, "Failed: bmg160_set_power_state for %d\n", on);
 		if (on)
-			pm_runtime_put_noidle(data->dev);
+			pm_runtime_put_noidle(dev);
 		return ret;
@@ -272,6 +275,7 @@ static int bmg160_set_power_state(struct bmg160_data *data, bool on)
 static int bmg160_setup_any_motion_interrupt(struct bmg160_data *data,
 					     bool status)
 	int ret;
 	/* Enable/Disable INT_MAP0 mapping */
@@ -279,7 +283,7 @@ static int bmg160_setup_any_motion_interrupt(struct bmg160_data *data,
 				 BMG160_INT_MAP_0_BIT_ANY,
 				 (status ? BMG160_INT_MAP_0_BIT_ANY : 0));
 	if (ret < 0) {
-		dev_err(data->dev, "Error updating bits reg_int_map0\n");
+		dev_err(dev, "Error updating bits reg_int_map0\n");
 		return ret;
@@ -289,8 +293,7 @@ static int bmg160_setup_any_motion_interrupt(struct bmg160_data *data,
 		ret = regmap_write(data->regmap, BMG160_REG_SLOPE_THRES,
 				   data->slope_thres);
 		if (ret < 0) {
-				"Error writing reg_slope_thres\n");
+			dev_err(dev, "Error writing reg_slope_thres\n");
 			return ret;
@@ -298,8 +301,7 @@ static int bmg160_setup_any_motion_interrupt(struct bmg160_data *data,
 				   BMG160_INT_MOTION_X | BMG160_INT_MOTION_Y |
 				   BMG160_INT_MOTION_Z);
 		if (ret < 0) {
-				"Error writing reg_motion_intr\n");
+			dev_err(dev, "Error writing reg_motion_intr\n");
 			return ret;
@@ -314,8 +316,7 @@ static int bmg160_setup_any_motion_interrupt(struct bmg160_data *data,
 			if (ret < 0) {
-					"Error writing reg_rst_latch\n");
+				dev_err(dev, "Error writing reg_rst_latch\n");
 				return ret;
@@ -328,7 +329,7 @@ static int bmg160_setup_any_motion_interrupt(struct bmg160_data *data,
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_int_en0\n");
+		dev_err(dev, "Error writing reg_int_en0\n");
 		return ret;
@@ -338,6 +339,7 @@ static int bmg160_setup_any_motion_interrupt(struct bmg160_data *data,
 static int bmg160_setup_new_data_interrupt(struct bmg160_data *data,
 					   bool status)
 	int ret;
 	/* Enable/Disable INT_MAP1 mapping */
@@ -345,7 +347,7 @@ static int bmg160_setup_new_data_interrupt(struct bmg160_data *data,
 				 BMG160_INT_MAP_1_BIT_NEW_DATA,
 				 (status ? BMG160_INT_MAP_1_BIT_NEW_DATA : 0));
 	if (ret < 0) {
-		dev_err(data->dev, "Error updating bits in reg_int_map1\n");
+		dev_err(dev, "Error updating bits in reg_int_map1\n");
 		return ret;
@@ -354,9 +356,8 @@ static int bmg160_setup_new_data_interrupt(struct bmg160_data *data,
 				   BMG160_INT_MODE_NON_LATCH_INT |
 		if (ret < 0) {
-				return ret;
+			return ret;
 		ret = regmap_write(data->regmap, BMG160_REG_INT_EN_0,
@@ -368,16 +369,15 @@ static int bmg160_setup_new_data_interrupt(struct bmg160_data *data,
 		if (ret < 0) {
-				return ret;
+			return ret;
 		ret = regmap_write(data->regmap, BMG160_REG_INT_EN_0, 0);
 	if (ret < 0) {
 		return ret;
@@ -400,6 +400,7 @@ static int bmg160_get_bw(struct bmg160_data *data, int *val)
 static int bmg160_set_scale(struct bmg160_data *data, int val)
 	int ret, i;
 	for (i = 0; i < ARRAY_SIZE(bmg160_scale_table); ++i) {
@@ -407,8 +408,7 @@ static int bmg160_set_scale(struct bmg160_data *data, int val)
 					   bmg160_scale_table[i].dps_range);
 			if (ret < 0) {
-					"Error writing reg_range\n");
 				return ret;
 			data->dps_range = bmg160_scale_table[i].dps_range;
@@ -421,6 +421,7 @@ static int bmg160_set_scale(struct bmg160_data *data, int val)
 static int bmg160_get_temp(struct bmg160_data *data, int *val)
 	int ret;
 	unsigned int raw_val;
@@ -433,7 +434,7 @@ static int bmg160_get_temp(struct bmg160_data *data, int *val)
 	ret = regmap_read(data->regmap, BMG160_REG_TEMP, &raw_val);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading reg_temp\n");
+		dev_err(dev, "Error reading reg_temp\n");
 		bmg160_set_power_state(data, false);
 		mutex_unlock(&data->mutex);
 		return ret;
@@ -450,6 +451,7 @@ static int bmg160_get_temp(struct bmg160_data *data, int *val)
 static int bmg160_get_axis(struct bmg160_data *data, int axis, int *val)
 	int ret;
@@ -463,7 +465,7 @@ static int bmg160_get_axis(struct bmg160_data *data, int axis, int *val)
 	ret = regmap_bulk_read(data->regmap, BMG160_AXIS_TO_REG(axis), &raw_val,
 			       2);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading axis %d\n", axis);
+		dev_err(dev, "Error reading axis %d\n", axis);
 		return ret;
@@ -793,6 +795,7 @@ static int bmg160_trig_try_reen(struct iio_trigger *trig)
 	struct iio_dev *indio_dev = iio_trigger_get_drvdata(trig);
 	struct bmg160_data *data = iio_priv(indio_dev);
 	int ret;
 	/* new data interrupts don't need ack */
@@ -804,7 +807,7 @@ static int bmg160_trig_try_reen(struct iio_trigger *trig)
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_rst_latch\n");
 		return ret;
@@ -864,13 +867,14 @@ static irqreturn_t bmg160_event_handler(int irq, void *private)
 	struct iio_dev *indio_dev = private;
 	int ret;
 	int dir;
 	unsigned int val;
 	ret = regmap_read(data->regmap, BMG160_REG_INT_STATUS_2, &val);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading reg_int_status2\n");
+		dev_err(dev, "Error reading reg_int_status2\n");
 		goto ack_intr_status;
@@ -907,8 +911,7 @@ ack_intr_status:
 		if (ret < 0)
 	return IRQ_HANDLED;
@@ -976,7 +979,6 @@ int bmg160_core_probe(struct device *dev, struct regmap *regmap, int irq,
 	dev_set_drvdata(dev, indio_dev);
-	data->dev = dev;
 	data->irq = irq;
 	data->regmap = regmap;
@@ -1139,7 +1141,7 @@ static int bmg160_runtime_suspend(struct device *dev)
 	ret = bmg160_set_mode(data, BMG160_MODE_SUSPEND);
 	if (ret < 0) {
-		dev_err(data->dev, "set mode failed\n");
+		dev_err(dev, "set mode failed\n");
 		return -EAGAIN;
