iio: Export I2C module alias information
Author: Javier Martinez Canillas <javier@osg.samsung.com>
The I2C drivers have an i2c_device_id array but that information isn't
exported to the modules using the MODULE_DEVICE_TABLE() macro. So the
modules autoloading won't work if the I2C device is registered using
OF or legacy board files due missing alias information in the modules.
The issue was found using Kieran Bingham's coccinelle semantic patch:
https://lkml.org/lkml/2016/5/10/520
Signed-off-by: Javier Martinez Canillas
Signed-off-by: Jonathan Cameron
 drivers/iio/humidity/am2315.c     | 1 +
 drivers/iio/humidity/htu21.c      | 1 +
 drivers/iio/pressure/hp206c.c     | 1 +
 drivers/iio/pressure/ms5637.c     | 1 +
 drivers/iio/temperature/tsys02d.c | 1 +
 5 files changed, 5 insertions(+)
diff --git a/drivers/iio/humidity/am2315.c b/drivers/iio/humidity/am2315.c
index 3be6d20..8de39bd 100644
--- a/drivers/iio/humidity/am2315.c
+++ b/drivers/iio/humidity/am2315.c
@@ -278,6 +278,7 @@ static const struct i2c_device_id am2315_i2c_id[] = {
 	{"am2315", 0},
+MODULE_DEVICE_TABLE(i2c, am2315_i2c_id);
 static const struct acpi_device_id am2315_acpi_id[] = {
 	{"AOS2315", 0},
diff --git a/drivers/iio/humidity/htu21.c b/drivers/iio/humidity/htu21.c
index 11cbc38..0fbbd8c 100644
--- a/drivers/iio/humidity/htu21.c
+++ b/drivers/iio/humidity/htu21.c
@@ -236,6 +236,7 @@ static const struct i2c_device_id htu21_id[] = {
 	{"ms8607-humidity", MS8607},
+MODULE_DEVICE_TABLE(i2c, htu21_id);
 static struct i2c_driver htu21_driver = {
 	.probe = htu21_probe,
diff --git a/drivers/iio/pressure/hp206c.c b/drivers/iio/pressure/hp206c.c
index 90f2b6e..12f769e 100644
--- a/drivers/iio/pressure/hp206c.c
+++ b/drivers/iio/pressure/hp206c.c
@@ -401,6 +401,7 @@ static const struct i2c_device_id hp206c_id[] = {
 	{"hp206c"},
+MODULE_DEVICE_TABLE(i2c, hp206c_id);
 #ifdef CONFIG_ACPI
 static const struct acpi_device_id hp206c_acpi_match[] = {
diff --git a/drivers/iio/pressure/ms5637.c b/drivers/iio/pressure/ms5637.c
index e68052c..8fb6f7a 100644
--- a/drivers/iio/pressure/ms5637.c
+++ b/drivers/iio/pressure/ms5637.c
@@ -173,6 +173,7 @@ static const struct i2c_device_id ms5637_id[] = {
 	{"ms8607-temppressure", 1},
+MODULE_DEVICE_TABLE(i2c, ms5637_id);
 static struct i2c_driver ms5637_driver = {
 	.probe = ms5637_probe,
diff --git a/drivers/iio/temperature/tsys02d.c b/drivers/iio/temperature/tsys02d.c
index ab6fe8f..c0a19a0 100644
--- a/drivers/iio/temperature/tsys02d.c
+++ b/drivers/iio/temperature/tsys02d.c
@@ -174,6 +174,7 @@ static const struct i2c_device_id tsys02d_id[] = {
 	{"tsys02d", 0},
+MODULE_DEVICE_TABLE(i2c, tsys02d_id);
 static struct i2c_driver tsys02d_driver = {
 	.probe = tsys02d_probe,
BtrLinux
Privacy Overview
