iio: adc: vf610: fix simple_return.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
drivers/iio/adc/vf610_adc.c:766:1-4: WARNING: end returns can be simpified and declaration on line 755 can be dropped
 Simplify a trivial if-return sequence.  Possibly combine with a
 preceding function call.
Generated by: scripts/coccinelle/misc/simple_return.cocci
CC: Sanchayan Maity
Signed-off-by: Fengguang Wu
Signed-off-by: Jonathan Cameron
 drivers/iio/adc/vf610_adc.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/iio/adc/vf610_adc.c b/drivers/iio/adc/vf610_adc.c
index 635ccd8..599cde3 100644
--- a/drivers/iio/adc/vf610_adc.c
+++ b/drivers/iio/adc/vf610_adc.c
@@ -752,7 +752,7 @@ static int vf610_adc_buffer_predisable(struct iio_dev *indio_dev)
 	struct vf610_adc *info = iio_priv(indio_dev);
 	unsigned int hc_cfg = 0;
-	int val, ret;
+	int val;
 	val = readl(info->regs + VF610_REG_ADC_GC);
 	val &= ~VF610_ADC_ADCON;
@@ -763,11 +763,7 @@ static int vf610_adc_buffer_predisable(struct iio_dev *indio_dev)
 	writel(hc_cfg, info->regs + VF610_REG_ADC_HC0);
-	ret = iio_triggered_buffer_predisable(indio_dev);
-	if (ret)
-		return ret;
-	return 0;
+	return iio_triggered_buffer_predisable(indio_dev);
 static const struct iio_buffer_setup_ops iio_triggered_buffer_setup_ops = {
BtrLinux
Privacy Overview
