 drivers/iio/accel/bmc150-accel-core.c | 99 +++++++++++++++++++----------------
 1 file changed, 54 insertions(+), 45 deletions(-)
diff --git a/drivers/iio/accel/bmc150-accel-core.c b/drivers/iio/accel/bmc150-accel-core.c
index e631ee9..91a52c2 100644
--- a/drivers/iio/accel/bmc150-accel-core.c
+++ b/drivers/iio/accel/bmc150-accel-core.c
@@ -188,7 +188,6 @@ enum bmc150_accel_trigger_id {
 struct bmc150_accel_data {
 	struct regmap *regmap;
-	struct device *dev;
 	int irq;
 	struct bmc150_accel_interrupt interrupts[BMC150_ACCEL_INTERRUPTS];
 	atomic_t active_intr;
@@ -257,6 +256,7 @@ static int bmc150_accel_set_mode(struct bmc150_accel_data *data,
 				 enum bmc150_power_modes mode,
 				 int dur_us)
+	struct device *dev = regmap_get_device(data->regmap);
 	int i;
 	int ret;
 	u8 lpw_bits;
@@ -280,11 +280,11 @@ static int bmc150_accel_set_mode(struct bmc150_accel_data *data,
 	lpw_bits = mode << BMC150_ACCEL_PMU_MODE_SHIFT;
 	lpw_bits |= (dur_val << BMC150_ACCEL_PMU_BIT_SLEEP_DUR_SHIFT);
-	dev_dbg(data->dev, "Set Mode bits %x\n", lpw_bits);
+	dev_dbg(dev, "Set Mode bits %x\n", lpw_bits);
 	ret = regmap_write(data->regmap, BMC150_ACCEL_REG_PMU_LPW, lpw_bits);
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_pmu_lpw\n");
+		dev_err(dev, "Error writing reg_pmu_lpw\n");
 		return ret;
@@ -317,23 +317,24 @@ static int bmc150_accel_set_bw(struct bmc150_accel_data *data, int val,
 static int bmc150_accel_update_slope(struct bmc150_accel_data *data)
 	int ret;
 	ret = regmap_write(data->regmap, BMC150_ACCEL_REG_INT_6,
 					data->slope_thres);
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_int_6\n");
+		dev_err(dev, "Error writing reg_int_6\n");
 		return ret;
 	ret = regmap_update_bits(data->regmap, BMC150_ACCEL_REG_INT_5,
 				 BMC150_ACCEL_SLOPE_DUR_MASK, data->slope_dur);
 	if (ret < 0) {
-		dev_err(data->dev, "Error updating reg_int_5\n");
+		dev_err(dev, "Error updating reg_int_5\n");
 		return ret;
-	dev_dbg(data->dev, "%s: %x %x\n", __func__, data->slope_thres,
+	dev_dbg(dev, "%s: %x %x\n", __func__, data->slope_thres,
 		data->slope_dur);
 	return ret;
@@ -379,20 +380,21 @@ static int bmc150_accel_get_startup_times(struct bmc150_accel_data *data)
 static int bmc150_accel_set_power_state(struct bmc150_accel_data *data, bool on)
 	int ret;
 	if (on) {
-		ret = pm_runtime_get_sync(data->dev);
+		ret = pm_runtime_get_sync(dev);
 	} else {
-		pm_runtime_mark_last_busy(data->dev);
-		ret = pm_runtime_put_autosuspend(data->dev);
+		pm_runtime_mark_last_busy(dev);
+		ret = pm_runtime_put_autosuspend(dev);
 	if (ret < 0) {
+		dev_err(dev,
 			"Failed: bmc150_accel_set_power_state for %d\n", on);
 		if (on)
-			pm_runtime_put_noidle(data->dev);
+			pm_runtime_put_noidle(dev);
 		return ret;
@@ -446,6 +448,7 @@ static void bmc150_accel_interrupts_setup(struct iio_dev *indio_dev,
 static int bmc150_accel_set_interrupt(struct bmc150_accel_data *data, int i,
 				      bool state)
 	struct bmc150_accel_interrupt *intr = &data->interrupts[i];
 	const struct bmc150_accel_interrupt_info *info = intr->info;
 	int ret;
@@ -475,7 +478,7 @@ static int bmc150_accel_set_interrupt(struct bmc150_accel_data *data, int i,
 	ret = regmap_update_bits(data->regmap, info->map_reg, info->map_bitmask,
 				 (state ? info->map_bitmask : 0));
 	if (ret < 0) {
-		dev_err(data->dev, "Error updating reg_int_map\n");
+		dev_err(dev, "Error updating reg_int_map\n");
 		goto out_fix_power_state;
@@ -483,7 +486,7 @@ static int bmc150_accel_set_interrupt(struct bmc150_accel_data *data, int i,
 	ret = regmap_update_bits(data->regmap, info->en_reg, info->en_bitmask,
 				 (state ? info->en_bitmask : 0));
 	if (ret < 0) {
-		dev_err(data->dev, "Error updating reg_int_en\n");
+		dev_err(dev, "Error updating reg_int_en\n");
@@ -501,6 +504,7 @@ out_fix_power_state:
 static int bmc150_accel_set_scale(struct bmc150_accel_data *data, int val)
 	int ret, i;
 	for (i = 0; i < ARRAY_SIZE(data->chip_info->scale_table); ++i) {
@@ -509,8 +513,7 @@ static int bmc150_accel_set_scale(struct bmc150_accel_data *data, int val)
 				     BMC150_ACCEL_REG_PMU_RANGE,
 				     data->chip_info->scale_table[i].reg_range);
 			if (ret < 0) {
-					"Error writing pmu_range\n");
+				dev_err(dev, "Error writing pmu_range\n");
 				return ret;
@@ -524,6 +527,7 @@ static int bmc150_accel_set_scale(struct bmc150_accel_data *data, int val)
 static int bmc150_accel_get_temp(struct bmc150_accel_data *data, int *val)
 	int ret;
 	unsigned int value;
@@ -531,7 +535,7 @@ static int bmc150_accel_get_temp(struct bmc150_accel_data *data, int *val)
 	ret = regmap_read(data->regmap, BMC150_ACCEL_REG_TEMP, &value);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading reg_temp\n");
+		dev_err(dev, "Error reading reg_temp\n");
 		mutex_unlock(&data->mutex);
 		return ret;
@@ -546,6 +550,7 @@ static int bmc150_accel_get_axis(struct bmc150_accel_data *data,
 				 struct iio_chan_spec const *chan,
 				 int *val)
 	int ret;
 	int axis = chan->scan_index;
 	unsigned int raw_val;
@@ -560,7 +565,7 @@ static int bmc150_accel_get_axis(struct bmc150_accel_data *data,
 	ret = regmap_bulk_read(data->regmap, BMC150_ACCEL_AXIS_TO_REG(axis),
 			       &raw_val, 2);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading axis %d\n", axis);
+		dev_err(dev, "Error reading axis %d\n", axis);
 		bmc150_accel_set_power_state(data, false);
 		return ret;
@@ -832,6 +837,7 @@ static int bmc150_accel_set_watermark(struct iio_dev *indio_dev, unsigned val)
 static int bmc150_accel_fifo_transfer(struct bmc150_accel_data *data,
 				      char *buffer, int samples)
 	int sample_length = 3 * 2;
 	int ret;
 	int total_length = samples * sample_length;
@@ -855,7 +861,8 @@ static int bmc150_accel_fifo_transfer(struct bmc150_accel_data *data,
 	if (ret)
-		dev_err(data->dev, "Error transferring data from fifo in single steps of %zu\n",
+		dev_err(dev,
+			"Error transferring data from fifo in single steps of %zu\n",
 			step);
 	return ret;
@@ -865,6 +872,7 @@ static int __bmc150_accel_fifo_flush(struct iio_dev *indio_dev,
 				     unsigned samples, bool irq)
 	struct bmc150_accel_data *data = iio_priv(indio_dev);
 	int ret, i;
 	u8 count;
 	u16 buffer[BMC150_ACCEL_FIFO_LENGTH * 3];
@@ -874,7 +882,7 @@ static int __bmc150_accel_fifo_flush(struct iio_dev *indio_dev,
 	ret = regmap_read(data->regmap, BMC150_ACCEL_REG_FIFO_STATUS, &val);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading reg_fifo_status\n");
+		dev_err(dev, "Error reading reg_fifo_status\n");
 		return ret;
@@ -1136,6 +1144,7 @@ static int bmc150_accel_trig_try_reen(struct iio_trigger *trig)
 	struct bmc150_accel_trigger *t = iio_trigger_get_drvdata(trig);
 	struct bmc150_accel_data *data = t->data;
 	int ret;
 	/* new data interrupts don't need ack */
@@ -1149,8 +1158,7 @@ static int bmc150_accel_trig_try_reen(struct iio_trigger *trig)
 			   BMC150_ACCEL_INT_MODE_LATCH_RESET);
 	if (ret < 0) {
-			"Error writing reg_int_rst_latch\n");
+		dev_err(dev, "Error writing reg_int_rst_latch\n");
 		return ret;
@@ -1201,13 +1209,14 @@ static const struct iio_trigger_ops bmc150_accel_trigger_ops = {
 static int bmc150_accel_handle_roc_event(struct iio_dev *indio_dev)
 	int dir;
 	int ret;
 	unsigned int val;
 	ret = regmap_read(data->regmap, BMC150_ACCEL_REG_INT_STATUS_2, &val);
 	if (ret < 0) {
-		dev_err(data->dev, "Error reading reg_int_status_2\n");
+		dev_err(dev, "Error reading reg_int_status_2\n");
 		return ret;
@@ -1250,6 +1259,7 @@ static irqreturn_t bmc150_accel_irq_thread_handler(int irq, void *private)
 	struct iio_dev *indio_dev = private;
 	bool ack = false;
 	int ret;
@@ -1273,7 +1283,7 @@ static irqreturn_t bmc150_accel_irq_thread_handler(int irq, void *private)
 				   BMC150_ACCEL_INT_MODE_LATCH_INT |
 		if (ret)
-			dev_err(data->dev, "Error writing reg_int_rst_latch\n");
 		ret = IRQ_HANDLED;
 	} else {
@@ -1344,13 +1354,14 @@ static void bmc150_accel_unregister_triggers(struct bmc150_accel_data *data,
 static int bmc150_accel_triggers_setup(struct iio_dev *indio_dev,
 	int i, ret;
 	for (i = 0; i < BMC150_ACCEL_TRIGGERS; i++) {
 		struct bmc150_accel_trigger *t = &data->triggers[i];
-		t->indio_trig = devm_iio_trigger_alloc(data->dev,
-					       bmc150_accel_triggers[i].name,
+		t->indio_trig = devm_iio_trigger_alloc(dev,
+					bmc150_accel_triggers[i].name,
 						       indio_dev->name,
 						       indio_dev->id);
 		if (!t->indio_trig) {
@@ -1358,7 +1369,7 @@ static int bmc150_accel_triggers_setup(struct iio_dev *indio_dev,
 			break;
-		t->indio_trig->dev.parent = data->dev;
+		t->indio_trig->dev.parent = dev;
 		t->indio_trig->ops = &bmc150_accel_trigger_ops;
 		t->intr = bmc150_accel_triggers[i].intr;
 		t->data = data;
@@ -1382,12 +1393,13 @@ static int bmc150_accel_triggers_setup(struct iio_dev *indio_dev,
 static int bmc150_accel_fifo_set_mode(struct bmc150_accel_data *data)
 	u8 reg = BMC150_ACCEL_REG_FIFO_CONFIG1;
 	int ret;
 	ret = regmap_write(data->regmap, reg, data->fifo_mode);
 	if (ret < 0) {
-		dev_err(data->dev, "Error writing reg_fifo_config1\n");
+		dev_err(dev, "Error writing reg_fifo_config1\n");
 		return ret;
@@ -1397,7 +1409,7 @@ static int bmc150_accel_fifo_set_mode(struct bmc150_accel_data *data)
 	ret = regmap_write(data->regmap, BMC150_ACCEL_REG_FIFO_CONFIG0,
 			   data->watermark);
 	if (ret < 0)
-		dev_err(data->dev, "Error writing reg_fifo_config0\n");
+		dev_err(dev, "Error writing reg_fifo_config0\n");
 	return ret;
@@ -1481,17 +1493,17 @@ static const struct iio_buffer_setup_ops bmc150_accel_buffer_ops = {
 static int bmc150_accel_chip_init(struct bmc150_accel_data *data)
 	int ret, i;
 	unsigned int val;
 	ret = regmap_read(data->regmap, BMC150_ACCEL_REG_CHIP_ID, &val);
 	if (ret < 0) {
-			"Error: Reading chip id\n");
+		dev_err(dev, "Error: Reading chip id\n");
 		return ret;
-	dev_dbg(data->dev, "Chip Id %x\n", val);
+	dev_dbg(dev, "Chip Id %x\n", val);
 	for (i = 0; i < ARRAY_SIZE(bmc150_accel_chip_info_tbl); i++) {
 		if (bmc150_accel_chip_info_tbl[i].chip_id == val) {
 			data->chip_info = &bmc150_accel_chip_info_tbl[i];
@@ -1500,7 +1512,7 @@ static int bmc150_accel_chip_init(struct bmc150_accel_data *data)
 	if (!data->chip_info) {
-		dev_err(data->dev, "Invalid chip %x\n", val);
+		dev_err(dev, "Invalid chip %x\n", val);
 		return -ENODEV;
@@ -1517,8 +1529,7 @@ static int bmc150_accel_chip_init(struct bmc150_accel_data *data)
 	ret = regmap_write(data->regmap, BMC150_ACCEL_REG_PMU_RANGE,
 			   BMC150_ACCEL_DEF_RANGE_4G);
 	if (ret < 0) {
-					"Error writing reg_pmu_range\n");
+		dev_err(dev, "Error writing reg_pmu_range\n");
 		return ret;
@@ -1536,8 +1547,7 @@ static int bmc150_accel_chip_init(struct bmc150_accel_data *data)
 	if (ret < 0) {
 		return ret;
@@ -1557,7 +1567,6 @@ int bmc150_accel_core_probe(struct device *dev, struct regmap *regmap, int irq,
 	dev_set_drvdata(dev, indio_dev);
-	data->dev = dev;
 	data->irq = irq;
 	data->regmap = regmap;
@@ -1581,13 +1590,13 @@ int bmc150_accel_core_probe(struct device *dev, struct regmap *regmap, int irq,
 					 bmc150_accel_trigger_handler,
 					 &bmc150_accel_buffer_ops);
 	if (ret < 0) {
-		dev_err(data->dev, "Failed: iio triggered buffer setup\n");
+		dev_err(dev, "Failed: iio triggered buffer setup\n");
 		return ret;
 	if (data->irq > 0) {
 		ret = devm_request_threaded_irq(
-						data->dev, data->irq,
+						dev, data->irq,
 						bmc150_accel_irq_handler,
 						bmc150_accel_irq_thread_handler,
 						IRQF_TRIGGER_RISING,
@@ -1605,7 +1614,7 @@ int bmc150_accel_core_probe(struct device *dev, struct regmap *regmap, int irq,
 		ret = regmap_write(data->regmap, BMC150_ACCEL_REG_INT_RST_LATCH,
 		if (ret < 0) {
 			goto err_buffer_cleanup;
@@ -1654,9 +1663,9 @@ int bmc150_accel_core_remove(struct device *dev)
 	iio_device_unregister(indio_dev);
-	pm_runtime_disable(data->dev);
-	pm_runtime_set_suspended(data->dev);
+	pm_runtime_disable(dev);
+	pm_runtime_set_suspended(dev);
 	bmc150_accel_unregister_triggers(data, BMC150_ACCEL_TRIGGERS - 1);
@@ -1705,7 +1714,7 @@ static int bmc150_accel_runtime_suspend(struct device *dev)
 	int ret;
-	dev_dbg(data->dev,  __func__);
+	dev_dbg(dev,  __func__);
 	ret = bmc150_accel_set_mode(data, BMC150_ACCEL_SLEEP_MODE_SUSPEND, 0);
 	if (ret < 0)
 		return -EAGAIN;
@@ -1720,7 +1729,7 @@ static int bmc150_accel_runtime_resume(struct device *dev)
 	int ret;
 	int sleep_val;
 	ret = bmc150_accel_set_mode(data, BMC150_ACCEL_SLEEP_MODE_NORMAL, 0);
 	if (ret < 0) |
