igmp: remove exceptional & on function name
Author: Himangi Saraogi <himangi774@gmail.com>
In this file, function names are otherwise used as pointers without &.
A simplified version of the Coccinelle semantic patch that makes this
change is as follows:
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: David S. Miller
 net/ipv4/igmp.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/ipv4/igmp.c b/net/ipv4/igmp.c
index db710b0..f10eab4 100644
--- a/net/ipv4/igmp.c
+++ b/net/ipv4/igmp.c
@@ -1321,7 +1321,7 @@ void ip_mc_inc_group(struct in_device *in_dev, __be32 addr)
 	atomic_set(&im->refcnt, 1);
 	spin_lock_init(&im->lock);
 #ifdef CONFIG_IP_MULTICAST
-	setup_timer(&im->timer, &igmp_timer_expire, (unsigned long)im);
+	setup_timer(&im->timer, igmp_timer_expire, (unsigned long)im);
 	im->unsolicit_count = IGMP_Unsolicited_Report_Count;
 #endif
BtrLinux
Privacy Overview
