Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. An explicit linux/device.h include is added to make sure
the devm_*() routine declarations are unambiguously available.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
.probe = probefn,
.remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/ieee802154/fakelb.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ieee802154/fakelb.c b/drivers/net/ieee802154/fakelb.c
index b8d2217..27d8320 100644
--- a/drivers/net/ieee802154/fakelb.c
+++ b/drivers/net/ieee802154/fakelb.c
@@ -26,6 +26,7 @@
#include <linux/timer.h>
#include <linux/platform_device.h>
#include <linux/netdevice.h>
+#include <linux/device.h>
#include <linux/spinlock.h>
#include <net/mac802154.h>
#include <net/wpan-phy.h>
@@ -228,7 +229,8 @@ static int fakelb_probe(struct platform_device *pdev)
int err = -ENOMEM;
int i;
- priv = kzalloc(sizeof(struct fakelb_priv), GFP_KERNEL);
+ priv = devm_kzalloc(&pdev->dev, sizeof(struct fakelb_priv),
+ GFP_KERNEL);
if (!priv)
goto err_alloc;
@@ -248,7 +250,6 @@ static int fakelb_probe(struct platform_device *pdev)
err_slave:
list_for_each_entry(dp, &priv->list, list)
fakelb_del(dp);
- kfree(priv);
err_alloc:
return err;
@@ -260,7 +261,6 @@ static int fakelb_remove(struct platform_device *pdev)
list_for_each_entry_safe(dp, temp, &priv->list, list)
fakelb_del(dp);
- kfree(priv);
return 0;
@@ -26,6 +26,7 @@
int err = -ENOMEM;
int i;
+ GFP_KERNEL);
if (!priv)
goto err_alloc;
err_slave:
fakelb_del(dp);
- kfree(priv);
err_alloc:
return err;
fakelb_del(dp);
- kfree(priv);
return 0;
