Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. The label sysfs_failed is removed as it is no longer
required. Also, linux/device.h is added to make sure the devm_*()
routine declarations are unambiguously available.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
.probe = probefn,
.remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Matthew Garrett
drivers/platform/x86/ideapad-laptop.c | 8 +++-----
1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/platform/x86/ideapad-laptop.c b/drivers/platform/x86/ideapad-laptop.c
index 219eb28..b4c495a 100644
--- a/drivers/platform/x86/ideapad-laptop.c
+++ b/drivers/platform/x86/ideapad-laptop.c
@@ -37,6 +37,7 @@
#include <linux/seq_file.h>
#include <linux/i8042.h>
#include <linux/dmi.h>
+#include <linux/device.h>
#define IDEAPAD_RFKILL_DEV_NUM (3)
@@ -847,7 +848,7 @@ static int ideapad_acpi_add(struct platform_device *pdev)
if (read_method_int(adev->handle, "_CFG", &cfg))
return -ENODEV;
- priv = kzalloc(sizeof(*priv), GFP_KERNEL);
+ priv = devm_kzalloc(&pdev->dev, sizeof(*priv), GFP_KERNEL);
if (!priv)
return -ENOMEM;
@@ -858,7 +859,7 @@ static int ideapad_acpi_add(struct platform_device *pdev)
ret = ideapad_sysfs_init(priv);
if (ret)
- goto sysfs_failed;
+ return ret;
ret = ideapad_debugfs_init(priv);
if (ret)
@@ -897,8 +898,6 @@ input_failed:
ideapad_debugfs_exit(priv);
debugfs_failed:
ideapad_sysfs_exit(priv);
-sysfs_failed:
- kfree(priv);
return ret;
@@ -916,7 +915,6 @@ static int ideapad_acpi_remove(struct platform_device *pdev)
dev_set_drvdata(&pdev->dev, NULL);
- kfree(priv);
return 0;
@@ -37,6 +37,7 @@
return -ENODEV;
if (!priv)
return -ENOMEM;
if (ret)
+ return ret;
if (ret)
debugfs_failed:
-sysfs_failed:
- kfree(priv);
return ret;
- kfree(priv);
return 0;
