IDE: Deletion of an unnecessary check before the function call “module_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The module_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: David S. Miller
drivers/ide/ide.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/ide/ide.c b/drivers/ide/ide.c
index 2ce6268..e29b02c 100644
--- a/drivers/ide/ide.c
+++ b/drivers/ide/ide.c
@@ -101,8 +101,7 @@ void ide_device_put(ide_drive_t *drive)
struct device *host_dev = drive->hwif->host->dev[0];
struct module *module = host_dev ? host_dev->driver->owner : NULL;
- if (module)
- module_put(module);
+ module_put(module);
#endif
put_device(&drive->gendev);
- if (module)
#endif
