IB/qib: Replace rcu_assign_pointer() with RCU_INIT_POINTER() in qib_keys.c
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The uses of "rcu_assign_pointer()" are NULLing out the pointers.
According to RCU_INIT_POINTER()'s block comment:
"1. This use of RCU_INIT_POINTER() is NULLing out the pointer"
it is better to use it instead of rcu_assign_pointer() because it has a
smaller overhead.
The following Coccinelle semantic patch was used:
- rcu_assign_pointer
+ RCU_INIT_POINTER
(..., NULL)
[Derived from http://marc.info/?l=linux-rdma&m=140836519219236&w=2]
Tested-by: Mike Marciniszyn
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: Mike Marciniszyn
Signed-off-by: Roland Dreier
drivers/infiniband/hw/qib/qib_keys.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/infiniband/hw/qib/qib_keys.c b/drivers/infiniband/hw/qib/qib_keys.c
index 3b9afcc..ad843c7 100644
--- a/drivers/infiniband/hw/qib/qib_keys.c
+++ b/drivers/infiniband/hw/qib/qib_keys.c
@@ -122,10 +122,10 @@ void qib_free_lkey(struct qib_mregion *mr)
if (!mr->lkey_published)
goto out;
if (lkey == 0)
- rcu_assign_pointer(dev->dma_mr, NULL);
+ RCU_INIT_POINTER(dev->dma_mr, NULL);
else {
r = lkey >> (32 - ib_qib_lkey_table_size);
- rcu_assign_pointer(rkt->table[r], NULL);
+ RCU_INIT_POINTER(rkt->table[r], NULL);
qib_put_mr(mr);
mr->lkey_published = 0; |
goto out;
if (lkey == 0)
else {
qib_put_mr(mr);
