IB/nes: Return an error on ib_copy_from_udata() failure instead of NULL
Author: Yann Droneaud <ydroneaud@opteya.com>
In case of error while accessing to userspace memory, function
nes_create_qp() returns NULL instead of an error code wrapped through
ERR_PTR().  But NULL is not expected by ib_uverbs_create_qp(), as it
check for error with IS_ERR().
As page 0 is likely not mapped, it is going to trigger an Oops when
the kernel will try to dereference NULL pointer to access to struct
ib_qp's fields.
In some rare cases, page 0 could be mapped by userspace, which could
turn this bug to a vulnerability that could be exploited: the function
pointers in struct ib_device will be under userspace total control.
This was caught when using spatch (aka. coccinelle)
to rewrite calls to ib_copy_{from,to}_udata().
Link: https://www.gitorious.org/opteya/ib-hw-nes-create-qp-null
Link: https://www.gitorious.org/opteya/coccib/source/75ebf2c1033c64c1d81df13e4ae44ee99c989eba:ib_copy_udata.cocci
Link: http://marc.info/?i=cover.1394485254.git.ydroneaud@opteya.com
Cc:
Signed-off-by: Yann Droneaud
Signed-off-by: Roland Dreier
 drivers/infiniband/hw/nes/nes_verbs.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/infiniband/hw/nes/nes_verbs.c b/drivers/infiniband/hw/nes/nes_verbs.c
index 8308e36..eb62461 100644
--- a/drivers/infiniband/hw/nes/nes_verbs.c
+++ b/drivers/infiniband/hw/nes/nes_verbs.c
@@ -1186,7 +1186,7 @@ static struct ib_qp *nes_create_qp(struct ib_pd *ibpd,
 					nes_free_resource(nesadapter, nesadapter->allocated_qps, qp_num);
 					kfree(nesqp->allocated_buffer);
 					nes_debug(NES_DBG_QP, "ib_copy_from_udata() Failed \n");
-					return NULL;
+					return ERR_PTR(-EFAULT);
 				if (req.user_wqe_buffers) {
 					virt_wqs = 1;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
