IB/mlx4: Fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Roland Dreier
 drivers/infiniband/hw/mlx4/sysfs.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/infiniband/hw/mlx4/sysfs.c b/drivers/infiniband/hw/mlx4/sysfs.c
index 97516eb..db2ea31 100644
--- a/drivers/infiniband/hw/mlx4/sysfs.c
+++ b/drivers/infiniband/hw/mlx4/sysfs.c
@@ -582,8 +582,10 @@ static int add_port(struct mlx4_ib_dev *dev, int port_num, int slave)
 	p->pkey_group.attrs =
 		alloc_group_attrs(show_port_pkey, store_port_pkey,
 				  dev->dev->caps.pkey_table_len[port_num]);
-	if (!p->pkey_group.attrs)
+	if (!p->pkey_group.attrs) {
+		ret = -ENOMEM;
 		goto err_alloc;
 	ret = sysfs_create_group(&p->kobj, &p->pkey_group);
 	if (ret)
@@ -591,8 +593,10 @@ static int add_port(struct mlx4_ib_dev *dev, int port_num, int slave)
 	p->gid_group.name  = "gid_idx";
 	p->gid_group.attrs = alloc_group_attrs(show_port_gid_idx, NULL, 1);
-	if (!p->gid_group.attrs)
+	if (!p->gid_group.attrs) {
+		ret = -ENOMEM;
 		goto err_free_pkey;
 	ret = sysfs_create_group(&p->kobj, &p->gid_group);
 	if (ret)
BtrLinux
Privacy Overview
