IB/hfi1: Replace kmalloc and memcpy with a kmemdup
Author: Harish Chegondi <harish.chegondi@intel.com>
This change was recommended by Coccinelle tool when I ran the command:
-bash-4.2$ make coccicheck MODE=patch M=drivers/infiniband/hw/hfi1/
Reviewed-by: Jubin John
Reviewed-by: Mike Marciniszyn
Reviewed-by: Dennis Dalessandro
Signed-off-by: Harish Chegondi
Signed-off-by: Doug Ledford
 drivers/staging/rdma/hfi1/efivar.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/rdma/hfi1/efivar.c b/drivers/staging/rdma/hfi1/efivar.c
index 5fe3924..3f014f9 100644
--- a/drivers/staging/rdma/hfi1/efivar.c
+++ b/drivers/staging/rdma/hfi1/efivar.c
@@ -125,13 +125,12 @@ static int read_efi_var(const char *name, unsigned long *size,
 	 * temporary buffer.  Now allocate a correctly sized
 	 * buffer.
-	data = kmalloc(temp_size, GFP_KERNEL);
+	data = kmemdup(temp_buffer, temp_size, GFP_KERNEL);
 	if (!data) {
 		ret = -ENOMEM;
 		goto fail;
-	memcpy(data, temp_buffer, temp_size);
 	*size = temp_size;
 	*return_data = data;
BtrLinux
Privacy Overview
