IB/ehca: Remove redundant test of vpage
vpage is checked not to be NULL just after it is initialized at the
beginning of each loop iteration.
A simplified version of the semantic patch that makes this change is
as follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
position p1,p2;
if (x@p1 == NULL || ...) { ... when forall
   return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
x@p2 == NULL
x@p2 != NULL
// another path to the test that is not through p1?
@s exists@
local idexpression r.x;
position r.p1,r.p2;
... when != x@p1
x@p2 == NULL
x@p2 != NULL
@fix depends on !s@
position r.p1,r.p2;
expression x,E;
statement S1,S2;
- if ((x@p2 != NULL) || ...)
  S1
- if ((x@p2 == NULL) && ...) S1
- BUG_ON(x@p2 == NULL);
Signed-off-by: Julia Lawall
Signed-off-by: Roland Dreier
 drivers/infiniband/hw/ehca/ehca_eq.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/infiniband/hw/ehca/ehca_eq.c b/drivers/infiniband/hw/ehca/ehca_eq.c
index 49660df..523e733 100644
--- a/drivers/infiniband/hw/ehca/ehca_eq.c
+++ b/drivers/infiniband/hw/ehca/ehca_eq.c
@@ -113,7 +113,7 @@ int ehca_create_eq(struct ehca_shca *shca,
 			if (h_ret != H_SUCCESS || vpage)
 				goto create_eq_exit2;
 		} else {
-			if (h_ret != H_PAGE_REGISTERED || !vpage)
+			if (h_ret != H_PAGE_REGISTERED)
 		} else {
