IB/ehca: fix handling idr_alloc result
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Acked-by: Doug Ledford
 drivers/staging/rdma/ehca/ehca_cq.c | 13 +++++++------
 1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rdma/ehca/ehca_cq.c b/drivers/staging/rdma/ehca/ehca_cq.c
index 9b68b17..ea1b5c1 100644
--- a/drivers/staging/rdma/ehca/ehca_cq.c
+++ b/drivers/staging/rdma/ehca/ehca_cq.c
@@ -130,7 +130,7 @@ struct ib_cq *ehca_create_cq(struct ib_device *device,
 	void *vpage;
 	u32 counter;
 	u64 rpage, cqx_fec, h_ret;
-	int ipz_rc, i;
+	int rc, i;
 	unsigned long flags;
 	if (attr->flags)
@@ -170,16 +170,17 @@ struct ib_cq *ehca_create_cq(struct ib_device *device,
 	idr_preload(GFP_KERNEL);
 	write_lock_irqsave(&ehca_cq_idr_lock, flags);
-	my_cq->token = idr_alloc(&ehca_cq_idr, my_cq, 0, 0x2000000, GFP_NOWAIT);
+	rc = idr_alloc(&ehca_cq_idr, my_cq, 0, 0x2000000, GFP_NOWAIT);
 	write_unlock_irqrestore(&ehca_cq_idr_lock, flags);
 	idr_preload_end();
-	if (my_cq->token < 0) {
+	if (rc < 0) {
 		cq = ERR_PTR(-ENOMEM);
 		ehca_err(device, "Can't allocate new idr entry. device=%p",
 			 device);
 		goto create_cq_exit1;
+	my_cq->token = rc;
 	 * CQs maximum depth is 4GB-64, but we need additional 20 as buffer
@@ -195,11 +196,11 @@ struct ib_cq *ehca_create_cq(struct ib_device *device,
 		goto create_cq_exit2;
-	ipz_rc = ipz_queue_ctor(NULL, &my_cq->ipz_queue, param.act_pages,
+	rc = ipz_queue_ctor(NULL, &my_cq->ipz_queue, param.act_pages,
 				EHCA_PAGESIZE, sizeof(struct ehca_cqe), 0, 0);
-	if (!ipz_rc) {
+	if (!rc) {
 		ehca_err(device, "ipz_queue_ctor() failed ipz_rc=%i device=%p",
-			 ipz_rc, device);
+			 rc, device);
 		cq = ERR_PTR(-EINVAL);
 		goto create_cq_exit3;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
