ia64: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e1, e2, a;
-init_timer(&e1);
+setup_timer(&e1, a, 0UL);
... when != a = e2
-e1.function = a;
Signed-off-by: Vaishali Thakkar
Signed-off-by: Tony Luck
arch/ia64/kernel/mca.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/ia64/kernel/mca.c b/arch/ia64/kernel/mca.c
index dd5801e..2889412 100644
--- a/arch/ia64/kernel/mca.c
+++ b/arch/ia64/kernel/mca.c
@@ -2117,8 +2117,7 @@ ia64_mca_late_init(void)
register_hotcpu_notifier(&mca_cpu_notifier);
/* Setup the CMCI/P vector and handler */
- init_timer(&cmc_poll_timer);
- cmc_poll_timer.function = ia64_mca_cmc_poll;
+ setup_timer(&cmc_poll_timer, ia64_mca_cmc_poll, 0UL);
/* Unmask/enable the vector */
cmc_polling_enabled = 0;
@@ -2129,8 +2128,7 @@ ia64_mca_late_init(void)
#ifdef CONFIG_ACPI
/* Setup the CPEI/P vector and handler */
cpe_vector = acpi_request_vector(ACPI_INTERRUPT_CPEI);
- init_timer(&cpe_poll_timer);
- cpe_poll_timer.function = ia64_mca_cpe_poll;
+ setup_timer(&cpe_poll_timer, ia64_mca_cpe_poll, 0UL);
unsigned int irq; |
#ifdef CONFIG_ACPI
unsigned int irq;
