ia64: tioca: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer
Signed-off-by: Tony Luck
 arch/ia64/sn/pci/tioca_provider.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/ia64/sn/pci/tioca_provider.c b/arch/ia64/sn/pci/tioca_provider.c
index 642451e..e77c477 100644
--- a/arch/ia64/sn/pci/tioca_provider.c
+++ b/arch/ia64/sn/pci/tioca_provider.c
@@ -600,11 +600,11 @@ tioca_bus_fixup(struct pcibus_bussoft *prom_bussoft, struct pci_controller *cont
 	 * Allocate kernel bus soft and copy from prom.
-	tioca_common = kzalloc(sizeof(struct tioca_common), GFP_KERNEL);
+	tioca_common = kmemdup(prom_bussoft, sizeof(struct tioca_common),
+			       GFP_KERNEL);
 	if (!tioca_common)
 		return NULL;
-	memcpy(tioca_common, prom_bussoft, sizeof(struct tioca_common));
 	tioca_common->ca_common.bs_base = (unsigned long)
 		ioremap(REGION_OFFSET(tioca_common->ca_common.bs_base),
BtrLinux
Privacy Overview
