ia64: pcibr: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer
Signed-off-by: Tony Luck
 arch/ia64/sn/pci/pcibr/pcibr_provider.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/ia64/sn/pci/pcibr/pcibr_provider.c b/arch/ia64/sn/pci/pcibr/pcibr_provider.c
index 5698f29..8886a0b 100644
--- a/arch/ia64/sn/pci/pcibr/pcibr_provider.c
+++ b/arch/ia64/sn/pci/pcibr/pcibr_provider.c
@@ -127,12 +127,11 @@ pcibr_bus_fixup(struct pcibus_bussoft *prom_bussoft, struct pci_controller *cont
 	 * Allocate kernel bus soft and copy from prom.
-	soft = kmalloc(sizeof(struct pcibus_info), GFP_KERNEL);
+	soft = kmemdup(prom_bussoft, sizeof(struct pcibus_info), GFP_KERNEL);
 	if (!soft) {
 		return NULL;
-	memcpy(soft, prom_bussoft, sizeof(struct pcibus_info));
 	soft->pbi_buscommon.bs_base = (unsigned long)
 		ioremap(REGION_OFFSET(soft->pbi_buscommon.bs_base),
 			sizeof(struct pic));
BtrLinux
Privacy Overview
