drivers/infiniband/hw/i40iw/i40iw_ctrl.c | 4743 ++++++++++++++++++++++++++++++
1 file changed, 4743 insertions(+)
diff --git a/drivers/infiniband/hw/i40iw/i40iw_ctrl.c b/drivers/infiniband/hw/i40iw/i40iw_ctrl.c
new file mode 100644
index 0000000..f05802b
--- /dev/null
+++ b/drivers/infiniband/hw/i40iw/i40iw_ctrl.c
@@ -0,0 +1,4743 @@
+* Copyright (c) 2015-2016 Intel Corporation. All rights reserved.
+* This software is available to you under a choice of one of two
+* licenses. You may choose to be licensed under the terms of the GNU
+* General Public License (GPL) Version 2, available from the file
+* COPYING in the main directory of this source tree, or the
+* OpenFabrics.org BSD license below:
+* Redistribution and use in source and binary forms, with or
+* without modification, are permitted provided that the following
+* conditions are met:
+* - Redistributions of source code must retain the above
+* copyright notice, this list of conditions and the following
+* disclaimer.
+* - Redistributions in binary form must reproduce the above
+* disclaimer in the documentation and/or other materials
+* provided with the distribution.
+* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
+* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
+* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
+* NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
+* BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
+* ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
+* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+* SOFTWARE.
+#include "i40iw_osdep.h"
+#include "i40iw_register.h"
+#include "i40iw_status.h"
+#include "i40iw_hmc.h"
+#include "i40iw_d.h"
+#include "i40iw_type.h"
+#include "i40iw_p.h"
+#include "i40iw_vf.h"
+#include "i40iw_virtchnl.h"
+ * i40iw_insert_wqe_hdr - write wqe header
+ * @wqe: cqp wqe for header
+ * @header: header for the cqp wqe
+static inline void i40iw_insert_wqe_hdr(u64 *wqe, u64 header)
+ wmb(); /* make sure WQE is populated before polarity is set */
+ set_64bit_val(wqe, 24, header);
+ * i40iw_get_cqp_reg_info - get head and tail for cqp using registers
+ * @cqp: struct for cqp hw
+ * @val: cqp tail register value
+ * @tail:wqtail register value
+ * @error: cqp processing err
+static inline void i40iw_get_cqp_reg_info(struct i40iw_sc_cqp *cqp,
+ u32 *val,
+ u32 *tail,
+ u32 *error)
+ if (cqp->dev->is_pf) {
+ *val = i40iw_rd32(cqp->dev->hw, I40E_PFPE_CQPTAIL);
+ *tail = RS_32(*val, I40E_PFPE_CQPTAIL_WQTAIL);
+ *error = RS_32(*val, I40E_PFPE_CQPTAIL_CQP_OP_ERR);
+ } else {
+ *val = i40iw_rd32(cqp->dev->hw, I40E_VFPE_CQPTAIL1);
+ *tail = RS_32(*val, I40E_VFPE_CQPTAIL_WQTAIL);
+ *error = RS_32(*val, I40E_VFPE_CQPTAIL_CQP_OP_ERR);
+ * i40iw_cqp_poll_registers - poll cqp registers
+ * @count: how many times to try for completion
+static enum i40iw_status_code i40iw_cqp_poll_registers(
+ struct i40iw_sc_cqp *cqp,
+ u32 tail,
+ u32 count)
+ u32 i = 0;
+ u32 newtail, error, val;
+ while (i < count) {
+ i++;
+ i40iw_get_cqp_reg_info(cqp, &val, &newtail, &error);
+ if (error) {
+ error = (cqp->dev->is_pf) ?
+ i40iw_rd32(cqp->dev->hw, I40E_PFPE_CQPERRCODES) :
+ i40iw_rd32(cqp->dev->hw, I40E_VFPE_CQPERRCODES1);
+ return I40IW_ERR_CQP_COMPL_ERROR;
+ if (newtail != tail) {
+ /* SUCCESS */
+ I40IW_RING_MOVE_TAIL(cqp->sq_ring);
+ return 0;
+ udelay(I40IW_SLEEP_COUNT);
+ return I40IW_ERR_TIMEOUT;
+ * i40iw_sc_parse_fpm_commit_buf - parse fpm commit buffer
+ * @buf: ptr to fpm commit buffer
+ * @info: ptr to i40iw_hmc_obj_info struct
+ * parses fpm commit info and copy base value
+ * of hmc objects in hmc_info
+static enum i40iw_status_code i40iw_sc_parse_fpm_commit_buf(
+ u64 *buf,
+ struct i40iw_hmc_obj_info *info)
+ u64 temp;
+ u32 i, j;
+ u32 low;
+ /* copy base values in obj_info */
+ for (i = I40IW_HMC_IW_QP, j = 0;
+ i <= I40IW_HMC_IW_PBLE; i++, j += 8) {
+ get_64bit_val(buf, j, &temp);
+ info[i].base = RS_64_1(temp, 32) * 512;
+ low = (u32)(temp);
+ if (low)
+ info[i].cnt = low;
+ return 0;
+ * i40iw_sc_parse_fpm_query_buf() - parses fpm query buffer
+ * @buf: ptr to fpm query buffer
+ * @hmc_fpm_misc: ptr to fpm data
+ * parses fpm query buffer and copy max_cnt and
+ * size value of hmc objects in hmc_info
+static enum i40iw_status_code i40iw_sc_parse_fpm_query_buf(
+ u64 *buf,
+ struct i40iw_hmc_info *hmc_info,
+ struct i40iw_hmc_fpm_misc *hmc_fpm_misc)
+ u64 temp;
+ struct i40iw_hmc_obj_info *obj_info;
+ u32 i, j, size;
+ u16 max_pe_sds;
+ obj_info = hmc_info->hmc_obj;
+ get_64bit_val(buf, 0, &temp);
+ hmc_info->first_sd_index = (u16)RS_64(temp, I40IW_QUERY_FPM_FIRST_PE_SD_INDEX);
+ max_pe_sds = (u16)RS_64(temp, I40IW_QUERY_FPM_MAX_PE_SDS);
+ /* Reduce SD count for VFs by 1 to account for PBLE backing page rounding */
+ if (hmc_info->hmc_fn_id >= I40IW_FIRST_VF_FPM_ID)
+ max_pe_sds--;
+ hmc_fpm_misc->max_sds = max_pe_sds;
+ hmc_info->sd_table.sd_cnt = max_pe_sds + hmc_info->first_sd_index;
+ for (i = I40IW_HMC_IW_QP, j = 8;
+ i <= I40IW_HMC_IW_ARP; i++, j += 8) {
+ if (i == I40IW_HMC_IW_QP)
+ obj_info[i].max_cnt = (u32)RS_64(temp, I40IW_QUERY_FPM_MAX_QPS);
+ else if (i == I40IW_HMC_IW_CQ)
+ obj_info[i].max_cnt = (u32)RS_64(temp, I40IW_QUERY_FPM_MAX_CQS);
+ else
+ obj_info[i].max_cnt = (u32)temp;
+ size = (u32)RS_64_1(temp, 32);
+ obj_info[i].size = ((u64)1 << size);
+ for (i = I40IW_HMC_IW_MR, j = 48;
+ obj_info[i].size = LS_64_1(1, size);
+ get_64bit_val(buf, 120, &temp);
+ hmc_fpm_misc->max_ceqs = (u8)RS_64(temp, I40IW_QUERY_FPM_MAX_CEQS);
+ hmc_fpm_misc->ht_multiplier = RS_64(temp, I40IW_QUERY_FPM_HTMULTIPLIER);
+ hmc_fpm_misc->timer_bucket = RS_64(temp, I40IW_QUERY_FPM_TIMERBUCKET);
+ get_64bit_val(buf, 64, &temp);
+ hmc_fpm_misc->xf_block_size = RS_64(temp, I40IW_QUERY_FPM_XFBLOCKSIZE);
+ if (!hmc_fpm_misc->xf_block_size)
+ return I40IW_ERR_INVALID_SIZE;
+ get_64bit_val(buf, 80, &temp);
+ hmc_fpm_misc->q1_block_size = RS_64(temp, I40IW_QUERY_FPM_Q1BLOCKSIZE);
+ if (!hmc_fpm_misc->q1_block_size)
+ return 0;
+ * i40iw_sc_pd_init - initialize sc pd struct
+ * @dev: sc device struct
+ * @pd: sc pd ptr
+ * @pd_id: pd_id for allocated pd
+static void i40iw_sc_pd_init(struct i40iw_sc_dev *dev,
+ struct i40iw_sc_pd *pd,
+ u16 pd_id)
+ pd->size = sizeof(*pd);
+ pd->pd_id = pd_id;
+ pd->dev = dev;
+ * i40iw_get_encoded_wqe_size - given wq size, returns hardware encoded size
+ * @wqsize: size of the wq (sq, rq, srq) to encoded_size
+ * @cqpsq: encoded size for sq for cqp as its encoded size is 1+ other wq's
+u8 i40iw_get_encoded_wqe_size(u32 wqsize, bool cqpsq)
+ u8 encoded_size = 0;
+ /* cqp sq's hw coded value starts from 1 for size of 4
+ * while it starts from 0 for qp' wq's.
+ if (cqpsq)
+ encoded_size = 1;
+ wqsize >>= 2;
+ while (wqsize >>= 1)
+ encoded_size++;
+ return encoded_size;
+ * i40iw_sc_cqp_init - Initialize buffers for a control Queue Pair
+ * @cqp: IWARP control queue pair pointer
+ * @info: IWARP control queue pair init info pointer
+ * Initializes the object and context buffers for a control Queue Pair.
+static enum i40iw_status_code i40iw_sc_cqp_init(struct i40iw_sc_cqp *cqp,
+ struct i40iw_cqp_init_info *info)
+ u8 hw_sq_size;
+ if ((info->sq_size > I40IW_CQP_SW_SQSIZE_2048) ||
+ (info->sq_size < I40IW_CQP_SW_SQSIZE_4) ||
+ ((info->sq_size & (info->sq_size - 1))))
+ hw_sq_size = i40iw_get_encoded_wqe_size(info->sq_size, true);
+ cqp->size = sizeof(*cqp);
+ cqp->sq_size = info->sq_size;
+ cqp->hw_sq_size = hw_sq_size;
+ cqp->sq_base = info->sq;
+ cqp->host_ctx = info->host_ctx;
+ cqp->sq_pa = info->sq_pa;
+ cqp->host_ctx_pa = info->host_ctx_pa;
+ cqp->dev = info->dev;
+ cqp->struct_ver = info->struct_ver;
+ cqp->scratch_array = info->scratch_array;
+ cqp->polarity = 0;
+ cqp->en_datacenter_tcp = info->en_datacenter_tcp;
+ cqp->enabled_vf_count = info->enabled_vf_count;
+ cqp->hmc_profile = info->hmc_profile;
+ info->dev->cqp = cqp;
+ I40IW_RING_INIT(cqp->sq_ring, cqp->sq_size);
+ i40iw_debug(cqp->dev, I40IW_DEBUG_WQE,
+ "%s: sq_size[%04d] hw_sq_size[%04d] sq_base[%p] sq_pa[%llxh] cqp[%p] polarity[x%04X]\n",
+ __func__, cqp->sq_size, cqp->hw_sq_size,
+ cqp->sq_base, cqp->sq_pa, cqp, cqp->polarity);
+ return 0;
+ * i40iw_sc_cqp_create - create cqp during bringup
+ * @disable_pfpdus: if pfpdu to be disabled
+ * @maj_err: If error, major err number
+ * @min_err: If error, minor err number
+static enum i40iw_status_code i40iw_sc_cqp_create(struct i40iw_sc_cqp *cqp,
+ bool disable_pfpdus,
+ u16 *maj_err,
+ u16 *min_err)
+ u64 temp;
+ u32 cnt = 0, p1, p2, val = 0, err_code;
+ enum i40iw_status_code ret_code;
+ ret_code = i40iw_allocate_dma_mem(cqp->dev->hw,
+ &cqp->sdbuf,
+ 128,
+ I40IW_SD_BUF_ALIGNMENT);
+ if (ret_code)
+ goto exit;
+ temp = LS_64(cqp->hw_sq_size, I40IW_CQPHC_SQSIZE) |
+ LS_64(cqp->struct_ver, I40IW_CQPHC_SVER);
+ if (disable_pfpdus)
+ temp |= LS_64(1, I40IW_CQPHC_DISABLE_PFPDUS);
+ set_64bit_val(cqp->host_ctx, 0, temp);
+ set_64bit_val(cqp->host_ctx, 8, cqp->sq_pa);
+ temp = LS_64(cqp->enabled_vf_count, I40IW_CQPHC_ENABLED_VFS) |
+ LS_64(cqp->hmc_profile, I40IW_CQPHC_HMC_PROFILE);
+ set_64bit_val(cqp->host_ctx, 16, temp);
+ set_64bit_val(cqp->host_ctx, 24, (uintptr_t)cqp);
+ set_64bit_val(cqp->host_ctx, 32, 0);
+ set_64bit_val(cqp->host_ctx, 40, 0);
+ set_64bit_val(cqp->host_ctx, 48, 0);
+ set_64bit_val(cqp->host_ctx, 56, 0);
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CQP_HOST_CTX",
+ cqp->host_ctx, I40IW_CQP_CTX_SIZE * 8);
+ p1 = RS_32_1(cqp->host_ctx_pa, 32);
+ p2 = (u32)cqp->host_ctx_pa;
+ i40iw_wr32(cqp->dev->hw, I40E_PFPE_CCQPHIGH, p1);
+ i40iw_wr32(cqp->dev->hw, I40E_PFPE_CCQPLOW, p2);
+ } else {
+ i40iw_wr32(cqp->dev->hw, I40E_VFPE_CCQPHIGH1, p1);
+ i40iw_wr32(cqp->dev->hw, I40E_VFPE_CCQPLOW1, p2);
+ do {
+ if (cnt++ > I40IW_DONE_COUNT) {
+ i40iw_free_dma_mem(cqp->dev->hw, &cqp->sdbuf);
+ ret_code = I40IW_ERR_TIMEOUT;
+ * read PFPE_CQPERRORCODES register to get the minor
+ * and major error code
+ err_code = i40iw_rd32(cqp->dev->hw, I40E_PFPE_CQPERRCODES);
+ else
+ err_code = i40iw_rd32(cqp->dev->hw, I40E_VFPE_CQPERRCODES1);
+ *min_err = RS_32(err_code, I40E_PFPE_CQPERRCODES_CQP_MINOR_CODE);
+ *maj_err = RS_32(err_code, I40E_PFPE_CQPERRCODES_CQP_MAJOR_CODE);
+ goto exit;
+ val = i40iw_rd32(cqp->dev->hw, I40E_PFPE_CCQPSTATUS);
+ else
+ val = i40iw_rd32(cqp->dev->hw, I40E_VFPE_CCQPSTATUS1);
+ } while (!val);
+exit:
+ if (!ret_code)
+ cqp->process_cqp_sds = i40iw_update_sds_noccq;
+ return ret_code;
+ * i40iw_sc_cqp_post_sq - post of cqp's sq
+void i40iw_sc_cqp_post_sq(struct i40iw_sc_cqp *cqp)
+ i40iw_wr32(cqp->dev->hw, I40E_PFPE_CQPDB, I40IW_RING_GETCURRENT_HEAD(cqp->sq_ring));
+ else
+ i40iw_wr32(cqp->dev->hw, I40E_VFPE_CQPDB1, I40IW_RING_GETCURRENT_HEAD(cqp->sq_ring));
+ I40IW_DEBUG_WQE,
+ "%s: HEAD_TAIL[%04d,%04d,%04d]\n",
+ __func__,
+ cqp->sq_ring.head,
+ cqp->sq_ring.tail,
+ cqp->sq_ring.size);
+ * i40iw_sc_cqp_get_next_send_wqe - get next wqe on cqp sq
+ * @wqe_idx: we index of cqp ring
+u64 *i40iw_sc_cqp_get_next_send_wqe(struct i40iw_sc_cqp *cqp, u64 scratch)
+ u64 *wqe = NULL;
+ u32 wqe_idx;
+ if (I40IW_RING_FULL_ERR(cqp->sq_ring)) {
+ I40IW_DEBUG_WQE,
+ "%s: ring is full head %x tail %x size %x\n",
+ __func__,
+ return NULL;
+ I40IW_ATOMIC_RING_MOVE_HEAD(cqp->sq_ring, wqe_idx, ret_code);
+ if (ret_code)
+ return NULL;
+ if (!wqe_idx)
+ cqp->polarity = !cqp->polarity;
+ wqe = cqp->sq_base[wqe_idx].elem;
+ cqp->scratch_array[wqe_idx] = scratch;
+ I40IW_CQP_INIT_WQE(wqe);
+ return wqe;
+ * i40iw_sc_cqp_destroy - destroy cqp during close
+static enum i40iw_status_code i40iw_sc_cqp_destroy(struct i40iw_sc_cqp *cqp)
+ u32 cnt = 0, val = 1;
+ enum i40iw_status_code ret_code = 0;
+ u32 cqpstat_addr;
+ i40iw_wr32(cqp->dev->hw, I40E_PFPE_CCQPHIGH, 0);
+ i40iw_wr32(cqp->dev->hw, I40E_PFPE_CCQPLOW, 0);
+ cqpstat_addr = I40E_PFPE_CCQPSTATUS;
+ } else {
+ i40iw_wr32(cqp->dev->hw, I40E_VFPE_CCQPHIGH1, 0);
+ i40iw_wr32(cqp->dev->hw, I40E_VFPE_CCQPLOW1, 0);
+ cqpstat_addr = I40E_VFPE_CCQPSTATUS1;
+ do {
+ break;
+ val = i40iw_rd32(cqp->dev->hw, cqpstat_addr);
+ } while (val);
+ return ret_code;
+ * i40iw_sc_ccq_arm - enable intr for control cq
+ * @ccq: ccq sc struct
+static void i40iw_sc_ccq_arm(struct i40iw_sc_cq *ccq)
+ u64 temp_val;
+ u16 sw_cq_sel;
+ u8 arm_next_se;
+ u8 arm_seq_num;
+ /* write to cq doorbell shadow area */
+ /* arm next se should always be zero */
+ get_64bit_val(ccq->cq_uk.shadow_area, 32, &temp_val);
+ sw_cq_sel = (u16)RS_64(temp_val, I40IW_CQ_DBSA_SW_CQ_SELECT);
+ arm_next_se = (u8)RS_64(temp_val, I40IW_CQ_DBSA_ARM_NEXT_SE);
+ arm_seq_num = (u8)RS_64(temp_val, I40IW_CQ_DBSA_ARM_SEQ_NUM);
+ arm_seq_num++;
+ temp_val = LS_64(arm_seq_num, I40IW_CQ_DBSA_ARM_SEQ_NUM) |
+ LS_64(sw_cq_sel, I40IW_CQ_DBSA_SW_CQ_SELECT) |
+ LS_64(arm_next_se, I40IW_CQ_DBSA_ARM_NEXT_SE) |
+ LS_64(1, I40IW_CQ_DBSA_ARM_NEXT);
+ set_64bit_val(ccq->cq_uk.shadow_area, 32, temp_val);
+ wmb(); /* make sure shadow area is updated before arming */
+ if (ccq->dev->is_pf)
+ i40iw_wr32(ccq->dev->hw, I40E_PFPE_CQARM, ccq->cq_uk.cq_id);
+ else
+ i40iw_wr32(ccq->dev->hw, I40E_VFPE_CQARM1, ccq->cq_uk.cq_id);
+ * i40iw_sc_ccq_get_cqe_info - get ccq's cq entry
+ * @info: completion q entry to return
+static enum i40iw_status_code i40iw_sc_ccq_get_cqe_info(
+ struct i40iw_sc_cq *ccq,
+ struct i40iw_ccq_cqe_info *info)
+ u64 qp_ctx, temp, temp1;
+ u64 *cqe;
+ struct i40iw_sc_cqp *cqp;
+ u32 wqe_idx;
+ u8 polarity;
+ if (ccq->cq_uk.avoid_mem_cflct)
+ cqe = (u64 *)I40IW_GET_CURRENT_EXTENDED_CQ_ELEMENT(&ccq->cq_uk);
+ else
+ cqe = (u64 *)I40IW_GET_CURRENT_CQ_ELEMENT(&ccq->cq_uk);
+ get_64bit_val(cqe, 24, &temp);
+ polarity = (u8)RS_64(temp, I40IW_CQ_VALID);
+ if (polarity != ccq->cq_uk.polarity)
+ return I40IW_ERR_QUEUE_EMPTY;
+ get_64bit_val(cqe, 8, &qp_ctx);
+ cqp = (struct i40iw_sc_cqp *)(unsigned long)qp_ctx;
+ info->error = (bool)RS_64(temp, I40IW_CQ_ERROR);
+ info->min_err_code = (u16)RS_64(temp, I40IW_CQ_MINERR);
+ if (info->error) {
+ info->maj_err_code = (u16)RS_64(temp, I40IW_CQ_MAJERR);
+ wqe_idx = (u32)RS_64(temp, I40IW_CQ_WQEIDX);
+ info->scratch = cqp->scratch_array[wqe_idx];
+ get_64bit_val(cqe, 16, &temp1);
+ info->op_ret_val = (u32)RS_64(temp1, I40IW_CCQ_OPRETVAL);
+ get_64bit_val(cqp->sq_base[wqe_idx].elem, 24, &temp1);
+ info->op_code = (u8)RS_64(temp1, I40IW_CQPSQ_OPCODE);
+ info->cqp = cqp;
+ /* move the head for cq */
+ I40IW_RING_MOVE_HEAD(ccq->cq_uk.cq_ring, ret_code);
+ if (I40IW_RING_GETCURRENT_HEAD(ccq->cq_uk.cq_ring) == 0)
+ ccq->cq_uk.polarity ^= 1;
+ /* update cq tail in cq shadow memory also */
+ I40IW_RING_MOVE_TAIL(ccq->cq_uk.cq_ring);
+ 0,
+ I40IW_RING_GETCURRENT_HEAD(ccq->cq_uk.cq_ring));
+ wmb(); /* write shadow area before tail */
+ return ret_code;
+ * i40iw_sc_poll_for_cqp_op_done - Waits for last write to complete in CQP SQ
+ * @op_code: cqp opcode for completion
+static enum i40iw_status_code i40iw_sc_poll_for_cqp_op_done(
+ u8 op_code,
+ struct i40iw_ccq_cqe_info *compl_info)
+ struct i40iw_ccq_cqe_info info;
+ struct i40iw_sc_cq *ccq;
+ u32 cnt = 0;
+ memset(&info, 0, sizeof(info));
+ ccq = cqp->dev->ccq;
+ while (1) {
+ if (i40iw_sc_ccq_get_cqe_info(ccq, &info)) {
+ continue;
+ if (info.error) {
+ ret_code = I40IW_ERR_CQP_COMPL_ERROR;
+ break;
+ /* check if opcode is cq create */
+ if (op_code != info.op_code) {
+ "%s: opcode mismatch for my op code 0x%x, returned opcode %x\n",
+ __func__, op_code, info.op_code);
+ /* success, exit out of the loop */
+ if (op_code == info.op_code)
+ break;
+ if (compl_info)
+ memcpy(compl_info, &info, sizeof(*compl_info));
+ return ret_code;
+ * i40iw_sc_manage_push_page - Handle push page
+ * @info: push page info
+ * @scratch: u64 saved to be used during cqp completion
+ * @post_sq: flag for cqp db to ring
+static enum i40iw_status_code i40iw_sc_manage_push_page(
+ struct i40iw_cqp_manage_push_page_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (info->push_idx >= I40IW_MAX_PUSH_PAGE_COUNT)
+ return I40IW_ERR_INVALID_PUSH_PAGE_INDEX;
+ wqe = i40iw_sc_cqp_get_next_send_wqe(cqp, scratch);
+ if (!wqe)
+ return I40IW_ERR_RING_FULL;
+ set_64bit_val(wqe, 16, info->qs_handle);
+ header = LS_64(info->push_idx, I40IW_CQPSQ_MPP_PPIDX) |
+ LS_64(I40IW_CQP_OP_MANAGE_PUSH_PAGES, I40IW_CQPSQ_OPCODE) |
+ LS_64(cqp->polarity, I40IW_CQPSQ_WQEVALID) |
+ LS_64(info->free_page, I40IW_CQPSQ_MPP_FREE_PAGE);
+ i40iw_insert_wqe_hdr(wqe, header);
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "MANAGE_PUSH_PAGES WQE",
+ wqe, I40IW_CQP_WQE_SIZE * 8);
+ if (post_sq)
+ i40iw_sc_cqp_post_sq(cqp);
+ return 0;
+ * i40iw_sc_manage_hmc_pm_func_table - manage of function table
+ * @vf_index: vf index for cqp
+ * @free_pm_fcn: function number
+static enum i40iw_status_code i40iw_sc_manage_hmc_pm_func_table(
+ u64 scratch,
+ u8 vf_index,
+ bool free_pm_fcn,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (vf_index >= I40IW_MAX_VF_PER_PF)
+ return I40IW_ERR_INVALID_VF_ID;
+ if (!wqe)
+ header = LS_64(vf_index, I40IW_CQPSQ_MHMC_VFIDX) |
+ LS_64(I40IW_CQP_OP_MANAGE_HMC_PM_FUNC_TABLE, I40IW_CQPSQ_OPCODE) |
+ LS_64(free_pm_fcn, I40IW_CQPSQ_MHMC_FREEPMFN) |
+ LS_64(cqp->polarity, I40IW_CQPSQ_WQEVALID);
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "MANAGE_HMC_PM_FUNC_TABLE WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_set_hmc_resource_profile - cqp wqe for hmc profile
+ * @hmc_profile_type: type of profile to set
+ * @vf_num: vf number for profile
+ * @poll_registers: flag to poll register for cqp completion
+static enum i40iw_status_code i40iw_sc_set_hmc_resource_profile(
+ u64 scratch,
+ u8 hmc_profile_type,
+ u8 vf_num, bool post_sq,
+ bool poll_registers)
+ u64 *wqe;
+ u64 header;
+ u32 val, tail, error;
+ if (!wqe)
+ (LS_64(hmc_profile_type, I40IW_CQPSQ_SHMCRP_HMC_PROFILE) |
+ LS_64(vf_num, I40IW_CQPSQ_SHMCRP_VFNUM)));
+ header = LS_64(I40IW_CQP_OP_SET_HMC_RESOURCE_PROFILE, I40IW_CQPSQ_OPCODE) |
+ i40iw_get_cqp_reg_info(cqp, &val, &tail, &error);
+ if (error)
+ if (post_sq) {
+ if (poll_registers)
+ ret_code = i40iw_cqp_poll_registers(cqp, tail, 1000000);
+ else
+ ret_code = i40iw_sc_poll_for_cqp_op_done(cqp,
+ I40IW_CQP_OP_SHMC_PAGES_ALLOCATED,
+ NULL);
+ return ret_code;
+ * i40iw_sc_manage_hmc_pm_func_table_done - wait for cqp wqe completion for function table
+static enum i40iw_status_code i40iw_sc_manage_hmc_pm_func_table_done(struct i40iw_sc_cqp *cqp)
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_MANAGE_HMC_PM_FUNC_TABLE, NULL);
+ * i40iw_sc_commit_fpm_values_done - wait for cqp eqe completion for fpm commit
+static enum i40iw_status_code i40iw_sc_commit_fpm_values_done(struct i40iw_sc_cqp *cqp)
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_COMMIT_FPM_VALUES, NULL);
+ * i40iw_sc_commit_fpm_values - cqp wqe for commit fpm values
+ * @hmc_fn_id: hmc function id
+ * @commit_fpm_mem; Memory for fpm values
+ * @wait_type: poll ccq or cqp registers for cqp completion
+static enum i40iw_status_code i40iw_sc_commit_fpm_values(
+ u64 scratch,
+ u8 hmc_fn_id,
+ struct i40iw_dma_mem *commit_fpm_mem,
+ bool post_sq,
+ u8 wait_type)
+ u64 *wqe;
+ u64 header;
+ u32 tail, val, error;
+ if (!wqe)
+ set_64bit_val(wqe, 16, hmc_fn_id);
+ set_64bit_val(wqe, 32, commit_fpm_mem->pa);
+ header = LS_64(I40IW_CQP_OP_COMMIT_FPM_VALUES, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "COMMIT_FPM_VALUES WQE",
+ if (error)
+ if (post_sq) {
+ if (wait_type == I40IW_CQP_WAIT_POLL_REGS)
+ ret_code = i40iw_cqp_poll_registers(cqp, tail, I40IW_DONE_COUNT);
+ else if (wait_type == I40IW_CQP_WAIT_POLL_CQ)
+ ret_code = i40iw_sc_commit_fpm_values_done(cqp);
+ return ret_code;
+ * i40iw_sc_query_fpm_values_done - poll for cqp wqe completion for query fpm
+static enum i40iw_status_code i40iw_sc_query_fpm_values_done(struct i40iw_sc_cqp *cqp)
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_QUERY_FPM_VALUES, NULL);
+ * i40iw_sc_query_fpm_values - cqp wqe query fpm values
+ * @query_fpm_mem: memory for return fpm values
+static enum i40iw_status_code i40iw_sc_query_fpm_values(
+ u64 scratch,
+ u8 hmc_fn_id,
+ struct i40iw_dma_mem *query_fpm_mem,
+ bool post_sq,
+ u8 wait_type)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ set_64bit_val(wqe, 32, query_fpm_mem->pa);
+ header = LS_64(I40IW_CQP_OP_QUERY_FPM_VALUES, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "QUERY_FPM WQE",
+ /* read the tail from CQP_TAIL register */
+ if (error)
+ if (post_sq) {
+ ret_code = i40iw_sc_query_fpm_values_done(cqp);
+ return ret_code;
+ * i40iw_sc_add_arp_cache_entry - cqp wqe add arp cache entry
+ * @info: arp entry information
+static enum i40iw_status_code i40iw_sc_add_arp_cache_entry(
+ struct i40iw_add_arp_cache_entry_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 temp, header;
+ if (!wqe)
+ set_64bit_val(wqe, 8, info->reach_max);
+ temp = info->mac_addr[5] |
+ LS_64_1(info->mac_addr[4], 8) |
+ LS_64_1(info->mac_addr[3], 16) |
+ LS_64_1(info->mac_addr[2], 24) |
+ LS_64_1(info->mac_addr[1], 32) |
+ LS_64_1(info->mac_addr[0], 40);
+ set_64bit_val(wqe, 16, temp);
+ header = info->arp_index |
+ LS_64(I40IW_CQP_OP_MANAGE_ARP, I40IW_CQPSQ_OPCODE) |
+ LS_64((info->permanent ? 1 : 0), I40IW_CQPSQ_MAT_PERMANENT) |
+ LS_64(1, I40IW_CQPSQ_MAT_ENTRYVALID) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "ARP_CACHE_ENTRY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_del_arp_cache_entry - dele arp cache entry
+ * @arp_index: arp index to delete arp entry
+static enum i40iw_status_code i40iw_sc_del_arp_cache_entry(
+ u64 scratch,
+ u16 arp_index,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ header = arp_index |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "ARP_CACHE_DEL_ENTRY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_query_arp_cache_entry - cqp wqe to query arp and arp index
+static enum i40iw_status_code i40iw_sc_query_arp_cache_entry(
+ u64 scratch,
+ u16 arp_index,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ LS_64(1, I40IW_CQPSQ_MAT_QUERY) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "QUERY_ARP_CACHE_ENTRY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_manage_apbvt_entry - for adding and deleting apbvt entries
+ * @info: info for apbvt entry to add or delete
+static enum i40iw_status_code i40iw_sc_manage_apbvt_entry(
+ struct i40iw_apbvt_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ set_64bit_val(wqe, 16, info->port);
+ header = LS_64(I40IW_CQP_OP_MANAGE_APBVT, I40IW_CQPSQ_OPCODE) |
+ LS_64(info->add, I40IW_CQPSQ_MAPT_ADDPORT) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "MANAGE_APBVT WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_manage_qhash_table_entry - manage quad hash entries
+ * @info: info for quad hash to manage
+ * This is called before connection establishment is started. For passive connections, when
+ * listener is created, it will call with entry type of I40IW_QHASH_TYPE_TCP_SYN with local
+ * ip address and tcp port. When SYN is received (passive connections) or
+ * sent (active connections), this routine is called with entry type of
+ * I40IW_QHASH_TYPE_TCP_ESTABLISHED and quad is passed in info.
+ * When iwarp connection is done and its state moves to RTS, the quad hash entry in
+ * the hardware will point to iwarp's qp number and requires no calls from the driver.
+static enum i40iw_status_code i40iw_sc_manage_qhash_table_entry(
+ struct i40iw_qhash_table_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 qw1 = 0;
+ u64 qw2 = 0;
+ u64 temp;
+ if (!wqe)
+ set_64bit_val(wqe, 0, temp);
+ qw1 = LS_64(info->qp_num, I40IW_CQPSQ_QHASH_QPN) |
+ LS_64(info->dest_port, I40IW_CQPSQ_QHASH_DEST_PORT);
+ if (info->ipv4_valid) {
+ 48,
+ LS_64(info->dest_ip[0], I40IW_CQPSQ_QHASH_ADDR3));
+ } else {
+ 56,
+ LS_64(info->dest_ip[0], I40IW_CQPSQ_QHASH_ADDR0) |
+ LS_64(info->dest_ip[1], I40IW_CQPSQ_QHASH_ADDR1));
+ 48,
+ LS_64(info->dest_ip[2], I40IW_CQPSQ_QHASH_ADDR2) |
+ LS_64(info->dest_ip[3], I40IW_CQPSQ_QHASH_ADDR3));
+ qw2 = LS_64(cqp->dev->qs_handle, I40IW_CQPSQ_QHASH_QS_HANDLE);
+ if (info->vlan_valid)
+ qw2 |= LS_64(info->vlan_id, I40IW_CQPSQ_QHASH_VLANID);
+ set_64bit_val(wqe, 16, qw2);
+ if (info->entry_type == I40IW_QHASH_TYPE_TCP_ESTABLISHED) {
+ qw1 |= LS_64(info->src_port, I40IW_CQPSQ_QHASH_SRC_PORT);
+ if (!info->ipv4_valid) {
+ 40,
+ LS_64(info->src_ip[0], I40IW_CQPSQ_QHASH_ADDR0) |
+ LS_64(info->src_ip[1], I40IW_CQPSQ_QHASH_ADDR1));
+ 32,
+ LS_64(info->src_ip[2], I40IW_CQPSQ_QHASH_ADDR2) |
+ LS_64(info->src_ip[3], I40IW_CQPSQ_QHASH_ADDR3));
+ } else {
+ 32,
+ LS_64(info->src_ip[0], I40IW_CQPSQ_QHASH_ADDR3));
+ set_64bit_val(wqe, 8, qw1);
+ temp = LS_64(cqp->polarity, I40IW_CQPSQ_QHASH_WQEVALID) |
+ LS_64(I40IW_CQP_OP_MANAGE_QUAD_HASH_TABLE_ENTRY, I40IW_CQPSQ_QHASH_OPCODE) |
+ LS_64(info->manage, I40IW_CQPSQ_QHASH_MANAGE) |
+ LS_64(info->ipv4_valid, I40IW_CQPSQ_QHASH_IPV4VALID) |
+ LS_64(info->vlan_valid, I40IW_CQPSQ_QHASH_VLANVALID) |
+ LS_64(info->entry_type, I40IW_CQPSQ_QHASH_ENTRYTYPE);
+ i40iw_insert_wqe_hdr(wqe, temp);
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "MANAGE_QHASH WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_alloc_local_mac_ipaddr_entry - cqp wqe for loc mac entry
+static enum i40iw_status_code i40iw_sc_alloc_local_mac_ipaddr_entry(
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ header = LS_64(I40IW_CQP_OP_ALLOCATE_LOC_MAC_IP_TABLE_ENTRY, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "ALLOCATE_LOCAL_MAC_IPADDR WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_add_local_mac_ipaddr_entry - add mac enry
+ * @info:mac addr info
+static enum i40iw_status_code i40iw_sc_add_local_mac_ipaddr_entry(
+ struct i40iw_local_mac_ipaddr_entry_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 temp, header;
+ if (!wqe)
+ set_64bit_val(wqe, 32, temp);
+ header = LS_64(info->entry_idx, I40IW_CQPSQ_MLIPA_IPTABLEIDX) |
+ LS_64(I40IW_CQP_OP_MANAGE_LOC_MAC_IP_TABLE, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "ADD_LOCAL_MAC_IPADDR WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_del_local_mac_ipaddr_entry - cqp wqe to dele local mac
+ * @entry_idx: index of mac entry
+ * @ ignore_ref_count: to force mac adde delete
+static enum i40iw_status_code i40iw_sc_del_local_mac_ipaddr_entry(
+ u64 scratch,
+ u8 entry_idx,
+ u8 ignore_ref_count,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ header = LS_64(entry_idx, I40IW_CQPSQ_MLIPA_IPTABLEIDX) |
+ LS_64(1, I40IW_CQPSQ_MLIPA_FREEENTRY) |
+ LS_64(ignore_ref_count, I40IW_CQPSQ_MLIPA_IGNORE_REF_CNT);
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "DEL_LOCAL_MAC_IPADDR WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_cqp_nop - send a nop wqe
+static enum i40iw_status_code i40iw_sc_cqp_nop(struct i40iw_sc_cqp *cqp,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ header = LS_64(I40IW_CQP_OP_NOP, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "NOP WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_ceq_init - initialize ceq
+ * @ceq: ceq sc structure
+ * @info: ceq initialization info
+static enum i40iw_status_code i40iw_sc_ceq_init(struct i40iw_sc_ceq *ceq,
+ struct i40iw_ceq_init_info *info)
+ u32 pble_obj_cnt;
+ if ((info->elem_cnt < I40IW_MIN_CEQ_ENTRIES) ||
+ (info->elem_cnt > I40IW_MAX_CEQ_ENTRIES))
+ if (info->ceq_id >= I40IW_MAX_CEQID)
+ return I40IW_ERR_INVALID_CEQ_ID;
+ pble_obj_cnt = info->dev->hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].cnt;
+ if (info->virtual_map && (info->first_pm_pbl_idx >= pble_obj_cnt))
+ return I40IW_ERR_INVALID_PBLE_INDEX;
+ ceq->size = sizeof(*ceq);
+ ceq->ceqe_base = (struct i40iw_ceqe *)info->ceqe_base;
+ ceq->ceq_id = info->ceq_id;
+ ceq->dev = info->dev;
+ ceq->elem_cnt = info->elem_cnt;
+ ceq->ceq_elem_pa = info->ceqe_pa;
+ ceq->virtual_map = info->virtual_map;
+ ceq->pbl_chunk_size = (ceq->virtual_map ? info->pbl_chunk_size : 0);
+ ceq->first_pm_pbl_idx = (ceq->virtual_map ? info->first_pm_pbl_idx : 0);
+ ceq->pbl_list = (ceq->virtual_map ? info->pbl_list : NULL);
+ ceq->tph_en = info->tph_en;
+ ceq->tph_val = info->tph_val;
+ ceq->polarity = 1;
+ I40IW_RING_INIT(ceq->ceq_ring, ceq->elem_cnt);
+ ceq->dev->ceq[info->ceq_id] = ceq;
+ return 0;
+ * i40iw_sc_ceq_create - create ceq wqe
+static enum i40iw_status_code i40iw_sc_ceq_create(struct i40iw_sc_ceq *ceq,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ cqp = ceq->dev->cqp;
+ if (!wqe)
+ set_64bit_val(wqe, 16, ceq->elem_cnt);
+ set_64bit_val(wqe, 32, (ceq->virtual_map ? 0 : ceq->ceq_elem_pa));
+ set_64bit_val(wqe, 48, (ceq->virtual_map ? ceq->first_pm_pbl_idx : 0));
+ set_64bit_val(wqe, 56, LS_64(ceq->tph_val, I40IW_CQPSQ_TPHVAL));
+ header = ceq->ceq_id |
+ LS_64(I40IW_CQP_OP_CREATE_CEQ, I40IW_CQPSQ_OPCODE) |
+ LS_64(ceq->pbl_chunk_size, I40IW_CQPSQ_CEQ_LPBLSIZE) |
+ LS_64(ceq->virtual_map, I40IW_CQPSQ_CEQ_VMAP) |
+ LS_64(ceq->tph_en, I40IW_CQPSQ_TPHEN) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CEQ_CREATE WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_cceq_create_done - poll for control ceq wqe to complete
+static enum i40iw_status_code i40iw_sc_cceq_create_done(struct i40iw_sc_ceq *ceq)
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_CREATE_CEQ, NULL);
+ * i40iw_sc_cceq_destroy_done - poll for destroy cceq to complete
+static enum i40iw_status_code i40iw_sc_cceq_destroy_done(struct i40iw_sc_ceq *ceq)
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_DESTROY_CEQ, NULL);
+ * i40iw_sc_cceq_create - create cceq
+static enum i40iw_status_code i40iw_sc_cceq_create(struct i40iw_sc_ceq *ceq, u64 scratch)
+ ret_code = i40iw_sc_ceq_create(ceq, scratch, true);
+ if (!ret_code)
+ ret_code = i40iw_sc_cceq_create_done(ceq);
+ return ret_code;
+ * i40iw_sc_ceq_destroy - destroy ceq
+static enum i40iw_status_code i40iw_sc_ceq_destroy(struct i40iw_sc_ceq *ceq,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ set_64bit_val(wqe, 48, ceq->first_pm_pbl_idx);
+ LS_64(I40IW_CQP_OP_DESTROY_CEQ, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CEQ_DESTROY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_process_ceq - process ceq
+static void *i40iw_sc_process_ceq(struct i40iw_sc_dev *dev, struct i40iw_sc_ceq *ceq)
+ u64 temp;
+ u64 *ceqe;
+ struct i40iw_sc_cq *cq = NULL;
+ u8 polarity;
+ ceqe = (u64 *)I40IW_GET_CURRENT_CEQ_ELEMENT(ceq);
+ get_64bit_val(ceqe, 0, &temp);
+ polarity = (u8)RS_64(temp, I40IW_CEQE_VALID);
+ if (polarity != ceq->polarity)
+ return cq;
+ cq = (struct i40iw_sc_cq *)(unsigned long)LS_64_1(temp, 1);
+ I40IW_RING_MOVE_TAIL(ceq->ceq_ring);
+ if (I40IW_RING_GETCURRENT_TAIL(ceq->ceq_ring) == 0)
+ ceq->polarity ^= 1;
+ if (dev->is_pf)
+ i40iw_wr32(dev->hw, I40E_PFPE_CQACK, cq->cq_uk.cq_id);
+ else
+ i40iw_wr32(dev->hw, I40E_VFPE_CQACK1, cq->cq_uk.cq_id);
+ return cq;
+ * i40iw_sc_aeq_init - initialize aeq
+ * @aeq: aeq structure ptr
+ * @info: aeq initialization info
+static enum i40iw_status_code i40iw_sc_aeq_init(struct i40iw_sc_aeq *aeq,
+ struct i40iw_aeq_init_info *info)
+ u32 pble_obj_cnt;
+ if ((info->elem_cnt < I40IW_MIN_AEQ_ENTRIES) ||
+ (info->elem_cnt > I40IW_MAX_AEQ_ENTRIES))
+ aeq->size = sizeof(*aeq);
+ aeq->polarity = 1;
+ aeq->aeqe_base = (struct i40iw_sc_aeqe *)info->aeqe_base;
+ aeq->dev = info->dev;
+ aeq->elem_cnt = info->elem_cnt;
+ aeq->aeq_elem_pa = info->aeq_elem_pa;
+ I40IW_RING_INIT(aeq->aeq_ring, aeq->elem_cnt);
+ info->dev->aeq = aeq;
+ aeq->virtual_map = info->virtual_map;
+ aeq->pbl_list = (aeq->virtual_map ? info->pbl_list : NULL);
+ aeq->pbl_chunk_size = (aeq->virtual_map ? info->pbl_chunk_size : 0);
+ aeq->first_pm_pbl_idx = (aeq->virtual_map ? info->first_pm_pbl_idx : 0);
+ return 0;
+ * i40iw_sc_aeq_create - create aeq
+static enum i40iw_status_code i40iw_sc_aeq_create(struct i40iw_sc_aeq *aeq,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ cqp = aeq->dev->cqp;
+ if (!wqe)
+ set_64bit_val(wqe, 16, aeq->elem_cnt);
+ (aeq->virtual_map ? 0 : aeq->aeq_elem_pa));
+ (aeq->virtual_map ? aeq->first_pm_pbl_idx : 0));
+ header = LS_64(I40IW_CQP_OP_CREATE_AEQ, I40IW_CQPSQ_OPCODE) |
+ LS_64(aeq->pbl_chunk_size, I40IW_CQPSQ_AEQ_LPBLSIZE) |
+ LS_64(aeq->virtual_map, I40IW_CQPSQ_AEQ_VMAP) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "AEQ_CREATE WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_aeq_destroy - destroy aeq during close
+static enum i40iw_status_code i40iw_sc_aeq_destroy(struct i40iw_sc_aeq *aeq,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ set_64bit_val(wqe, 48, aeq->first_pm_pbl_idx);
+ header = LS_64(I40IW_CQP_OP_DESTROY_AEQ, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "AEQ_DESTROY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_get_next_aeqe - get next aeq entry
+ * @info: aeqe info to be returned
+static enum i40iw_status_code i40iw_sc_get_next_aeqe(struct i40iw_sc_aeq *aeq,
+ struct i40iw_aeqe_info *info)
+ u64 temp, compl_ctx;
+ u64 *aeqe;
+ u16 wqe_idx;
+ u8 ae_src;
+ u8 polarity;
+ aeqe = (u64 *)I40IW_GET_CURRENT_AEQ_ELEMENT(aeq);
+ get_64bit_val(aeqe, 0, &compl_ctx);
+ get_64bit_val(aeqe, 8, &temp);
+ polarity = (u8)RS_64(temp, I40IW_AEQE_VALID);
+ if (aeq->polarity != polarity)
+ i40iw_debug_buf(aeq->dev, I40IW_DEBUG_WQE, "AEQ_ENTRY", aeqe, 16);
+ ae_src = (u8)RS_64(temp, I40IW_AEQE_AESRC);
+ wqe_idx = (u16)RS_64(temp, I40IW_AEQE_WQDESCIDX);
+ info->qp_cq_id = (u32)RS_64(temp, I40IW_AEQE_QPCQID);
+ info->ae_id = (u16)RS_64(temp, I40IW_AEQE_AECODE);
+ info->tcp_state = (u8)RS_64(temp, I40IW_AEQE_TCPSTATE);
+ info->iwarp_state = (u8)RS_64(temp, I40IW_AEQE_IWSTATE);
+ info->q2_data_written = (u8)RS_64(temp, I40IW_AEQE_Q2DATA);
+ info->aeqe_overflow = (bool)RS_64(temp, I40IW_AEQE_OVERFLOW);
+ switch (ae_src) {
+ case I40IW_AE_SOURCE_RQ:
+ case I40IW_AE_SOURCE_RQ_0011:
+ info->qp = true;
+ info->wqe_idx = wqe_idx;
+ info->compl_ctx = compl_ctx;
+ break;
+ case I40IW_AE_SOURCE_CQ:
+ case I40IW_AE_SOURCE_CQ_0110:
+ case I40IW_AE_SOURCE_CQ_1010:
+ case I40IW_AE_SOURCE_CQ_1110:
+ info->cq = true;
+ info->compl_ctx = LS_64_1(compl_ctx, 1);
+ break;
+ case I40IW_AE_SOURCE_SQ:
+ case I40IW_AE_SOURCE_SQ_0111:
+ info->qp = true;
+ info->sq = true;
+ break;
+ case I40IW_AE_SOURCE_IN_RR_WR:
+ case I40IW_AE_SOURCE_IN_RR_WR_1011:
+ info->qp = true;
+ info->in_rdrsp_wr = true;
+ break;
+ case I40IW_AE_SOURCE_OUT_RR:
+ case I40IW_AE_SOURCE_OUT_RR_1111:
+ info->qp = true;
+ info->out_rdrsp = true;
+ break;
+ default:
+ break;
+ I40IW_RING_MOVE_TAIL(aeq->aeq_ring);
+ if (I40IW_RING_GETCURRENT_TAIL(aeq->aeq_ring) == 0)
+ aeq->polarity ^= 1;
+ return 0;
+ * i40iw_sc_repost_aeq_entries - repost completed aeq entries
+ * @count: allocate count
+static enum i40iw_status_code i40iw_sc_repost_aeq_entries(struct i40iw_sc_dev *dev,
+ u32 count)
+ if (count > I40IW_MAX_AEQ_ALLOCATE_COUNT)
+ if (dev->is_pf)
+ i40iw_wr32(dev->hw, I40E_PFPE_AEQALLOC, count);
+ else
+ i40iw_wr32(dev->hw, I40E_VFPE_AEQALLOC1, count);
+ return 0;
+ * i40iw_sc_aeq_create_done - create aeq
+static enum i40iw_status_code i40iw_sc_aeq_create_done(struct i40iw_sc_aeq *aeq)
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_CREATE_AEQ, NULL);
+ * i40iw_sc_aeq_destroy_done - destroy of aeq during close
+static enum i40iw_status_code i40iw_sc_aeq_destroy_done(struct i40iw_sc_aeq *aeq)
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_DESTROY_AEQ, NULL);
+ * i40iw_sc_ccq_init - initialize control cq
+ * @cq: sc's cq ctruct
+ * @info: info for control cq initialization
+static enum i40iw_status_code i40iw_sc_ccq_init(struct i40iw_sc_cq *cq,
+ struct i40iw_ccq_init_info *info)
+ u32 pble_obj_cnt;
+ if (info->num_elem < I40IW_MIN_CQ_SIZE || info->num_elem > I40IW_MAX_CQ_SIZE)
+ if (info->ceq_id > I40IW_MAX_CEQID)
+ cq->cq_pa = info->cq_pa;
+ cq->cq_uk.cq_base = info->cq_base;
+ cq->shadow_area_pa = info->shadow_area_pa;
+ cq->cq_uk.shadow_area = info->shadow_area;
+ cq->shadow_read_threshold = info->shadow_read_threshold;
+ cq->dev = info->dev;
+ cq->ceq_id = info->ceq_id;
+ cq->cq_uk.cq_size = info->num_elem;
+ cq->cq_type = I40IW_CQ_TYPE_CQP;
+ cq->ceqe_mask = info->ceqe_mask;
+ I40IW_RING_INIT(cq->cq_uk.cq_ring, info->num_elem);
+ cq->cq_uk.cq_id = 0; /* control cq is id 0 always */
+ cq->ceq_id_valid = info->ceq_id_valid;
+ cq->tph_en = info->tph_en;
+ cq->tph_val = info->tph_val;
+ cq->cq_uk.avoid_mem_cflct = info->avoid_mem_cflct;
+ cq->pbl_list = info->pbl_list;
+ cq->virtual_map = info->virtual_map;
+ cq->pbl_chunk_size = info->pbl_chunk_size;
+ cq->first_pm_pbl_idx = info->first_pm_pbl_idx;
+ cq->cq_uk.polarity = true;
+ /* following are only for iw cqs so initialize them to zero */
+ cq->cq_uk.cqe_alloc_reg = NULL;
+ info->dev->ccq = cq;
+ return 0;
+ * i40iw_sc_ccq_create_done - poll cqp for ccq create
+static enum i40iw_status_code i40iw_sc_ccq_create_done(struct i40iw_sc_cq *ccq)
+ cqp = ccq->dev->cqp;
+ return i40iw_sc_poll_for_cqp_op_done(cqp, I40IW_CQP_OP_CREATE_CQ, NULL);
+ * i40iw_sc_ccq_create - create control cq
+ * @check_overflow: overlow flag for ccq
+static enum i40iw_status_code i40iw_sc_ccq_create(struct i40iw_sc_cq *ccq,
+ u64 scratch,
+ bool check_overflow,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ set_64bit_val(wqe, 0, ccq->cq_uk.cq_size);
+ set_64bit_val(wqe, 8, RS_64_1(ccq, 1));
+ LS_64(ccq->shadow_read_threshold, I40IW_CQPSQ_CQ_SHADOW_READ_THRESHOLD));
+ set_64bit_val(wqe, 32, (ccq->virtual_map ? 0 : ccq->cq_pa));
+ set_64bit_val(wqe, 40, ccq->shadow_area_pa);
+ (ccq->virtual_map ? ccq->first_pm_pbl_idx : 0));
+ LS_64(ccq->tph_val, I40IW_CQPSQ_TPHVAL));
+ header = ccq->cq_uk.cq_id |
+ LS_64((ccq->ceq_id_valid ? ccq->ceq_id : 0), I40IW_CQPSQ_CQ_CEQID) |
+ LS_64(I40IW_CQP_OP_CREATE_CQ, I40IW_CQPSQ_OPCODE) |
+ LS_64(ccq->pbl_chunk_size, I40IW_CQPSQ_CQ_LPBLSIZE) |
+ LS_64(check_overflow, I40IW_CQPSQ_CQ_CHKOVERFLOW) |
+ LS_64(ccq->virtual_map, I40IW_CQPSQ_CQ_VIRTMAP) |
+ LS_64(ccq->ceqe_mask, I40IW_CQPSQ_CQ_ENCEQEMASK) |
+ LS_64(ccq->ceq_id_valid, I40IW_CQPSQ_CQ_CEQIDVALID) |
+ LS_64(ccq->tph_en, I40IW_CQPSQ_TPHEN) |
+ LS_64(ccq->cq_uk.avoid_mem_cflct, I40IW_CQPSQ_CQ_AVOIDMEMCNFLCT) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CCQ_CREATE WQE",
+ if (post_sq) {
+ ret_code = i40iw_sc_ccq_create_done(ccq);
+ if (ret_code)
+ return ret_code;
+ cqp->process_cqp_sds = i40iw_cqp_sds_cmd;
+ return 0;
+ * i40iw_sc_ccq_destroy - destroy ccq during close
+static enum i40iw_status_code i40iw_sc_ccq_destroy(struct i40iw_sc_cq *ccq,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ LS_64(I40IW_CQP_OP_DESTROY_CQ, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CCQ_DESTROY WQE",
+ if (error)
+ if (post_sq) {
+ ret_code = i40iw_cqp_poll_registers(cqp, tail, 1000);
+ return ret_code;
+ * i40iw_sc_cq_init - initialize completion q
+ * @cq: cq struct
+ * @info: cq initialization info
+static enum i40iw_status_code i40iw_sc_cq_init(struct i40iw_sc_cq *cq,
+ struct i40iw_cq_init_info *info)
+ u32 __iomem *cqe_alloc_reg = NULL;
+ u32 pble_obj_cnt;
+ u32 arm_offset;
+ cq->cq_pa = info->cq_base_pa;
+ arm_offset = (info->dev->is_pf) ? I40E_PFPE_CQARM : I40E_VFPE_CQARM1;
+ if (i40iw_get_hw_addr(cq->dev))
+ cqe_alloc_reg = (u32 __iomem *)(i40iw_get_hw_addr(cq->dev) +
+ arm_offset);
+ info->cq_uk_init_info.cqe_alloc_reg = cqe_alloc_reg;
+ ret_code = i40iw_cq_uk_init(&cq->cq_uk, &info->cq_uk_init_info);
+ if (ret_code)
+ return ret_code;
+ cq->cq_type = (info->type) ? info->type : I40IW_CQ_TYPE_IWARP;
+ return 0;
+ * i40iw_sc_cq_create - create completion q
+ * @cq: cq struct
+ * @check_overflow: flag for overflow check
+static enum i40iw_status_code i40iw_sc_cq_create(struct i40iw_sc_cq *cq,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (cq->cq_uk.cq_id > I40IW_MAX_CQID)
+ return I40IW_ERR_INVALID_CQ_ID;
+ if (cq->ceq_id > I40IW_MAX_CEQID)
+ cqp = cq->dev->cqp;
+ if (!wqe)
+ set_64bit_val(wqe, 0, cq->cq_uk.cq_size);
+ set_64bit_val(wqe, 8, RS_64_1(cq, 1));
+ 16,
+ LS_64(cq->shadow_read_threshold, I40IW_CQPSQ_CQ_SHADOW_READ_THRESHOLD));
+ set_64bit_val(wqe, 32, (cq->virtual_map ? 0 : cq->cq_pa));
+ set_64bit_val(wqe, 40, cq->shadow_area_pa);
+ set_64bit_val(wqe, 48, (cq->virtual_map ? cq->first_pm_pbl_idx : 0));
+ set_64bit_val(wqe, 56, LS_64(cq->tph_val, I40IW_CQPSQ_TPHVAL));
+ header = cq->cq_uk.cq_id |
+ LS_64((cq->ceq_id_valid ? cq->ceq_id : 0), I40IW_CQPSQ_CQ_CEQID) |
+ LS_64(cq->pbl_chunk_size, I40IW_CQPSQ_CQ_LPBLSIZE) |
+ LS_64(cq->virtual_map, I40IW_CQPSQ_CQ_VIRTMAP) |
+ LS_64(cq->ceqe_mask, I40IW_CQPSQ_CQ_ENCEQEMASK) |
+ LS_64(cq->ceq_id_valid, I40IW_CQPSQ_CQ_CEQIDVALID) |
+ LS_64(cq->tph_en, I40IW_CQPSQ_TPHEN) |
+ LS_64(cq->cq_uk.avoid_mem_cflct, I40IW_CQPSQ_CQ_AVOIDMEMCNFLCT) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CQ_CREATE WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_cq_destroy - destroy completion q
+ * @cq: cq struct
+static enum i40iw_status_code i40iw_sc_cq_destroy(struct i40iw_sc_cq *cq,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CQ_DESTROY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_cq_modify - modify a Completion Queue
+ * @cq: cq struct
+ * @info: modification info struct
+ * @scratch:
+ * @post_sq: flag to post to sq
+static enum i40iw_status_code i40iw_sc_cq_modify(struct i40iw_sc_cq *cq,
+ struct i40iw_modify_cq_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ u32 cq_size, ceq_id, first_pm_pbl_idx;
+ u8 pbl_chunk_size;
+ bool virtual_map, ceq_id_valid, check_overflow;
+ u32 pble_obj_cnt;
+ if (info->ceq_valid && (info->ceq_id > I40IW_MAX_CEQID))
+ pble_obj_cnt = cq->dev->hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].cnt;
+ if (info->cq_resize && info->virtual_map &&
+ (info->first_pm_pbl_idx >= pble_obj_cnt))
+ if (!wqe)
+ cq_size = info->cq_resize ? info->cq_size : cq->cq_uk.cq_size;
+ if (info->ceq_change) {
+ ceq_id_valid = true;
+ ceq_id = info->ceq_id;
+ } else {
+ ceq_id_valid = cq->ceq_id_valid;
+ ceq_id = ceq_id_valid ? cq->ceq_id : 0;
+ virtual_map = info->cq_resize ? info->virtual_map : cq->virtual_map;
+ first_pm_pbl_idx = (info->cq_resize ?
+ (info->virtual_map ? info->first_pm_pbl_idx : 0) :
+ (cq->virtual_map ? cq->first_pm_pbl_idx : 0));
+ pbl_chunk_size = (info->cq_resize ?
+ (info->virtual_map ? info->pbl_chunk_size : 0) :
+ (cq->virtual_map ? cq->pbl_chunk_size : 0));
+ check_overflow = info->check_overflow_change ? info->check_overflow :
+ cq->check_overflow;
+ cq->cq_uk.cq_size = cq_size;
+ cq->ceq_id_valid = ceq_id_valid;
+ cq->ceq_id = ceq_id;
+ cq->virtual_map = virtual_map;
+ cq->first_pm_pbl_idx = first_pm_pbl_idx;
+ cq->pbl_chunk_size = pbl_chunk_size;
+ cq->check_overflow = check_overflow;
+ set_64bit_val(wqe, 0, cq_size);
+ LS_64(info->shadow_read_threshold, I40IW_CQPSQ_CQ_SHADOW_READ_THRESHOLD));
+ set_64bit_val(wqe, 48, (cq->virtual_map ? first_pm_pbl_idx : 0));
+ LS_64(ceq_id, I40IW_CQPSQ_CQ_CEQID) |
+ LS_64(I40IW_CQP_OP_MODIFY_CQ, I40IW_CQPSQ_OPCODE) |
+ LS_64(info->cq_resize, I40IW_CQPSQ_CQ_CQRESIZE) |
+ LS_64(pbl_chunk_size, I40IW_CQPSQ_CQ_LPBLSIZE) |
+ LS_64(virtual_map, I40IW_CQPSQ_CQ_VIRTMAP) |
+ LS_64(ceq_id_valid, I40IW_CQPSQ_CQ_CEQIDVALID) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "CQ_MODIFY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_qp_init - initialize qp
+ * @qp: sc qp
+ * @info: initialization qp info
+static enum i40iw_status_code i40iw_sc_qp_init(struct i40iw_sc_qp *qp,
+ struct i40iw_qp_init_info *info)
+ u32 __iomem *wqe_alloc_reg = NULL;
+ u32 pble_obj_cnt;
+ u8 wqe_size;
+ u32 offset;
+ qp->dev = info->pd->dev;
+ qp->sq_pa = info->sq_pa;
+ qp->rq_pa = info->rq_pa;
+ qp->hw_host_ctx_pa = info->host_ctx_pa;
+ qp->q2_pa = info->q2_pa;
+ qp->shadow_area_pa = info->shadow_area_pa;
+ qp->q2_buf = info->q2;
+ qp->pd = info->pd;
+ qp->hw_host_ctx = info->host_ctx;
+ offset = (qp->pd->dev->is_pf) ? I40E_PFPE_WQEALLOC : I40E_VFPE_WQEALLOC1;
+ if (i40iw_get_hw_addr(qp->pd->dev))
+ wqe_alloc_reg = (u32 __iomem *)(i40iw_get_hw_addr(qp->pd->dev) +
+ offset);
+ info->qp_uk_init_info.wqe_alloc_reg = wqe_alloc_reg;
+ ret_code = i40iw_qp_uk_init(&qp->qp_uk, &info->qp_uk_init_info);
+ if (ret_code)
+ return ret_code;
+ qp->virtual_map = info->virtual_map;
+ pble_obj_cnt = info->pd->dev->hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].cnt;
+ if ((info->virtual_map && (info->sq_pa >= pble_obj_cnt)) ||
+ (info->virtual_map && (info->rq_pa >= pble_obj_cnt)))
+ qp->llp_stream_handle = (void *)(-1);
+ qp->qp_type = (info->type) ? info->type : I40IW_QP_TYPE_IWARP;
+ qp->hw_sq_size = i40iw_get_encoded_wqe_size(qp->qp_uk.sq_ring.size,
+ false);
+ i40iw_debug(qp->dev, I40IW_DEBUG_WQE, "%s: hw_sq_size[%04d] sq_ring.size[%04d]\n",
+ __func__, qp->hw_sq_size, qp->qp_uk.sq_ring.size);
+ ret_code = i40iw_fragcnt_to_wqesize_rq(qp->qp_uk.max_rq_frag_cnt,
+ &wqe_size);
+ if (ret_code)
+ return ret_code;
+ qp->hw_rq_size = i40iw_get_encoded_wqe_size(qp->qp_uk.rq_size *
+ (wqe_size / I40IW_QP_WQE_MIN_SIZE), false);
+ "%s: hw_rq_size[%04d] qp_uk.rq_size[%04d] wqe_size[%04d]\n",
+ __func__, qp->hw_rq_size, qp->qp_uk.rq_size, wqe_size);
+ qp->sq_tph_val = info->sq_tph_val;
+ qp->rq_tph_val = info->rq_tph_val;
+ qp->sq_tph_en = info->sq_tph_en;
+ qp->rq_tph_en = info->rq_tph_en;
+ qp->rcv_tph_en = info->rcv_tph_en;
+ qp->xmit_tph_en = info->xmit_tph_en;
+ qp->qs_handle = qp->pd->dev->qs_handle;
+ qp->exception_lan_queue = qp->pd->dev->exception_lan_queue;
+ return 0;
+ * i40iw_sc_qp_create - create qp
+ * @qp: sc qp
+ * @info: qp create info
+static enum i40iw_status_code i40iw_sc_qp_create(
+ struct i40iw_sc_qp *qp,
+ struct i40iw_create_qp_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if ((qp->qp_uk.qp_id < I40IW_MIN_IW_QP_ID) ||
+ (qp->qp_uk.qp_id > I40IW_MAX_IW_QP_ID))
+ return I40IW_ERR_INVALID_QP_ID;
+ cqp = qp->pd->dev->cqp;
+ if (!wqe)
+ set_64bit_val(wqe, 16, qp->hw_host_ctx_pa);
+ set_64bit_val(wqe, 40, qp->shadow_area_pa);
+ header = qp->qp_uk.qp_id |
+ LS_64(I40IW_CQP_OP_CREATE_QP, I40IW_CQPSQ_OPCODE) |
+ LS_64((info->ord_valid ? 1 : 0), I40IW_CQPSQ_QP_ORDVALID) |
+ LS_64(info->tcp_ctx_valid, I40IW_CQPSQ_QP_TOECTXVALID) |
+ LS_64(qp->qp_type, I40IW_CQPSQ_QP_QPTYPE) |
+ LS_64(qp->virtual_map, I40IW_CQPSQ_QP_VQ) |
+ LS_64(info->cq_num_valid, I40IW_CQPSQ_QP_CQNUMVALID) |
+ LS_64(info->static_rsrc, I40IW_CQPSQ_QP_STATRSRC) |
+ LS_64(info->arp_cache_idx_valid, I40IW_CQPSQ_QP_ARPTABIDXVALID) |
+ LS_64(info->next_iwarp_state, I40IW_CQPSQ_QP_NEXTIWSTATE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "QP_CREATE WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_qp_modify - modify qp cqp wqe
+ * @qp: sc qp
+ * @info: modify qp info
+static enum i40iw_status_code i40iw_sc_qp_modify(
+ struct i40iw_modify_qp_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ u8 term_actions = 0;
+ u8 term_len = 0;
+ if (!wqe)
+ if (info->next_iwarp_state == I40IW_QP_STATE_TERMINATE) {
+ if (info->dont_send_fin)
+ term_actions += I40IWQP_TERM_SEND_TERM_ONLY;
+ if (info->dont_send_term)
+ term_actions += I40IWQP_TERM_SEND_FIN_ONLY;
+ if ((term_actions == I40IWQP_TERM_SEND_TERM_AND_FIN) ||
+ (term_actions == I40IWQP_TERM_SEND_TERM_ONLY))
+ term_len = info->termlen;
+ 8,
+ LS_64(info->new_mss, I40IW_CQPSQ_QP_NEWMSS) |
+ LS_64(term_len, I40IW_CQPSQ_QP_TERMLEN));
+ LS_64(I40IW_CQP_OP_MODIFY_QP, I40IW_CQPSQ_OPCODE) |
+ LS_64(info->ord_valid, I40IW_CQPSQ_QP_ORDVALID) |
+ LS_64(info->cached_var_valid, I40IW_CQPSQ_QP_CACHEDVARVALID) |
+ LS_64(info->force_loopback, I40IW_CQPSQ_QP_FORCELOOPBACK) |
+ LS_64(info->mss_change, I40IW_CQPSQ_QP_MSSCHANGE) |
+ LS_64(info->remove_hash_idx, I40IW_CQPSQ_QP_REMOVEHASHENTRY) |
+ LS_64(term_actions, I40IW_CQPSQ_QP_TERMACT) |
+ LS_64(info->reset_tcp_conn, I40IW_CQPSQ_QP_RESETCON) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "QP_MODIFY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_qp_destroy - cqp destroy qp
+ * @qp: sc qp
+ * @remove_hash_idx: flag if to remove hash idx
+ * @ignore_mw_bnd: memory window bind flag
+static enum i40iw_status_code i40iw_sc_qp_destroy(
+ u64 scratch,
+ bool remove_hash_idx,
+ bool ignore_mw_bnd,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ LS_64(I40IW_CQP_OP_DESTROY_QP, I40IW_CQPSQ_OPCODE) |
+ LS_64(ignore_mw_bnd, I40IW_CQPSQ_QP_IGNOREMWBOUND) |
+ LS_64(remove_hash_idx, I40IW_CQPSQ_QP_REMOVEHASHENTRY) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "QP_DESTROY WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_qp_flush_wqes - flush qp's wqe
+ * @qp: sc qp
+ * @info: dlush information
+static enum i40iw_status_code i40iw_sc_qp_flush_wqes(
+ struct i40iw_qp_flush_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 temp = 0;
+ u64 *wqe;
+ u64 header;
+ bool flush_sq = false, flush_rq = false;
+ if (info->rq && !qp->flush_rq)
+ flush_rq = true;
+ if (info->sq && !qp->flush_sq)
+ flush_sq = true;
+ qp->flush_sq |= flush_sq;
+ qp->flush_rq |= flush_rq;
+ if (!flush_sq && !flush_rq) {
+ if (info->ae_code != I40IW_AE_LLP_RECEIVED_MPA_CRC_ERROR)
+ return 0;
+ if (!wqe)
+ if (info->userflushcode) {
+ if (flush_rq) {
+ temp |= LS_64(info->rq_minor_code, I40IW_CQPSQ_FWQE_RQMNERR) |
+ LS_64(info->rq_major_code, I40IW_CQPSQ_FWQE_RQMJERR);
+ if (flush_sq) {
+ temp |= LS_64(info->sq_minor_code, I40IW_CQPSQ_FWQE_SQMNERR) |
+ LS_64(info->sq_major_code, I40IW_CQPSQ_FWQE_SQMJERR);
+ temp = (info->generate_ae) ?
+ info->ae_code | LS_64(info->ae_source, I40IW_CQPSQ_FWQE_AESOURCE) : 0;
+ set_64bit_val(wqe, 8, temp);
+ LS_64(I40IW_CQP_OP_FLUSH_WQES, I40IW_CQPSQ_OPCODE) |
+ LS_64(info->generate_ae, I40IW_CQPSQ_FWQE_GENERATE_AE) |
+ LS_64(info->userflushcode, I40IW_CQPSQ_FWQE_USERFLCODE) |
+ LS_64(flush_sq, I40IW_CQPSQ_FWQE_FLUSHSQ) |
+ LS_64(flush_rq, I40IW_CQPSQ_FWQE_FLUSHRQ) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "QP_FLUSH WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_qp_upload_context - upload qp's context
+ * @info: upload context info ptr for return
+static enum i40iw_status_code i40iw_sc_qp_upload_context(
+ struct i40iw_sc_dev *dev,
+ struct i40iw_upload_context_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ cqp = dev->cqp;
+ if (!wqe)
+ set_64bit_val(wqe, 16, info->buf_pa);
+ header = LS_64(info->qp_id, I40IW_CQPSQ_UCTX_QPID) |
+ LS_64(I40IW_CQP_OP_UPLOAD_CONTEXT, I40IW_CQPSQ_OPCODE) |
+ LS_64(info->qp_type, I40IW_CQPSQ_UCTX_QPTYPE) |
+ LS_64(info->raw_format, I40IW_CQPSQ_UCTX_RAWFORMAT) |
+ LS_64(info->freeze_qp, I40IW_CQPSQ_UCTX_FREEZEQP) |
+ i40iw_debug_buf(dev, I40IW_DEBUG_WQE, "QP_UPLOAD_CTX WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_qp_setctx - set qp's context
+ * @qp: sc qp
+ * @qp_ctx: context ptr
+ * @info: ctx info
+static enum i40iw_status_code i40iw_sc_qp_setctx(
+ u64 *qp_ctx,
+ struct i40iw_qp_host_ctx_info *info)
+ struct i40iwarp_offload_info *iw;
+ struct i40iw_tcp_offload_info *tcp;
+ u64 qw0, qw3, qw7 = 0;
+ iw = info->iwarp_info;
+ tcp = info->tcp_info;
+ qw0 = LS_64(qp->qp_uk.rq_wqe_size, I40IWQPC_RQWQESIZE) |
+ LS_64(info->err_rq_idx_valid, I40IWQPC_ERR_RQ_IDX_VALID) |
+ LS_64(qp->rcv_tph_en, I40IWQPC_RCVTPHEN) |
+ LS_64(qp->xmit_tph_en, I40IWQPC_XMITTPHEN) |
+ LS_64(qp->rq_tph_en, I40IWQPC_RQTPHEN) |
+ LS_64(qp->sq_tph_en, I40IWQPC_SQTPHEN) |
+ LS_64(info->push_idx, I40IWQPC_PPIDX) |
+ LS_64(info->push_mode_en, I40IWQPC_PMENA);
+ set_64bit_val(qp_ctx, 8, qp->sq_pa);
+ set_64bit_val(qp_ctx, 16, qp->rq_pa);
+ qw3 = LS_64(qp->src_mac_addr_idx, I40IWQPC_SRCMACADDRIDX) |
+ LS_64(qp->hw_rq_size, I40IWQPC_RQSIZE) |
+ LS_64(qp->hw_sq_size, I40IWQPC_SQSIZE);
+ 128,
+ LS_64(info->err_rq_idx, I40IWQPC_ERR_RQ_IDX));
+ 136,
+ LS_64(info->send_cq_num, I40IWQPC_TXCQNUM) |
+ LS_64(info->rcv_cq_num, I40IWQPC_RXCQNUM));
+ 168,
+ LS_64(info->qp_compl_ctx, I40IWQPC_QPCOMPCTX));
+ 176,
+ LS_64(qp->sq_tph_val, I40IWQPC_SQTPHVAL) |
+ LS_64(qp->rq_tph_val, I40IWQPC_RQTPHVAL) |
+ LS_64(qp->qs_handle, I40IWQPC_QSHANDLE) |
+ LS_64(qp->exception_lan_queue, I40IWQPC_EXCEPTION_LAN_QUEUE));
+ if (info->iwarp_info_valid) {
+ qw0 |= LS_64(iw->ddp_ver, I40IWQPC_DDP_VER) |
+ LS_64(iw->rdmap_ver, I40IWQPC_RDMAP_VER);
+ qw7 |= LS_64(iw->pd_id, I40IWQPC_PDIDX);
+ set_64bit_val(qp_ctx, 144, qp->q2_pa);
+ 152,
+ LS_64(iw->last_byte_sent, I40IWQPC_LASTBYTESENT));
+ * Hard-code IRD_SIZE to hw-limit, 128, in qpctx, i.e matching an
+ *advertisable IRD of 64
+ iw->ird_size = I40IW_QPCTX_ENCD_MAXIRD;
+ 160,
+ LS_64(iw->ord_size, I40IWQPC_ORDSIZE) |
+ LS_64(iw->ird_size, I40IWQPC_IRDSIZE) |
+ LS_64(iw->wr_rdresp_en, I40IWQPC_WRRDRSPOK) |
+ LS_64(iw->rd_enable, I40IWQPC_RDOK) |
+ LS_64(iw->snd_mark_en, I40IWQPC_SNDMARKERS) |
+ LS_64(iw->bind_en, I40IWQPC_BINDEN) |
+ LS_64(iw->fast_reg_en, I40IWQPC_FASTREGEN) |
+ LS_64(iw->priv_mode_en, I40IWQPC_PRIVEN) |
+ LS_64(1, I40IWQPC_IWARPMODE) |
+ LS_64(iw->rcv_mark_en, I40IWQPC_RCVMARKERS) |
+ LS_64(iw->align_hdrs, I40IWQPC_ALIGNHDRS) |
+ LS_64(iw->rcv_no_mpa_crc, I40IWQPC_RCVNOMPACRC) |
+ LS_64(iw->rcv_mark_offset, I40IWQPC_RCVMARKOFFSET) |
+ LS_64(iw->snd_mark_offset, I40IWQPC_SNDMARKOFFSET));
+ if (info->tcp_info_valid) {
+ qw0 |= LS_64(tcp->ipv4, I40IWQPC_IPV4) |
+ LS_64(tcp->no_nagle, I40IWQPC_NONAGLE) |
+ LS_64(tcp->insert_vlan_tag, I40IWQPC_INSERTVLANTAG) |
+ LS_64(tcp->time_stamp, I40IWQPC_TIMESTAMP) |
+ LS_64(tcp->cwnd_inc_limit, I40IWQPC_LIMIT) |
+ LS_64(tcp->drop_ooo_seg, I40IWQPC_DROPOOOSEG) |
+ LS_64(tcp->dup_ack_thresh, I40IWQPC_DUPACK_THRESH);
+ qw3 |= LS_64(tcp->ttl, I40IWQPC_TTL) |
+ LS_64(tcp->src_mac_addr_idx, I40IWQPC_SRCMACADDRIDX) |
+ LS_64(tcp->avoid_stretch_ack, I40IWQPC_AVOIDSTRETCHACK) |
+ LS_64(tcp->tos, I40IWQPC_TOS) |
+ LS_64(tcp->src_port, I40IWQPC_SRCPORTNUM) |
+ LS_64(tcp->dst_port, I40IWQPC_DESTPORTNUM);
+ qp->src_mac_addr_idx = tcp->src_mac_addr_idx;
+ 32,
+ LS_64(tcp->dest_ip_addr2, I40IWQPC_DESTIPADDR2) |
+ LS_64(tcp->dest_ip_addr3, I40IWQPC_DESTIPADDR3));
+ 40,
+ LS_64(tcp->dest_ip_addr0, I40IWQPC_DESTIPADDR0) |
+ LS_64(tcp->dest_ip_addr1, I40IWQPC_DESTIPADDR1));
+ 48,
+ LS_64(tcp->snd_mss, I40IWQPC_SNDMSS) |
+ LS_64(tcp->vlan_tag, I40IWQPC_VLANTAG) |
+ LS_64(tcp->arp_idx, I40IWQPC_ARPIDX));
+ qw7 |= LS_64(tcp->flow_label, I40IWQPC_FLOWLABEL) |
+ LS_64(tcp->wscale, I40IWQPC_WSCALE) |
+ LS_64(tcp->ignore_tcp_opt, I40IWQPC_IGNORE_TCP_OPT) |
+ LS_64(tcp->ignore_tcp_uns_opt, I40IWQPC_IGNORE_TCP_UNS_OPT) |
+ LS_64(tcp->tcp_state, I40IWQPC_TCPSTATE) |
+ LS_64(tcp->rcv_wscale, I40IWQPC_RCVSCALE) |
+ LS_64(tcp->snd_wscale, I40IWQPC_SNDSCALE);
+ 72,
+ LS_64(tcp->time_stamp_recent, I40IWQPC_TIMESTAMP_RECENT) |
+ LS_64(tcp->time_stamp_age, I40IWQPC_TIMESTAMP_AGE));
+ 80,
+ LS_64(tcp->snd_nxt, I40IWQPC_SNDNXT) |
+ LS_64(tcp->snd_wnd, I40IWQPC_SNDWND));
+ 88,
+ LS_64(tcp->rcv_nxt, I40IWQPC_RCVNXT) |
+ LS_64(tcp->rcv_wnd, I40IWQPC_RCVWND));
+ 96,
+ LS_64(tcp->snd_max, I40IWQPC_SNDMAX) |
+ LS_64(tcp->snd_una, I40IWQPC_SNDUNA));
+ 104,
+ LS_64(tcp->srtt, I40IWQPC_SRTT) |
+ LS_64(tcp->rtt_var, I40IWQPC_RTTVAR));
+ 112,
+ LS_64(tcp->ss_thresh, I40IWQPC_SSTHRESH) |
+ LS_64(tcp->cwnd, I40IWQPC_CWND));
+ 120,
+ LS_64(tcp->snd_wl1, I40IWQPC_SNDWL1) |
+ LS_64(tcp->snd_wl2, I40IWQPC_SNDWL2));
+ 128,
+ LS_64(tcp->max_snd_window, I40IWQPC_MAXSNDWND) |
+ LS_64(tcp->rexmit_thresh, I40IWQPC_REXMIT_THRESH));
+ 184,
+ LS_64(tcp->local_ipaddr3, I40IWQPC_LOCAL_IPADDR3) |
+ LS_64(tcp->local_ipaddr2, I40IWQPC_LOCAL_IPADDR2));
+ 192,
+ LS_64(tcp->local_ipaddr1, I40IWQPC_LOCAL_IPADDR1) |
+ LS_64(tcp->local_ipaddr0, I40IWQPC_LOCAL_IPADDR0));
+ set_64bit_val(qp_ctx, 0, qw0);
+ set_64bit_val(qp_ctx, 24, qw3);
+ set_64bit_val(qp_ctx, 56, qw7);
+ i40iw_debug_buf(qp->dev, I40IW_DEBUG_WQE, "QP_HOST)CTX WQE",
+ qp_ctx, I40IW_QP_CTX_SIZE);
+ return 0;
+ * i40iw_sc_alloc_stag - mr stag alloc
+ * @info: stag info
+static enum i40iw_status_code i40iw_sc_alloc_stag(
+ struct i40iw_allocate_stag_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 header;
+ cqp = dev->cqp;
+ if (!wqe)
+ 8,
+ LS_64(info->pd_id, I40IW_CQPSQ_STAG_PDID) |
+ LS_64(info->total_len, I40IW_CQPSQ_STAG_STAGLEN));
+ 16,
+ LS_64(info->stag_idx, I40IW_CQPSQ_STAG_IDX));
+ 40,
+ LS_64(info->hmc_fcn_index, I40IW_CQPSQ_STAG_HMCFNIDX));
+ header = LS_64(I40IW_CQP_OP_ALLOC_STAG, I40IW_CQPSQ_OPCODE) |
+ LS_64(1, I40IW_CQPSQ_STAG_MR) |
+ LS_64(info->access_rights, I40IW_CQPSQ_STAG_ARIGHTS) |
+ LS_64(info->chunk_size, I40IW_CQPSQ_STAG_LPBLSIZE) |
+ LS_64(info->page_size, I40IW_CQPSQ_STAG_HPAGESIZE) |
+ LS_64(info->remote_access, I40IW_CQPSQ_STAG_REMACCENABLED) |
+ LS_64(info->use_hmc_fcn_index, I40IW_CQPSQ_STAG_USEHMCFNIDX) |
+ LS_64(info->use_pf_rid, I40IW_CQPSQ_STAG_USEPFRID) |
+ i40iw_debug_buf(dev, I40IW_DEBUG_WQE, "ALLOC_STAG WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_mr_reg_non_shared - non-shared mr registration
+ * @info: mr info
+static enum i40iw_status_code i40iw_sc_mr_reg_non_shared(
+ struct i40iw_reg_ns_stag_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 temp;
+ u64 header;
+ u32 pble_obj_cnt;
+ bool remote_access;
+ u8 addr_type;
+ if (info->access_rights & (I40IW_ACCESS_FLAGS_REMOTEREAD_ONLY |
+ I40IW_ACCESS_FLAGS_REMOTEWRITE_ONLY))
+ remote_access = true;
+ else
+ remote_access = false;
+ pble_obj_cnt = dev->hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].cnt;
+ if (info->chunk_size && (info->first_pm_pbl_index >= pble_obj_cnt))
+ cqp = dev->cqp;
+ if (!wqe)
+ temp = (info->addr_type == I40IW_ADDR_TYPE_VA_BASED) ? (uintptr_t)info->va : info->fbo;
+ 8,
+ LS_64(info->total_len, I40IW_CQPSQ_STAG_STAGLEN) |
+ LS_64(info->pd_id, I40IW_CQPSQ_STAG_PDID));
+ 16,
+ LS_64(info->stag_key, I40IW_CQPSQ_STAG_KEY) |
+ if (!info->chunk_size) {
+ set_64bit_val(wqe, 32, info->reg_addr_pa);
+ set_64bit_val(wqe, 48, 0);
+ } else {
+ set_64bit_val(wqe, 32, 0);
+ set_64bit_val(wqe, 48, info->first_pm_pbl_index);
+ set_64bit_val(wqe, 40, info->hmc_fcn_index);
+ set_64bit_val(wqe, 56, 0);
+ addr_type = (info->addr_type == I40IW_ADDR_TYPE_VA_BASED) ? 1 : 0;
+ header = LS_64(I40IW_CQP_OP_REG_MR, I40IW_CQPSQ_OPCODE) |
+ LS_64(remote_access, I40IW_CQPSQ_STAG_REMACCENABLED) |
+ LS_64(addr_type, I40IW_CQPSQ_STAG_VABASEDTO) |
+ i40iw_debug_buf(dev, I40IW_DEBUG_WQE, "MR_REG_NS WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_mr_reg_shared - registered shared memory region
+ * @info: info for shared memory registeration
+static enum i40iw_status_code i40iw_sc_mr_reg_shared(
+ struct i40iw_register_shared_stag *info,
+ u64 scratch,
+ bool post_sq)
+ u64 *wqe;
+ u64 temp, va64, fbo, header;
+ u32 va32;
+ u8 addr_type;
+ else
+ cqp = dev->cqp;
+ if (!wqe)
+ va64 = (uintptr_t)(info->va);
+ va32 = (u32)(va64 & 0x00000000FFFFFFFF);
+ fbo = (u64)(va32 & (4096 - 1));
+ 0,
+ (info->addr_type == I40IW_ADDR_TYPE_VA_BASED ? (uintptr_t)info->va : fbo));
+ 8,
+ temp = LS_64(info->new_stag_key, I40IW_CQPSQ_STAG_KEY) |
+ LS_64(info->new_stag_idx, I40IW_CQPSQ_STAG_IDX) |
+ LS_64(info->parent_stag_idx, I40IW_CQPSQ_STAG_PARENTSTAGIDX);
+ header = LS_64(I40IW_CQP_OP_REG_SMR, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(dev, I40IW_DEBUG_WQE, "MR_REG_SHARED WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_dealloc_stag - deallocate stag
+ * @info: dealloc stag info
+static enum i40iw_status_code i40iw_sc_dealloc_stag(
+ struct i40iw_dealloc_stag_info *info,
+ u64 scratch,
+ bool post_sq)
+ u64 header;
+ u64 *wqe;
+ cqp = dev->cqp;
+ if (!wqe)
+ 8,
+ 16,
+ header = LS_64(I40IW_CQP_OP_DEALLOC_STAG, I40IW_CQPSQ_OPCODE) |
+ LS_64(info->mr, I40IW_CQPSQ_STAG_MR) |
+ i40iw_debug_buf(dev, I40IW_DEBUG_WQE, "DEALLOC_STAG WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_query_stag - query hardware for stag
+ * @stag_index: stag index for query
+static enum i40iw_status_code i40iw_sc_query_stag(struct i40iw_sc_dev *dev,
+ u64 scratch,
+ u32 stag_index,
+ bool post_sq)
+ u64 header;
+ u64 *wqe;
+ cqp = dev->cqp;
+ if (!wqe)
+ 16,
+ LS_64(stag_index, I40IW_CQPSQ_QUERYSTAG_IDX));
+ header = LS_64(I40IW_CQP_OP_QUERY_STAG, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(dev, I40IW_DEBUG_WQE, "QUERY_STAG WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_mw_alloc - mw allocate
+ * @mw_stag_index:stag index
+ * @pd_id: pd is for this mw
+static enum i40iw_status_code i40iw_sc_mw_alloc(
+ u64 scratch,
+ u32 mw_stag_index,
+ u16 pd_id,
+ bool post_sq)
+ u64 header;
+ u64 *wqe;
+ cqp = dev->cqp;
+ if (!wqe)
+ set_64bit_val(wqe, 8, LS_64(pd_id, I40IW_CQPSQ_STAG_PDID));
+ 16,
+ LS_64(mw_stag_index, I40IW_CQPSQ_STAG_IDX));
+ i40iw_debug_buf(dev, I40IW_DEBUG_WQE, "MW_ALLOC WQE",
+ if (post_sq)
+ return 0;
+ * i40iw_sc_send_lsmm - send last streaming mode message
+ * @qp: sc qp struct
+ * @lsmm_buf: buffer with lsmm message
+ * @size: size of lsmm buffer
+ * @stag: stag of lsmm buffer
+static void i40iw_sc_send_lsmm(struct i40iw_sc_qp *qp,
+ void *lsmm_buf,
+ u32 size,
+ i40iw_stag stag)
+ u64 *wqe;
+ u64 header;
+ struct i40iw_qp_uk *qp_uk;
+ qp_uk = &qp->qp_uk;
+ wqe = qp_uk->sq_base->elem;
+ set_64bit_val(wqe, 0, (uintptr_t)lsmm_buf);
+ set_64bit_val(wqe, 8, (size | LS_64(stag, I40IWQPSQ_FRAG_STAG)));
+ set_64bit_val(wqe, 16, 0);
+ header = LS_64(I40IWQP_OP_RDMA_SEND, I40IWQPSQ_OPCODE) |
+ LS_64(1, I40IWQPSQ_STREAMMODE) |
+ LS_64(1, I40IWQPSQ_WAITFORRCVPDU) |
+ LS_64(qp->qp_uk.swqe_polarity, I40IWQPSQ_VALID);
+ i40iw_debug_buf(qp->dev, I40IW_DEBUG_QP, "SEND_LSMM WQE",
+ wqe, I40IW_QP_WQE_MIN_SIZE);
+ * i40iw_sc_send_lsmm_nostag - for privilege qp
+static void i40iw_sc_send_lsmm_nostag(struct i40iw_sc_qp *qp,
+ void *lsmm_buf,
+ u32 size)
+ u64 *wqe;
+ u64 header;
+ set_64bit_val(wqe, 8, size);
+ i40iw_debug_buf(qp->dev, I40IW_DEBUG_WQE, "SEND_LSMM_NOSTAG WQE",
+ * i40iw_sc_send_rtt - send last read0 or write0
+ * @read: Do read0 or write0
+static void i40iw_sc_send_rtt(struct i40iw_sc_qp *qp, bool read)
+ u64 *wqe;
+ u64 header;
+ set_64bit_val(wqe, 0, 0);
+ set_64bit_val(wqe, 8, 0);
+ if (read) {
+ header = LS_64(0x1234, I40IWQPSQ_REMSTAG) |
+ LS_64(I40IWQP_OP_RDMA_READ, I40IWQPSQ_OPCODE) |
+ set_64bit_val(wqe, 8, ((u64)0xabcd << 32));
+ } else {
+ header = LS_64(I40IWQP_OP_RDMA_WRITE, I40IWQPSQ_OPCODE) |
+ i40iw_debug_buf(qp->dev, I40IW_DEBUG_WQE, "RTR WQE",
+ * i40iw_sc_post_wqe0 - send wqe with opcode
+ * @opcode: opcode to use for wqe0
+static enum i40iw_status_code i40iw_sc_post_wqe0(struct i40iw_sc_qp *qp, u8 opcode)
+ u64 *wqe;
+ u64 header;
+ if (!wqe)
+ return I40IW_ERR_QP_TOOMANY_WRS_POSTED;
+ switch (opcode) {
+ case I40IWQP_OP_NOP:
+ header = LS_64(I40IWQP_OP_NOP, I40IWQPSQ_OPCODE) |
+ break;
+ case I40IWQP_OP_RDMA_SEND:
+ LS_64(qp->qp_uk.swqe_polarity, I40IWQPSQ_VALID) |
+ LS_64(1, I40IWQPSQ_WAITFORRCVPDU);
+ break;
+ default:
+ i40iw_debug(qp->dev, I40IW_DEBUG_QP, "%s: Invalid WQE zero opcode\n",
+ __func__);
+ break;
+ return 0;
+ * i40iw_sc_init_iw_hmc() - queries fpm values using cqp and populates hmc_info
+ * @dev : ptr to i40iw_dev struct
+enum i40iw_status_code i40iw_sc_init_iw_hmc(struct i40iw_sc_dev *dev, u8 hmc_fn_id)
+ struct i40iw_hmc_info *hmc_info;
+ struct i40iw_dma_mem query_fpm_mem;
+ struct i40iw_virt_mem virt_mem;
+ struct i40iw_vfdev *vf_dev = NULL;
+ u32 mem_size;
+ bool poll_registers = true;
+ u16 iw_vf_idx;
+ u8 wait_type;
+ if (hmc_fn_id >= I40IW_MAX_VF_FPM_ID ||
+ (dev->hmc_fn_id != hmc_fn_id && hmc_fn_id < I40IW_FIRST_VF_FPM_ID))
+ return I40IW_ERR_INVALID_HMCFN_ID;
+ i40iw_debug(dev, I40IW_DEBUG_HMC, "hmc_fn_id %u, dev->hmc_fn_id %u\n", hmc_fn_id,
+ dev->hmc_fn_id);
+ if (hmc_fn_id == dev->hmc_fn_id) {
+ hmc_info = dev->hmc_info;
+ query_fpm_mem.pa = dev->fpm_query_buf_pa;
+ query_fpm_mem.va = dev->fpm_query_buf;
+ } else {
+ vf_dev = i40iw_vfdev_from_fpm(dev, hmc_fn_id);
+ if (!vf_dev)
+ hmc_info = &vf_dev->hmc_info;
+ iw_vf_idx = vf_dev->iw_vf_idx;
+ i40iw_debug(dev, I40IW_DEBUG_HMC, "vf_dev %p, hmc_info %p, hmc_obj %p\n", vf_dev,
+ hmc_info, hmc_info->hmc_obj);
+ if (!vf_dev->fpm_query_buf) {
+ if (!dev->vf_fpm_query_buf[iw_vf_idx].va) {
+ ret_code = i40iw_alloc_query_fpm_buf(dev,
+ &dev->vf_fpm_query_buf[iw_vf_idx]);
+ if (ret_code)
+ return ret_code;
+ vf_dev->fpm_query_buf = dev->vf_fpm_query_buf[iw_vf_idx].va;
+ vf_dev->fpm_query_buf_pa = dev->vf_fpm_query_buf[iw_vf_idx].pa;
+ query_fpm_mem.pa = vf_dev->fpm_query_buf_pa;
+ query_fpm_mem.va = vf_dev->fpm_query_buf;
+ * It is HARDWARE specific:
+ * this call is done by PF for VF and
+ * i40iw_sc_query_fpm_values needs ccq poll
+ * because PF ccq is already created.
+ poll_registers = false;
+ hmc_info->hmc_fn_id = hmc_fn_id;
+ if (hmc_fn_id != dev->hmc_fn_id) {
+ ret_code =
+ i40iw_cqp_query_fpm_values_cmd(dev, &query_fpm_mem, hmc_fn_id);
+ } else {
+ wait_type = poll_registers ? (u8)I40IW_CQP_WAIT_POLL_REGS :
+ (u8)I40IW_CQP_WAIT_POLL_CQ;
+ ret_code = i40iw_sc_query_fpm_values(
+ dev->cqp,
+ 0,
+ hmc_info->hmc_fn_id,
+ &query_fpm_mem,
+ true,
+ wait_type);
+ if (ret_code)
+ return ret_code;
+ /* parse the fpm_query_buf and fill hmc obj info */
+ ret_code =
+ i40iw_sc_parse_fpm_query_buf((u64 *)query_fpm_mem.va,
+ hmc_info,
+ &dev->hmc_fpm_misc);
+ if (ret_code)
+ return ret_code;
+ i40iw_debug_buf(dev, I40IW_DEBUG_HMC, "QUERY FPM BUFFER",
+ query_fpm_mem.va, I40IW_QUERY_FPM_BUF_SIZE);
+ i40iw_cqp_commit_fpm_values_cmd(dev, &query_fpm_mem, hmc_fn_id);
+ /* parse the fpm_commit_buf and fill hmc obj info */
+ i40iw_sc_parse_fpm_commit_buf((u64 *)query_fpm_mem.va, hmc_info->hmc_obj);
+ mem_size = sizeof(struct i40iw_hmc_sd_entry) *
+ (hmc_info->sd_table.sd_cnt + hmc_info->first_sd_index);
+ ret_code = i40iw_allocate_virt_mem(dev->hw, &virt_mem, mem_size);
+ if (ret_code)
+ return ret_code;
+ hmc_info->sd_table.sd_entry = virt_mem.va;
+ /* fill size of objects which are fixed */
+ hmc_info->hmc_obj[I40IW_HMC_IW_XFFL].size = 4;
+ hmc_info->hmc_obj[I40IW_HMC_IW_Q1FL].size = 4;
+ hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].size = 8;
+ hmc_info->hmc_obj[I40IW_HMC_IW_APBVT_ENTRY].size = 8192;
+ hmc_info->hmc_obj[I40IW_HMC_IW_APBVT_ENTRY].max_cnt = 1;
+ return ret_code;
+ * i40iw_sc_configure_iw_fpm() - commits hmc obj cnt values using cqp command and
+ * populates fpm base address in hmc_info
+static enum i40iw_status_code i40iw_sc_configure_iw_fpm(struct i40iw_sc_dev *dev,
+ u8 hmc_fn_id)
+ struct i40iw_hmc_obj_info *obj_info;
+ u64 *buf;
+ struct i40iw_dma_mem commit_fpm_mem;
+ u32 i, j;
+ u8 wait_type;
+ } else {
+ hmc_info = i40iw_vf_hmcinfo_from_fpm(dev, hmc_fn_id);
+ if (!hmc_info)
+ return I40IW_ERR_BAD_PTR;
+ obj_info = hmc_info->hmc_obj;
+ buf = dev->fpm_commit_buf;
+ /* copy cnt values in commit buf */
+ for (i = I40IW_HMC_IW_QP, j = 0; i <= I40IW_HMC_IW_PBLE;
+ i++, j += 8)
+ set_64bit_val(buf, j, (u64)obj_info[i].cnt);
+ set_64bit_val(buf, 40, 0); /* APBVT rsvd */
+ commit_fpm_mem.pa = dev->fpm_commit_buf_pa;
+ commit_fpm_mem.va = dev->fpm_commit_buf;
+ ret_code = i40iw_sc_commit_fpm_values(
+ dev->cqp,
+ 0,
+ &commit_fpm_mem,
+ true,
+ wait_type);
+ if (!ret_code)
+ ret_code = i40iw_sc_parse_fpm_commit_buf(dev->fpm_commit_buf, hmc_info->hmc_obj);
+ i40iw_debug_buf(dev, I40IW_DEBUG_HMC, "COMMIT FPM BUFFER",
+ commit_fpm_mem.va, I40IW_COMMIT_FPM_BUF_SIZE);
+ return ret_code;
+ * cqp_sds_wqe_fill - fill cqp wqe doe sd
+ * @cqp: struct for cqp hw
+ * @info; sd info for wqe
+static enum i40iw_status_code cqp_sds_wqe_fill(struct i40iw_sc_cqp *cqp,
+ struct i40iw_update_sds_info *info,
+ u64 scratch)
+ u64 data;
+ u64 header;
+ u64 *wqe;
+ int mem_entries, wqe_entries;
+ struct i40iw_dma_mem *sdbuf = &cqp->sdbuf;
+ if (!wqe)
+ wqe_entries = (info->cnt > 3) ? 3 : info->cnt;
+ mem_entries = info->cnt - wqe_entries;
+ header = LS_64(I40IW_CQP_OP_UPDATE_PE_SDS, I40IW_CQPSQ_OPCODE) |
+ LS_64(mem_entries, I40IW_CQPSQ_UPESD_ENTRY_COUNT);
+ if (mem_entries) {
+ memcpy(sdbuf->va, &info->entry[3], (mem_entries << 4));
+ data = sdbuf->pa;
+ } else {
+ data = 0;
+ data |= LS_64(info->hmc_fn_id, I40IW_CQPSQ_UPESD_HMCFNID);
+ set_64bit_val(wqe, 16, data);
+ switch (wqe_entries) {
+ case 3:
+ (LS_64(info->entry[2].cmd, I40IW_CQPSQ_UPESD_SDCMD) |
+ LS_64(1, I40IW_CQPSQ_UPESD_ENTRY_VALID)));
+ set_64bit_val(wqe, 56, info->entry[2].data);
+ /* fallthrough */
+ case 2:
+ (LS_64(info->entry[1].cmd, I40IW_CQPSQ_UPESD_SDCMD) |
+ set_64bit_val(wqe, 40, info->entry[1].data);
+ /* fallthrough */
+ case 1:
+ LS_64(info->entry[0].cmd, I40IW_CQPSQ_UPESD_SDCMD));
+ set_64bit_val(wqe, 8, info->entry[0].data);
+ break;
+ default:
+ break;
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "UPDATE_PE_SDS WQE",
+ return 0;
+ * i40iw_update_pe_sds - cqp wqe for sd
+ * @dev: ptr to i40iw_dev struct
+ * @info: sd info for sd's
+static enum i40iw_status_code i40iw_update_pe_sds(struct i40iw_sc_dev *dev,
+ u64 scratch)
+ struct i40iw_sc_cqp *cqp = dev->cqp;
+ ret_code = cqp_sds_wqe_fill(cqp, info, scratch);
+ if (!ret_code)
+ return ret_code;
+ * i40iw_update_sds_noccq - update sd before ccq created
+ * @dev: sc device struct
+enum i40iw_status_code i40iw_update_sds_noccq(struct i40iw_sc_dev *dev,
+ struct i40iw_update_sds_info *info)
+ u32 error, val, tail;
+ ret_code = cqp_sds_wqe_fill(cqp, info, 0);
+ if (ret_code)
+ return ret_code;
+ if (error)
+ return I40IW_ERR_CQP_COMPL_ERROR;
+ return ret_code;
+ * i40iw_sc_suspend_qp - suspend qp for param change
+enum i40iw_status_code i40iw_sc_suspend_qp(struct i40iw_sc_cqp *cqp,
+ u64 scratch)
+ u64 header;
+ u64 *wqe;
+ if (!wqe)
+ header = LS_64(qp->qp_uk.qp_id, I40IW_CQPSQ_SUSPENDQP_QPID) |
+ LS_64(I40IW_CQP_OP_SUSPEND_QP, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "SUSPEND_QP WQE",
+ return 0;
+ * i40iw_sc_resume_qp - resume qp after suspend
+enum i40iw_status_code i40iw_sc_resume_qp(struct i40iw_sc_cqp *cqp,
+ u64 scratch)
+ u64 header;
+ u64 *wqe;
+ if (!wqe)
+ 16,
+ LS_64(qp->qs_handle, I40IW_CQPSQ_RESUMEQP_QSHANDLE));
+ header = LS_64(qp->qp_uk.qp_id, I40IW_CQPSQ_RESUMEQP_QPID) |
+ LS_64(I40IW_CQP_OP_RESUME_QP, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "RESUME_QP WQE",
+ return 0;
+ * i40iw_sc_static_hmc_pages_allocated - cqp wqe to allocate hmc pages
+enum i40iw_status_code i40iw_sc_static_hmc_pages_allocated(
+ struct i40iw_sc_cqp *cqp,
+ u64 scratch,
+ u8 hmc_fn_id,
+ bool post_sq,
+ u64 header;
+ u64 *wqe;
+ if (!wqe)
+ 16,
+ LS_64(hmc_fn_id, I40IW_SHMC_PAGE_ALLOCATED_HMC_FN_ID));
+ header = LS_64(I40IW_CQP_OP_SHMC_PAGES_ALLOCATED, I40IW_CQPSQ_OPCODE) |
+ i40iw_debug_buf(cqp->dev, I40IW_DEBUG_WQE, "SHMC_PAGES_ALLOCATED WQE",
+ if (error) {
+ return ret_code;
+ if (post_sq) {
+ /* check for cqp sq tail update */
+ else
+ NULL);
+ return ret_code;
+ * i40iw_ring_full - check if cqp ring is full
+static bool i40iw_ring_full(struct i40iw_sc_cqp *cqp)
+ return I40IW_RING_FULL_ERR(cqp->sq_ring);
+ * i40iw_config_fpm_values - configure HMC objects
+ * @qp_count: desired qp count
+enum i40iw_status_code i40iw_config_fpm_values(struct i40iw_sc_dev *dev, u32 qp_count)
+ u32 i, mem_size;
+ u32 qpwantedoriginal, qpwanted, mrwanted, pblewanted;
+ u32 powerof2;
+ u64 sd_needed, bytes_needed;
+ u32 loop_count = 0;
+ struct i40iw_hmc_fpm_misc *hmc_fpm_misc;
+ hmc_fpm_misc = &dev->hmc_fpm_misc;
+ ret_code = i40iw_sc_init_iw_hmc(dev, dev->hmc_fn_id);
+ if (ret_code) {
+ "i40iw_sc_init_iw_hmc returned error_code = %d\n",
+ ret_code);
+ return ret_code;
+ bytes_needed = 0;
+ for (i = I40IW_HMC_IW_QP; i < I40IW_HMC_IW_MAX; i++) {
+ hmc_info->hmc_obj[i].cnt = hmc_info->hmc_obj[i].max_cnt;
+ bytes_needed +=
+ (hmc_info->hmc_obj[i].max_cnt) * (hmc_info->hmc_obj[i].size);
+ "%s i[%04d] max_cnt[0x%04X] size[0x%04llx]\n",
+ __func__, i, hmc_info->hmc_obj[i].max_cnt,
+ hmc_info->hmc_obj[i].size);
+ sd_needed = (bytes_needed / I40IW_HMC_DIRECT_BP_SIZE) + 1; /* round up */
+ "%s: FW initial max sd_count[%08lld] first_sd_index[%04d]\n",
+ __func__, sd_needed, hmc_info->first_sd_index);
+ "%s: bytes_needed=0x%llx sd count %d where max sd is %d\n",
+ __func__, bytes_needed, hmc_info->sd_table.sd_cnt,
+ hmc_fpm_misc->max_sds);
+ qpwanted = min(qp_count, hmc_info->hmc_obj[I40IW_HMC_IW_QP].max_cnt);
+ qpwantedoriginal = qpwanted;
+ mrwanted = hmc_info->hmc_obj[I40IW_HMC_IW_MR].max_cnt;
+ pblewanted = hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].max_cnt;
+ "req_qp=%d max_sd=%d, max_qp = %d, max_cq=%d, max_mr=%d, max_pble=%d\n",
+ qp_count, hmc_fpm_misc->max_sds,
+ hmc_info->hmc_obj[I40IW_HMC_IW_QP].max_cnt,
+ hmc_info->hmc_obj[I40IW_HMC_IW_CQ].max_cnt,
+ hmc_info->hmc_obj[I40IW_HMC_IW_MR].max_cnt,
+ hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].max_cnt);
+ do {
+ ++loop_count;
+ hmc_info->hmc_obj[I40IW_HMC_IW_QP].cnt = qpwanted;
+ hmc_info->hmc_obj[I40IW_HMC_IW_CQ].cnt =
+ min(2 * qpwanted, hmc_info->hmc_obj[I40IW_HMC_IW_CQ].cnt);
+ hmc_info->hmc_obj[I40IW_HMC_IW_SRQ].cnt = 0x00; /* Reserved */
+ hmc_info->hmc_obj[I40IW_HMC_IW_HTE].cnt =
+ qpwanted * hmc_fpm_misc->ht_multiplier;
+ hmc_info->hmc_obj[I40IW_HMC_IW_ARP].cnt =
+ hmc_info->hmc_obj[I40IW_HMC_IW_ARP].max_cnt;
+ hmc_info->hmc_obj[I40IW_HMC_IW_APBVT_ENTRY].cnt = 1;
+ hmc_info->hmc_obj[I40IW_HMC_IW_MR].cnt = mrwanted;
+ hmc_info->hmc_obj[I40IW_HMC_IW_XF].cnt = I40IW_MAX_WQ_ENTRIES * qpwanted;
+ hmc_info->hmc_obj[I40IW_HMC_IW_Q1].cnt = 4 * I40IW_MAX_IRD_SIZE * qpwanted;
+ hmc_info->hmc_obj[I40IW_HMC_IW_XFFL].cnt =
+ hmc_info->hmc_obj[I40IW_HMC_IW_XF].cnt / hmc_fpm_misc->xf_block_size;
+ hmc_info->hmc_obj[I40IW_HMC_IW_Q1FL].cnt =
+ hmc_info->hmc_obj[I40IW_HMC_IW_Q1].cnt / hmc_fpm_misc->q1_block_size;
+ hmc_info->hmc_obj[I40IW_HMC_IW_TIMER].cnt =
+ ((qpwanted) / 512 + 1) * hmc_fpm_misc->timer_bucket;
+ hmc_info->hmc_obj[I40IW_HMC_IW_FSIMC].cnt = 0x00;
+ hmc_info->hmc_obj[I40IW_HMC_IW_FSIAV].cnt = 0x00;
+ hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].cnt = pblewanted;
+ /* How much memory is needed for all the objects. */
+ bytes_needed = 0;
+ bytes_needed +=
+ (hmc_info->hmc_obj[i].cnt) * (hmc_info->hmc_obj[i].size);
+ if ((loop_count > 1000) ||
+ ((!(loop_count % 10)) &&
+ (qpwanted > qpwantedoriginal * 2 / 3))) {
+ if (qpwanted > FPM_MULTIPLIER) {
+ qpwanted -= FPM_MULTIPLIER;
+ powerof2 = 1;
+ while (powerof2 < qpwanted)
+ powerof2 *= 2;
+ powerof2 /= 2;
+ qpwanted = powerof2;
+ } else {
+ qpwanted /= 2;
+ if (mrwanted > FPM_MULTIPLIER * 10)
+ mrwanted -= FPM_MULTIPLIER * 10;
+ if (pblewanted > FPM_MULTIPLIER * 1000)
+ pblewanted -= FPM_MULTIPLIER * 1000;
+ } while (sd_needed > hmc_fpm_misc->max_sds && loop_count < 2000);
+ bytes_needed = 0;
+ bytes_needed += (hmc_info->hmc_obj[i].cnt) * (hmc_info->hmc_obj[i].size);
+ "%s i[%04d] cnt[0x%04x] size[0x%04llx]\n",
+ __func__, i, hmc_info->hmc_obj[i].cnt,
+ sd_needed = (bytes_needed / I40IW_HMC_DIRECT_BP_SIZE) + 1; /* round up not truncate. */
+ "loop_cnt=%d, sd_needed=%lld, qpcnt = %d, cqcnt=%d, mrcnt=%d, pblecnt=%d\n",
+ loop_count, sd_needed,
+ hmc_info->hmc_obj[I40IW_HMC_IW_QP].cnt,
+ hmc_info->hmc_obj[I40IW_HMC_IW_CQ].cnt,
+ hmc_info->hmc_obj[I40IW_HMC_IW_MR].cnt,
+ hmc_info->hmc_obj[I40IW_HMC_IW_PBLE].cnt);
+ ret_code = i40iw_sc_configure_iw_fpm(dev, dev->hmc_fn_id);
+ if (ret_code) {
+ "configure_iw_fpm returned error_code[x%08X]\n",
+ i40iw_rd32(dev->hw, dev->is_pf ? I40E_PFPE_CQPERRCODES : I40E_VFPE_CQPERRCODES1));
+ return ret_code;
+ hmc_info->sd_table.sd_cnt = (u32)sd_needed;
+ (hmc_info->sd_table.sd_cnt + hmc_info->first_sd_index + 1);
+ if (ret_code) {
+ "%s: failed to allocate memory for sd_entry buffer\n",
+ __func__);
+ return ret_code;
+ return ret_code;
+ * i40iw_exec_cqp_cmd - execute cqp cmd when wqe are available
+ * @dev: rdma device
+ * @pcmdinfo: cqp command info
+static enum i40iw_status_code i40iw_exec_cqp_cmd(struct i40iw_sc_dev *dev,
+ struct cqp_commands_info *pcmdinfo)
+ enum i40iw_status_code status;
+ struct i40iw_dma_mem values_mem;
+ dev->cqp_cmd_stats[pcmdinfo->cqp_cmd]++;
+ switch (pcmdinfo->cqp_cmd) {
+ case OP_DELETE_LOCAL_MAC_IPADDR_ENTRY:
+ status = i40iw_sc_del_local_mac_ipaddr_entry(
+ pcmdinfo->in.u.del_local_mac_ipaddr_entry.cqp,
+ pcmdinfo->in.u.del_local_mac_ipaddr_entry.scratch,
+ pcmdinfo->in.u.del_local_mac_ipaddr_entry.entry_idx,
+ pcmdinfo->in.u.del_local_mac_ipaddr_entry.ignore_ref_count,
+ pcmdinfo->post_sq);
+ break;
+ case OP_CEQ_DESTROY:
+ status = i40iw_sc_ceq_destroy(pcmdinfo->in.u.ceq_destroy.ceq,
+ pcmdinfo->in.u.ceq_destroy.scratch,
+ break;
+ case OP_AEQ_DESTROY:
+ status = i40iw_sc_aeq_destroy(pcmdinfo->in.u.aeq_destroy.aeq,
+ pcmdinfo->in.u.aeq_destroy.scratch,
+ break;
+ case OP_DELETE_ARP_CACHE_ENTRY:
+ status = i40iw_sc_del_arp_cache_entry(
+ pcmdinfo->in.u.del_arp_cache_entry.cqp,
+ pcmdinfo->in.u.del_arp_cache_entry.scratch,
+ pcmdinfo->in.u.del_arp_cache_entry.arp_index,
+ break;
+ case OP_MANAGE_APBVT_ENTRY:
+ status = i40iw_sc_manage_apbvt_entry(
+ pcmdinfo->in.u.manage_apbvt_entry.cqp,
+ &pcmdinfo->in.u.manage_apbvt_entry.info,
+ pcmdinfo->in.u.manage_apbvt_entry.scratch,
+ break;
+ case OP_CEQ_CREATE:
+ status = i40iw_sc_ceq_create(pcmdinfo->in.u.ceq_create.ceq,
+ pcmdinfo->in.u.ceq_create.scratch,
+ break;
+ case OP_AEQ_CREATE:
+ status = i40iw_sc_aeq_create(pcmdinfo->in.u.aeq_create.aeq,
+ pcmdinfo->in.u.aeq_create.scratch,
+ break;
+ case OP_ALLOC_LOCAL_MAC_IPADDR_ENTRY:
+ status = i40iw_sc_alloc_local_mac_ipaddr_entry(
+ pcmdinfo->in.u.alloc_local_mac_ipaddr_entry.cqp,
+ pcmdinfo->in.u.alloc_local_mac_ipaddr_entry.scratch,
+ break;
+ case OP_ADD_LOCAL_MAC_IPADDR_ENTRY:
+ status = i40iw_sc_add_local_mac_ipaddr_entry(
+ pcmdinfo->in.u.add_local_mac_ipaddr_entry.cqp,
+ &pcmdinfo->in.u.add_local_mac_ipaddr_entry.info,
+ pcmdinfo->in.u.add_local_mac_ipaddr_entry.scratch,
+ break;
+ case OP_MANAGE_QHASH_TABLE_ENTRY:
+ status = i40iw_sc_manage_qhash_table_entry(
+ pcmdinfo->in.u.manage_qhash_table_entry.cqp,
+ &pcmdinfo->in.u.manage_qhash_table_entry.info,
+ pcmdinfo->in.u.manage_qhash_table_entry.scratch,
+ break;
+ case OP_QP_MODIFY:
+ status = i40iw_sc_qp_modify(
+ pcmdinfo->in.u.qp_modify.qp,
+ &pcmdinfo->in.u.qp_modify.info,
+ pcmdinfo->in.u.qp_modify.scratch,
+ break;
+ case OP_QP_UPLOAD_CONTEXT:
+ status = i40iw_sc_qp_upload_context(
+ pcmdinfo->in.u.qp_upload_context.dev,
+ &pcmdinfo->in.u.qp_upload_context.info,
+ pcmdinfo->in.u.qp_upload_context.scratch,
+ break;
+ case OP_CQ_CREATE:
+ status = i40iw_sc_cq_create(
+ pcmdinfo->in.u.cq_create.cq,
+ pcmdinfo->in.u.cq_create.scratch,
+ pcmdinfo->in.u.cq_create.check_overflow,
+ break;
+ case OP_CQ_DESTROY:
+ status = i40iw_sc_cq_destroy(
+ pcmdinfo->in.u.cq_destroy.cq,
+ pcmdinfo->in.u.cq_destroy.scratch,
+ break;
+ case OP_QP_CREATE:
+ status = i40iw_sc_qp_create(
+ pcmdinfo->in.u.qp_create.qp,
+ &pcmdinfo->in.u.qp_create.info,
+ pcmdinfo->in.u.qp_create.scratch,
+ break;
+ case OP_QP_DESTROY:
+ status = i40iw_sc_qp_destroy(
+ pcmdinfo->in.u.qp_destroy.qp,
+ pcmdinfo->in.u.qp_destroy.scratch,
+ pcmdinfo->in.u.qp_destroy.remove_hash_idx,
+ ignore_mw_bnd,
+ break;
+ case OP_ALLOC_STAG:
+ status = i40iw_sc_alloc_stag(
+ pcmdinfo->in.u.alloc_stag.dev,
+ &pcmdinfo->in.u.alloc_stag.info,
+ pcmdinfo->in.u.alloc_stag.scratch,
+ break;
+ case OP_MR_REG_NON_SHARED:
+ status = i40iw_sc_mr_reg_non_shared(
+ pcmdinfo->in.u.mr_reg_non_shared.dev,
+ &pcmdinfo->in.u.mr_reg_non_shared.info,
+ pcmdinfo->in.u.mr_reg_non_shared.scratch,
+ break;
+ case OP_DEALLOC_STAG:
+ status = i40iw_sc_dealloc_stag(
+ pcmdinfo->in.u.dealloc_stag.dev,
+ &pcmdinfo->in.u.dealloc_stag.info,
+ pcmdinfo->in.u.dealloc_stag.scratch,
+ break;
+ case OP_MW_ALLOC:
+ status = i40iw_sc_mw_alloc(
+ pcmdinfo->in.u.mw_alloc.dev,
+ pcmdinfo->in.u.mw_alloc.scratch,
+ pcmdinfo->in.u.mw_alloc.mw_stag_index,
+ pcmdinfo->in.u.mw_alloc.pd_id,
+ break;
+ case OP_QP_FLUSH_WQES:
+ status = i40iw_sc_qp_flush_wqes(
+ pcmdinfo->in.u.qp_flush_wqes.qp,
+ &pcmdinfo->in.u.qp_flush_wqes.info,
+ scratch, pcmdinfo->post_sq);
+ break;
+ case OP_ADD_ARP_CACHE_ENTRY:
+ status = i40iw_sc_add_arp_cache_entry(
+ pcmdinfo->in.u.add_arp_cache_entry.cqp,
+ &pcmdinfo->in.u.add_arp_cache_entry.info,
+ pcmdinfo->in.u.add_arp_cache_entry.scratch,
+ break;
+ case OP_MANAGE_PUSH_PAGE:
+ status = i40iw_sc_manage_push_page(
+ pcmdinfo->in.u.manage_push_page.cqp,
+ &pcmdinfo->in.u.manage_push_page.info,
+ pcmdinfo->in.u.manage_push_page.scratch,
+ break;
+ case OP_UPDATE_PE_SDS:
+ /* case I40IW_CQP_OP_UPDATE_PE_SDS */
+ status = i40iw_update_pe_sds(
+ pcmdinfo->in.u.update_pe_sds.dev,
+ &pcmdinfo->in.u.update_pe_sds.info,
+ scratch);
+ break;
+ case OP_MANAGE_HMC_PM_FUNC_TABLE:
+ status = i40iw_sc_manage_hmc_pm_func_table(
+ pcmdinfo->in.u.manage_hmc_pm.dev->cqp,
+ pcmdinfo->in.u.manage_hmc_pm.scratch,
+ (u8)pcmdinfo->in.u.manage_hmc_pm.info.vf_id,
+ pcmdinfo->in.u.manage_hmc_pm.info.free_fcn,
+ true);
+ break;
+ case OP_SUSPEND:
+ status = i40iw_sc_suspend_qp(
+ pcmdinfo->in.u.suspend_resume.cqp,
+ pcmdinfo->in.u.suspend_resume.qp,
+ pcmdinfo->in.u.suspend_resume.scratch);
+ break;
+ case OP_RESUME:
+ status = i40iw_sc_resume_qp(
+ break;
+ case OP_MANAGE_VF_PBLE_BP:
+ status = i40iw_manage_vf_pble_bp(
+ pcmdinfo->in.u.manage_vf_pble_bp.cqp,
+ &pcmdinfo->in.u.manage_vf_pble_bp.info,
+ pcmdinfo->in.u.manage_vf_pble_bp.scratch, true);
+ break;
+ case OP_QUERY_FPM_VALUES:
+ values_mem.pa = pcmdinfo->in.u.query_fpm_values.fpm_values_pa;
+ values_mem.va = pcmdinfo->in.u.query_fpm_values.fpm_values_va;
+ status = i40iw_sc_query_fpm_values(
+ pcmdinfo->in.u.query_fpm_values.cqp,
+ pcmdinfo->in.u.query_fpm_values.scratch,
+ pcmdinfo->in.u.query_fpm_values.hmc_fn_id,
+ &values_mem, true, I40IW_CQP_WAIT_EVENT);
+ break;
+ case OP_COMMIT_FPM_VALUES:
+ values_mem.pa = pcmdinfo->in.u.commit_fpm_values.fpm_values_pa;
+ values_mem.va = pcmdinfo->in.u.commit_fpm_values.fpm_values_va;
+ status = i40iw_sc_commit_fpm_values(
+ pcmdinfo->in.u.commit_fpm_values.cqp,
+ pcmdinfo->in.u.commit_fpm_values.scratch,
+ pcmdinfo->in.u.commit_fpm_values.hmc_fn_id,
+ &values_mem,
+ true,
+ I40IW_CQP_WAIT_EVENT);
+ break;
+ default:
+ status = I40IW_NOT_SUPPORTED;
+ break;
+ return status;
+ * i40iw_process_cqp_cmd - process all cqp commands
+enum i40iw_status_code i40iw_process_cqp_cmd(struct i40iw_sc_dev *dev,
+ enum i40iw_status_code status = 0;
+ unsigned long flags;
+ spin_lock_irqsave(&dev->cqp_lock, flags);
+ if (list_empty(&dev->cqp_cmd_head) && !i40iw_ring_full(dev->cqp))
+ status = i40iw_exec_cqp_cmd(dev, pcmdinfo);
+ else
+ list_add_tail(&pcmdinfo->cqp_cmd_entry, &dev->cqp_cmd_head);
+ spin_unlock_irqrestore(&dev->cqp_lock, flags);
+ return status;
+ * i40iw_process_bh - called from tasklet for cqp list
+enum i40iw_status_code i40iw_process_bh(struct i40iw_sc_dev *dev)
+ struct cqp_commands_info *pcmdinfo;
+ while (!list_empty(&dev->cqp_cmd_head) && !i40iw_ring_full(dev->cqp)) {
+ pcmdinfo = (struct cqp_commands_info *)i40iw_remove_head(&dev->cqp_cmd_head);
+ if (status)
+ break;
+ return status;
+ * i40iw_iwarp_opcode - determine if incoming is rdma layer
+ * @info: aeq info for the packet
+ * @pkt: packet for error
+static u32 i40iw_iwarp_opcode(struct i40iw_aeqe_info *info, u8 *pkt)
+ u16 *mpa;
+ u32 opcode = 0xffffffff;
+ if (info->q2_data_written) {
+ mpa = (u16 *)pkt;
+ opcode = ntohs(mpa[1]) & 0xf;
+ return opcode;
+ * i40iw_locate_mpa - return pointer to mpa in the pkt
+ * @pkt: packet with data
+static u8 *i40iw_locate_mpa(u8 *pkt)
+ /* skip over ethernet header */
+ pkt += I40IW_MAC_HLEN;
+ /* Skip over IP and TCP headers */
+ pkt += 4 * (pkt[0] & 0x0f);
+ pkt += 4 * ((pkt[12] >> 4) & 0x0f);
+ return pkt;
+ * i40iw_setup_termhdr - termhdr for terminate pkt
+ * @qp: sc qp ptr for pkt
+ * @hdr: term hdr
+ * @opcode: flush opcode for termhdr
+ * @layer_etype: error layer + error type
+ * @err: error cod ein the header
+static void i40iw_setup_termhdr(struct i40iw_sc_qp *qp,
+ struct i40iw_terminate_hdr *hdr,
+ enum i40iw_flush_opcode opcode,
+ u8 layer_etype,
+ u8 err)
+ qp->flush_code = opcode;
+ hdr->layer_etype = layer_etype;
+ hdr->error_code = err;
+ * i40iw_bld_terminate_hdr - build terminate message header
+ * @qp: qp associated with received terminate AE
+ * @info: the struct contiaing AE information
+static int i40iw_bld_terminate_hdr(struct i40iw_sc_qp *qp,
+ u8 *pkt = qp->q2_buf + Q2_BAD_FRAME_OFFSET;
+ u16 ddp_seg_len;
+ int copy_len = 0;
+ u8 is_tagged = 0;
+ enum i40iw_flush_opcode flush_code = FLUSH_INVALID;
+ u32 opcode;
+ struct i40iw_terminate_hdr *termhdr;
+ termhdr = (struct i40iw_terminate_hdr *)qp->q2_buf;
+ memset(termhdr, 0, Q2_BAD_FRAME_OFFSET);
+ /* Use data from offending packet to fill in ddp & rdma hdrs */
+ pkt = i40iw_locate_mpa(pkt);
+ ddp_seg_len = ntohs(*(u16 *)pkt);
+ if (ddp_seg_len) {
+ copy_len = 2;
+ termhdr->hdrct = DDP_LEN_FLAG;
+ if (pkt[2] & 0x80) {
+ is_tagged = 1;
+ if (ddp_seg_len >= TERM_DDP_LEN_TAGGED) {
+ copy_len += TERM_DDP_LEN_TAGGED;
+ termhdr->hdrct |= DDP_HDR_FLAG;
+ } else {
+ if (ddp_seg_len >= TERM_DDP_LEN_UNTAGGED) {
+ copy_len += TERM_DDP_LEN_UNTAGGED;
+ if (ddp_seg_len >= (TERM_DDP_LEN_UNTAGGED + TERM_RDMA_LEN)) {
+ if ((pkt[3] & RDMA_OPCODE_MASK) == RDMA_READ_REQ_OPCODE) {
+ copy_len += TERM_RDMA_LEN;
+ termhdr->hdrct |= RDMA_HDR_FLAG;
+ opcode = i40iw_iwarp_opcode(info, pkt);
+ switch (info->ae_id) {
+ case I40IW_AE_AMP_UNALLOCATED_STAG:
+ qp->eventtype = TERM_EVENT_QP_ACCESS_ERR;
+ if (opcode == I40IW_OP_TYPE_RDMA_WRITE)
+ i40iw_setup_termhdr(qp, termhdr, FLUSH_PROT_ERR,
+ (LAYER_DDP << 4) | DDP_TAGGED_BUFFER, DDP_TAGGED_INV_STAG);
+ else
+ i40iw_setup_termhdr(qp, termhdr, FLUSH_REM_ACCESS_ERR,
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_PROT, RDMAP_INV_STAG);
+ break;
+ case I40IW_AE_AMP_BOUNDS_VIOLATION:
+ (LAYER_DDP << 4) | DDP_TAGGED_BUFFER, DDP_TAGGED_BOUNDS);
+ else
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_PROT, RDMAP_INV_BOUNDS);
+ break;
+ case I40IW_AE_AMP_BAD_PD:
+ switch (opcode) {
+ case I40IW_OP_TYPE_RDMA_WRITE:
+ (LAYER_DDP << 4) | DDP_TAGGED_BUFFER, DDP_TAGGED_UNASSOC_STAG);
+ break;
+ case I40IW_OP_TYPE_SEND_INV:
+ case I40IW_OP_TYPE_SEND_SOL_INV:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_PROT, RDMAP_CANT_INV_STAG);
+ break;
+ default:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_PROT, RDMAP_UNASSOC_STAG);
+ break;
+ case I40IW_AE_AMP_INVALID_STAG:
+ break;
+ case I40IW_AE_AMP_BAD_QP:
+ i40iw_setup_termhdr(qp, termhdr, FLUSH_LOC_QP_OP_ERR,
+ (LAYER_DDP << 4) | DDP_UNTAGGED_BUFFER, DDP_UNTAGGED_INV_QN);
+ break;
+ case I40IW_AE_AMP_BAD_STAG_KEY:
+ case I40IW_AE_AMP_BAD_STAG_INDEX:
+ switch (opcode) {
+ i40iw_setup_termhdr(qp, termhdr, FLUSH_REM_OP_ERR,
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_OP, RDMAP_CANT_INV_STAG);
+ break;
+ default:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_OP, RDMAP_INV_STAG);
+ break;
+ case I40IW_AE_AMP_RIGHTS_VIOLATION:
+ case I40IW_AE_AMP_INVALIDATE_NO_REMOTE_ACCESS_RIGHTS:
+ case I40IW_AE_PRIV_OPERATION_DENIED:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_PROT, RDMAP_ACCESS);
+ break;
+ case I40IW_AE_AMP_TO_WRAP:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_PROT, RDMAP_TO_WRAP);
+ break;
+ case I40IW_AE_LLP_RECEIVED_MARKER_AND_LENGTH_FIELDS_DONT_MATCH:
+ i40iw_setup_termhdr(qp, termhdr, FLUSH_LOC_LEN_ERR,
+ (LAYER_MPA << 4) | DDP_LLP, MPA_MARKER);
+ break;
+ case I40IW_AE_LLP_RECEIVED_MPA_CRC_ERROR:
+ i40iw_setup_termhdr(qp, termhdr, FLUSH_GENERAL_ERR,
+ (LAYER_MPA << 4) | DDP_LLP, MPA_CRC);
+ break;
+ case I40IW_AE_LLP_SEGMENT_TOO_LARGE:
+ case I40IW_AE_LLP_SEGMENT_TOO_SMALL:
+ (LAYER_DDP << 4) | DDP_CATASTROPHIC, DDP_CATASTROPHIC_LOCAL);
+ break;
+ case I40IW_AE_LCE_QP_CATASTROPHIC:
+ case I40IW_AE_DDP_NO_L_BIT:
+ i40iw_setup_termhdr(qp, termhdr, FLUSH_FATAL_ERR,
+ break;
+ case I40IW_AE_DDP_INVALID_MSN_GAP_IN_MSN:
+ case I40IW_AE_DDP_INVALID_MSN_RANGE_IS_NOT_VALID:
+ (LAYER_DDP << 4) | DDP_UNTAGGED_BUFFER, DDP_UNTAGGED_INV_MSN_RANGE);
+ break;
+ case I40IW_AE_DDP_UBE_DDP_MESSAGE_TOO_LONG_FOR_AVAILABLE_BUFFER:
+ (LAYER_DDP << 4) | DDP_UNTAGGED_BUFFER, DDP_UNTAGGED_INV_TOO_LONG);
+ break;
+ case I40IW_AE_DDP_UBE_INVALID_DDP_VERSION:
+ if (is_tagged)
+ (LAYER_DDP << 4) | DDP_TAGGED_BUFFER, DDP_TAGGED_INV_DDP_VER);
+ else
+ (LAYER_DDP << 4) | DDP_UNTAGGED_BUFFER, DDP_UNTAGGED_INV_DDP_VER);
+ break;
+ case I40IW_AE_DDP_UBE_INVALID_MO:
+ (LAYER_DDP << 4) | DDP_UNTAGGED_BUFFER, DDP_UNTAGGED_INV_MO);
+ break;
+ case I40IW_AE_DDP_UBE_INVALID_MSN_NO_BUFFER_AVAILABLE:
+ (LAYER_DDP << 4) | DDP_UNTAGGED_BUFFER, DDP_UNTAGGED_INV_MSN_NO_BUF);
+ break;
+ case I40IW_AE_DDP_UBE_INVALID_QN:
+ break;
+ case I40IW_AE_RDMAP_ROE_INVALID_RDMAP_VERSION:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_OP, RDMAP_INV_RDMAP_VER);
+ break;
+ case I40IW_AE_RDMAP_ROE_UNEXPECTED_OPCODE:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_OP, RDMAP_UNEXPECTED_OP);
+ break;
+ default:
+ (LAYER_RDMA << 4) | RDMAP_REMOTE_OP, RDMAP_UNSPECIFIED);
+ break;
+ if (copy_len)
+ memcpy(termhdr + 1, pkt, copy_len);
+ if (flush_code && !info->in_rdrsp_wr)
+ qp->sq_flush = (info->sq) ? true : false;
+ return sizeof(struct i40iw_terminate_hdr) + copy_len;
+ * i40iw_terminate_send_fin() - Send fin for terminate message
+void i40iw_terminate_send_fin(struct i40iw_sc_qp *qp)
+ /* Send the fin only */
+ i40iw_term_modify_qp(qp,
+ I40IW_QP_STATE_TERMINATE,
+ I40IWQP_TERM_SEND_FIN_ONLY,
+ 0);
+ * i40iw_terminate_connection() - Bad AE and send terminate to remote QP
+void i40iw_terminate_connection(struct i40iw_sc_qp *qp, struct i40iw_aeqe_info *info)
+ u8 termlen = 0;
+ if (qp->term_flags & I40IW_TERM_SENT)
+ return; /* Sanity check */
+ /* Eventtype can change from bld_terminate_hdr */
+ qp->eventtype = TERM_EVENT_QP_FATAL;
+ termlen = i40iw_bld_terminate_hdr(qp, info);
+ i40iw_terminate_start_timer(qp);
+ qp->term_flags |= I40IW_TERM_SENT;
+ i40iw_term_modify_qp(qp, I40IW_QP_STATE_TERMINATE,
+ I40IWQP_TERM_SEND_TERM_ONLY, termlen);
+ * i40iw_terminate_received - handle terminate received AE
+void i40iw_terminate_received(struct i40iw_sc_qp *qp, struct i40iw_aeqe_info *info)
+ u32 *mpa;
+ u8 ddp_ctl;
+ u8 rdma_ctl;
+ u16 aeq_id = 0;
+ mpa = (u32 *)i40iw_locate_mpa(pkt);
+ /* did not validate the frame - do it now */
+ ddp_ctl = (ntohl(mpa[0]) >> 8) & 0xff;
+ rdma_ctl = ntohl(mpa[0]) & 0xff;
+ if ((ddp_ctl & 0xc0) != 0x40)
+ aeq_id = I40IW_AE_LCE_QP_CATASTROPHIC;
+ else if ((ddp_ctl & 0x03) != 1)
+ aeq_id = I40IW_AE_DDP_UBE_INVALID_DDP_VERSION;
+ else if (ntohl(mpa[2]) != 2)
+ aeq_id = I40IW_AE_DDP_UBE_INVALID_QN;
+ else if (ntohl(mpa[3]) != 1)
+ aeq_id = I40IW_AE_DDP_INVALID_MSN_GAP_IN_MSN;
+ else if (ntohl(mpa[4]) != 0)
+ aeq_id = I40IW_AE_DDP_UBE_INVALID_MO;
+ else if ((rdma_ctl & 0xc0) != 0x40)
+ aeq_id = I40IW_AE_RDMAP_ROE_INVALID_RDMAP_VERSION;
+ info->ae_id = aeq_id;
+ if (info->ae_id) {
+ /* Bad terminate recvd - send back a terminate */
+ i40iw_terminate_connection(qp, info);
+ return;
+ qp->term_flags |= I40IW_TERM_RCVD;
+ termhdr = (struct i40iw_terminate_hdr *)&mpa[5];
+ if (termhdr->layer_etype == RDMAP_REMOTE_PROT ||
+ termhdr->layer_etype == RDMAP_REMOTE_OP) {
+ i40iw_terminate_done(qp, 0);
+ } else {
+ i40iw_terminate_send_fin(qp);
+ * i40iw_hw_stat_init - Initiliaze HW stats table
+ * @devstat: pestat struct
+ * @fcn_idx: PCI fn id
+ * @hw: PF i40iw_hw structure.
+ * @is_pf: Is it a PF?
+ * Populate the HW stat table with register offset addr for each
+ * stat. And start the perioidic stats timer.
+static void i40iw_hw_stat_init(struct i40iw_dev_pestat *devstat,
+ u8 fcn_idx,
+ struct i40iw_hw *hw, bool is_pf)
+ u32 stat_reg_offset;
+ u32 stat_index;
+ struct i40iw_dev_hw_stat_offsets *stat_table =
+ &devstat->hw_stat_offsets;
+ struct i40iw_dev_hw_stats *last_rd_stats = &devstat->last_read_hw_stats;
+ devstat->hw = hw;
+ if (is_pf) {
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_IP4RXDISCARD] =
+ I40E_GLPES_PFIP4RXDISCARD(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_IP4RXTRUNC] =
+ I40E_GLPES_PFIP4RXTRUNC(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_IP4TXNOROUTE] =
+ I40E_GLPES_PFIP4TXNOROUTE(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_IP6RXDISCARD] =
+ I40E_GLPES_PFIP6RXDISCARD(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_IP6RXTRUNC] =
+ I40E_GLPES_PFIP6RXTRUNC(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_IP6TXNOROUTE] =
+ I40E_GLPES_PFIP6TXNOROUTE(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_TCPRTXSEG] =
+ I40E_GLPES_PFTCPRTXSEG(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_TCPRXOPTERR] =
+ I40E_GLPES_PFTCPRXOPTERR(fcn_idx);
+ stat_table->stat_offset_32[I40IW_HW_STAT_INDEX_TCPRXPROTOERR] =
+ I40E_GLPES_PFTCPRXPROTOERR(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4RXOCTS] =
+ I40E_GLPES_PFIP4RXOCTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4RXPKTS] =
+ I40E_GLPES_PFIP4RXPKTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4RXFRAGS] =
+ I40E_GLPES_PFIP4RXFRAGSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4RXMCPKTS] =
+ I40E_GLPES_PFIP4RXMCPKTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4TXOCTS] =
+ I40E_GLPES_PFIP4TXOCTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4TXPKTS] =
+ I40E_GLPES_PFIP4TXPKTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4TXFRAGS] =
+ I40E_GLPES_PFIP4TXFRAGSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP4TXMCPKTS] =
+ I40E_GLPES_PFIP4TXMCPKTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP6RXOCTS] =
+ I40E_GLPES_PFIP6RXOCTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP6RXPKTS] =
+ I40E_GLPES_PFIP6RXPKTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP6RXFRAGS] =
+ I40E_GLPES_PFIP6RXFRAGSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP6RXMCPKTS] =
+ I40E_GLPES_PFIP6RXMCPKTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP6TXOCTS] =
+ I40E_GLPES_PFIP6TXOCTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP6TXPKTS] =
+ I40E_GLPES_PFIP6TXPKTSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_IP6TXFRAGS] =
+ I40E_GLPES_PFIP6TXFRAGSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_TCPRXSEGS] =
+ I40E_GLPES_PFTCPRXSEGSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_TCPTXSEG] =
+ I40E_GLPES_PFTCPTXSEGLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMARXRDS] =
+ I40E_GLPES_PFRDMARXRDSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMARXSNDS] =
+ I40E_GLPES_PFRDMARXSNDSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMARXWRS] =
+ I40E_GLPES_PFRDMARXWRSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMATXRDS] =
+ I40E_GLPES_PFRDMATXRDSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMATXSNDS] =
+ I40E_GLPES_PFRDMATXSNDSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMATXWRS] =
+ I40E_GLPES_PFRDMATXWRSLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMAVBND] =
+ I40E_GLPES_PFRDMAVBNDLO(fcn_idx);
+ stat_table->stat_offset_64[I40IW_HW_STAT_INDEX_RDMAVINV] =
+ I40E_GLPES_PFRDMAVINVLO(fcn_idx);
+ } else {
+ I40E_GLPES_VFIP4RXDISCARD(fcn_idx);
+ I40E_GLPES_VFIP4RXTRUNC(fcn_idx);
+ I40E_GLPES_VFIP4TXNOROUTE(fcn_idx);
+ I40E_GLPES_VFIP6RXDISCARD(fcn_idx);
+ I40E_GLPES_VFIP6RXTRUNC(fcn_idx);
+ I40E_GLPES_VFIP6TXNOROUTE(fcn_idx);
+ I40E_GLPES_VFTCPRTXSEG(fcn_idx);
+ I40E_GLPES_VFTCPRXOPTERR(fcn_idx);
+ I40E_GLPES_VFTCPRXPROTOERR(fcn_idx);
+ I40E_GLPES_VFIP4RXOCTSLO(fcn_idx);
+ I40E_GLPES_VFIP4RXPKTSLO(fcn_idx);
+ I40E_GLPES_VFIP4RXFRAGSLO(fcn_idx);
+ I40E_GLPES_VFIP4RXMCPKTSLO(fcn_idx);
+ I40E_GLPES_VFIP4TXOCTSLO(fcn_idx);
+ I40E_GLPES_VFIP4TXPKTSLO(fcn_idx);
+ I40E_GLPES_VFIP4TXFRAGSLO(fcn_idx);
+ I40E_GLPES_VFIP4TXMCPKTSLO(fcn_idx);
+ I40E_GLPES_VFIP6RXOCTSLO(fcn_idx);
+ I40E_GLPES_VFIP6RXPKTSLO(fcn_idx);
+ I40E_GLPES_VFIP6RXFRAGSLO(fcn_idx);
+ I40E_GLPES_VFIP6RXMCPKTSLO(fcn_idx);
+ I40E_GLPES_VFIP6TXOCTSLO(fcn_idx);
+ I40E_GLPES_VFIP6TXPKTSLO(fcn_idx);
+ I40E_GLPES_VFIP6TXFRAGSLO(fcn_idx);
+ I40E_GLPES_VFTCPRXSEGSLO(fcn_idx);
+ I40E_GLPES_VFTCPTXSEGLO(fcn_idx);
+ I40E_GLPES_VFRDMARXRDSLO(fcn_idx);
+ I40E_GLPES_VFRDMARXSNDSLO(fcn_idx);
+ I40E_GLPES_VFRDMARXWRSLO(fcn_idx);
+ I40E_GLPES_VFRDMATXRDSLO(fcn_idx);
+ I40E_GLPES_VFRDMATXSNDSLO(fcn_idx);
+ I40E_GLPES_VFRDMATXWRSLO(fcn_idx);
+ I40E_GLPES_VFRDMAVBNDLO(fcn_idx);
+ I40E_GLPES_VFRDMAVINVLO(fcn_idx);
+ for (stat_index = 0; stat_index < I40IW_HW_STAT_INDEX_MAX_64;
+ stat_index++) {
+ stat_reg_offset = stat_table->stat_offset_64[stat_index];
+ last_rd_stats->stat_value_64[stat_index] =
+ readq(devstat->hw->hw_addr + stat_reg_offset);
+ for (stat_index = 0; stat_index < I40IW_HW_STAT_INDEX_MAX_32;
+ stat_index++) {
+ stat_reg_offset = stat_table->stat_offset_32[stat_index];
+ last_rd_stats->stat_value_32[stat_index] =
+ i40iw_rd32(devstat->hw, stat_reg_offset);
+ * i40iw_hw_stat_read_32 - Read 32-bit HW stat counters and accommodates for roll-overs.
+ * @index: index in HW stat table which contains offset reg-addr
+ * @value: hw stat value
+static void i40iw_hw_stat_read_32(struct i40iw_dev_pestat *devstat,
+ enum i40iw_hw_stat_index_32b index,
+ u64 *value)
+ struct i40iw_dev_hw_stats *hw_stats = &devstat->hw_stats;
+ u64 new_stat_value = 0;
+ u32 stat_reg_offset = stat_table->stat_offset_32[index];
+ new_stat_value = i40iw_rd32(devstat->hw, stat_reg_offset);
+ /*roll-over case */
+ if (new_stat_value < last_rd_stats->stat_value_32[index])
+ hw_stats->stat_value_32[index] += new_stat_value;
+ else
+ new_stat_value - last_rd_stats->stat_value_32[index];
+ last_rd_stats->stat_value_32[index] = new_stat_value;
+ *value = hw_stats->stat_value_32[index];
+ * i40iw_hw_stat_read_64 - Read HW stat counters (greater than 32-bit) and accommodates for roll-overs.
+static void i40iw_hw_stat_read_64(struct i40iw_dev_pestat *devstat,
+ enum i40iw_hw_stat_index_64b index,
+ u64 *value)
+ u32 stat_reg_offset = stat_table->stat_offset_64[index];
+ new_stat_value = readq(devstat->hw->hw_addr + stat_reg_offset);
+ if (new_stat_value < last_rd_stats->stat_value_64[index])
+ hw_stats->stat_value_64[index] += new_stat_value;
+ else
+ new_stat_value - last_rd_stats->stat_value_64[index];
+ last_rd_stats->stat_value_64[index] = new_stat_value;
+ *value = hw_stats->stat_value_64[index];
+ * i40iw_hw_stat_read_all - read all HW stat counters
+ * @stat_values: hw stats structure
+ * Read all the HW stat counters and populates hw_stats structure
+ * of passed-in dev's pestat as well as copy created in stat_values.
+static void i40iw_hw_stat_read_all(struct i40iw_dev_pestat *devstat,
+ struct i40iw_dev_hw_stats *stat_values)
+ u32 stat_index;
+ stat_index++)
+ i40iw_hw_stat_read_32(devstat, stat_index,
+ &stat_values->stat_value_32[stat_index]);
+ stat_index++)
+ i40iw_hw_stat_read_64(devstat, stat_index,
+ &stat_values->stat_value_64[stat_index]);
+ * i40iw_hw_stat_refresh_all - Update all HW stat structs
+ * Read all the HW stat counters to refresh values in hw_stats structure
+static void i40iw_hw_stat_refresh_all(struct i40iw_dev_pestat *devstat)
+ u64 stat_value;
+ u32 stat_index;
+ stat_index++)
+ i40iw_hw_stat_read_32(devstat, stat_index, &stat_value);
+ stat_index++)
+ i40iw_hw_stat_read_64(devstat, stat_index, &stat_value);
+static struct i40iw_cqp_ops iw_cqp_ops = {
+ i40iw_sc_cqp_init,
+ i40iw_sc_cqp_create,
+ i40iw_sc_cqp_post_sq,
+ i40iw_sc_cqp_get_next_send_wqe,
+ i40iw_sc_cqp_destroy,
+ i40iw_sc_poll_for_cqp_op_done
+static struct i40iw_ccq_ops iw_ccq_ops = {
+ i40iw_sc_ccq_init,
+ i40iw_sc_ccq_create,
+ i40iw_sc_ccq_destroy,
+ i40iw_sc_ccq_create_done,
+ i40iw_sc_ccq_get_cqe_info,
+ i40iw_sc_ccq_arm
+static struct i40iw_ceq_ops iw_ceq_ops = {
+ i40iw_sc_ceq_init,
+ i40iw_sc_ceq_create,
+ i40iw_sc_cceq_create_done,
+ i40iw_sc_cceq_destroy_done,
+ i40iw_sc_cceq_create,
+ i40iw_sc_ceq_destroy,
+ i40iw_sc_process_ceq
+static struct i40iw_aeq_ops iw_aeq_ops = {
+ i40iw_sc_aeq_init,
+ i40iw_sc_aeq_create,
+ i40iw_sc_aeq_destroy,
+ i40iw_sc_get_next_aeqe,
+ i40iw_sc_repost_aeq_entries,
+ i40iw_sc_aeq_create_done,
+ i40iw_sc_aeq_destroy_done
+/* iwarp pd ops */
+static struct i40iw_pd_ops iw_pd_ops = {
+ i40iw_sc_pd_init,
+static struct i40iw_priv_qp_ops iw_priv_qp_ops = {
+ i40iw_sc_qp_init,
+ i40iw_sc_qp_create,
+ i40iw_sc_qp_modify,
+ i40iw_sc_qp_destroy,
+ i40iw_sc_qp_flush_wqes,
+ i40iw_sc_qp_upload_context,
+ i40iw_sc_qp_setctx,
+ i40iw_sc_send_lsmm,
+ i40iw_sc_send_lsmm_nostag,
+ i40iw_sc_send_rtt,
+ i40iw_sc_post_wqe0,
+static struct i40iw_priv_cq_ops iw_priv_cq_ops = {
+ i40iw_sc_cq_init,
+ i40iw_sc_cq_create,
+ i40iw_sc_cq_destroy,
+ i40iw_sc_cq_modify,
+static struct i40iw_mr_ops iw_mr_ops = {
+ i40iw_sc_alloc_stag,
+ i40iw_sc_mr_reg_non_shared,
+ i40iw_sc_mr_reg_shared,
+ i40iw_sc_dealloc_stag,
+ i40iw_sc_query_stag,
+ i40iw_sc_mw_alloc
+static struct i40iw_cqp_misc_ops iw_cqp_misc_ops = {
+ i40iw_sc_manage_push_page,
+ i40iw_sc_manage_hmc_pm_func_table,
+ i40iw_sc_set_hmc_resource_profile,
+ i40iw_sc_commit_fpm_values,
+ i40iw_sc_query_fpm_values,
+ i40iw_sc_static_hmc_pages_allocated,
+ i40iw_sc_add_arp_cache_entry,
+ i40iw_sc_del_arp_cache_entry,
+ i40iw_sc_query_arp_cache_entry,
+ i40iw_sc_manage_apbvt_entry,
+ i40iw_sc_manage_qhash_table_entry,
+ i40iw_sc_alloc_local_mac_ipaddr_entry,
+ i40iw_sc_add_local_mac_ipaddr_entry,
+ i40iw_sc_del_local_mac_ipaddr_entry,
+ i40iw_sc_cqp_nop,
+ i40iw_sc_commit_fpm_values_done,
+ i40iw_sc_query_fpm_values_done,
+ i40iw_sc_manage_hmc_pm_func_table_done,
+ i40iw_sc_suspend_qp,
+ i40iw_sc_resume_qp
+static struct i40iw_hmc_ops iw_hmc_ops = {
+ i40iw_sc_init_iw_hmc,
+ i40iw_sc_parse_fpm_query_buf,
+ i40iw_sc_configure_iw_fpm,
+ i40iw_sc_parse_fpm_commit_buf,
+ i40iw_sc_create_hmc_obj,
+ i40iw_sc_del_hmc_obj,
+ NULL,
+ NULL
+static const struct i40iw_device_pestat_ops iw_device_pestat_ops = {
+ i40iw_hw_stat_init,
+ i40iw_hw_stat_read_32,
+ i40iw_hw_stat_read_64,
+ i40iw_hw_stat_read_all,
+ i40iw_hw_stat_refresh_all
+ * i40iw_device_init_pestat - Initialize the pestat structure
+ * @dev: pestat struct
+enum i40iw_status_code i40iw_device_init_pestat(struct i40iw_dev_pestat *devstat)
+ devstat->ops = iw_device_pestat_ops;
+ return 0;
+ * i40iw_device_init - Initialize IWARP device
+ * @dev: IWARP device pointer
+ * @info: IWARP init info
+enum i40iw_status_code i40iw_device_init(struct i40iw_sc_dev *dev,
+ struct i40iw_device_init_info *info)
+ u32 val;
+ u32 vchnl_ver = 0;
+ u16 hmc_fcn = 0;
+ enum i40iw_status_code ret_code = 0;
+ u8 db_size;
+ spin_lock_init(&dev->cqp_lock);
+ INIT_LIST_HEAD(&dev->cqp_cmd_head); /* for the cqp commands backlog. */
+ i40iw_device_init_uk(&dev->dev_uk);
+ dev->debug_mask = info->debug_mask;
+ ret_code = i40iw_device_init_pestat(&dev->dev_pestat);
+ if (ret_code) {
+ i40iw_debug(dev, I40IW_DEBUG_DEV,
+ "%s: i40iw_device_init_pestat failed\n", __func__);
+ return ret_code;
+ dev->hmc_fn_id = info->hmc_fn_id;
+ dev->qs_handle = info->qs_handle;
+ dev->exception_lan_queue = info->exception_lan_queue;
+ dev->is_pf = info->is_pf;
+ dev->fpm_query_buf_pa = info->fpm_query_buf_pa;
+ dev->fpm_query_buf = info->fpm_query_buf;
+ dev->fpm_commit_buf_pa = info->fpm_commit_buf_pa;
+ dev->fpm_commit_buf = info->fpm_commit_buf;
+ dev->hw = info->hw;
+ dev->hw->hw_addr = info->bar0;
+ val = i40iw_rd32(dev->hw, I40E_GLPCI_DREVID);
+ dev->hw_rev = (u8)RS_32(val, I40E_GLPCI_DREVID_DEFAULT_REVID);
+ if (dev->is_pf) {
+ dev->dev_pestat.ops.iw_hw_stat_init(&dev->dev_pestat,
+ dev->hmc_fn_id, dev->hw, true);
+ spin_lock_init(&dev->dev_pestat.stats_lock);
+ /*start the periodic stats_timer */
+ i40iw_hw_stats_start_timer(dev);
+ val = i40iw_rd32(dev->hw, I40E_GLPCI_LBARCTRL);
+ db_size = (u8)RS_32(val, I40E_GLPCI_LBARCTRL_PE_DB_SIZE);
+ if ((db_size != I40IW_PE_DB_SIZE_4M) &&
+ (db_size != I40IW_PE_DB_SIZE_8M)) {
+ "%s: PE doorbell is not enabled in CSR val 0x%x\n",
+ __func__, val);
+ ret_code = I40IW_ERR_PE_DOORBELL_NOT_ENABLED;
+ return ret_code;
+ dev->db_addr = dev->hw->hw_addr + I40IW_DB_ADDR_OFFSET;
+ dev->vchnl_if.vchnl_recv = i40iw_vchnl_recv_pf;
+ } else {
+ dev->db_addr = dev->hw->hw_addr + I40IW_VF_DB_ADDR_OFFSET;
+ dev->cqp_ops = &iw_cqp_ops;
+ dev->ccq_ops = &iw_ccq_ops;
+ dev->ceq_ops = &iw_ceq_ops;
+ dev->aeq_ops = &iw_aeq_ops;
+ dev->cqp_misc_ops = &iw_cqp_misc_ops;
+ dev->iw_pd_ops = &iw_pd_ops;
+ dev->iw_priv_qp_ops = &iw_priv_qp_ops;
+ dev->iw_priv_cq_ops = &iw_priv_cq_ops;
+ dev->mr_ops = &iw_mr_ops;
+ dev->hmc_ops = &iw_hmc_ops;
+ dev->vchnl_if.vchnl_send = info->vchnl_send;
+ if (dev->vchnl_if.vchnl_send)
+ dev->vchnl_up = true;
+ else
+ dev->vchnl_up = false;
+ if (!dev->is_pf) {
+ dev->vchnl_if.vchnl_recv = i40iw_vchnl_recv_vf;
+ ret_code = i40iw_vchnl_vf_get_ver(dev, &vchnl_ver);
+ if (!ret_code) {
+ "%s: Get Channel version rc = 0x%0x, version is %u\n",
+ __func__, ret_code, vchnl_ver);
+ ret_code = i40iw_vchnl_vf_get_hmc_fcn(dev, &hmc_fcn);
+ if (!ret_code) {
+ "%s Get HMC function rc = 0x%0x, hmc fcn is %u\n",
+ __func__, ret_code, hmc_fcn);
+ dev->hmc_fn_id = (u8)hmc_fcn;
+ dev->iw_vf_cqp_ops = &iw_vf_cqp_ops;
+ return ret_code;
