i40e/i40evf: Remove addressof casts to same type
Author: Joe Perches <joe@perches.com>
Using addressof then casting to the original type is pointless,
so remove these unnecessary casts.
Done via coccinelle script:
$ cat typecast.cocci
type T;
T foo;
-	(T *)&foo
+	&foo
Signed-off-by: Joe Perches
Tested-by: Kavindya Deegala
Signed-off-by: Jeff Kirsher
 drivers/net/ethernet/intel/i40e/i40e_common.c   | 4 ++--
 drivers/net/ethernet/intel/i40evf/i40e_common.c | 3 +--
 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/net/ethernet/intel/i40e/i40e_common.c b/drivers/net/ethernet/intel/i40e/i40e_common.c
index bb948dd..922cdcc 100644
--- a/drivers/net/ethernet/intel/i40e/i40e_common.c
+++ b/drivers/net/ethernet/intel/i40e/i40e_common.c
@@ -1775,9 +1775,9 @@ static void i40e_parse_discover_capabilities(struct i40e_hw *hw, void *buff,
 	cap = (struct i40e_aqc_list_capabilities_element_resp *) buff;
 	if (list_type_opc == i40e_aqc_opc_list_dev_capabilities)
-		p = (struct i40e_hw_capabilities *)&hw->dev_caps;
+		p = &hw->dev_caps;
 	else if (list_type_opc == i40e_aqc_opc_list_func_capabilities)
-		p = (struct i40e_hw_capabilities *)&hw->func_caps;
+		p = &hw->func_caps;
 	else
 		return;
diff --git a/drivers/net/ethernet/intel/i40evf/i40e_common.c b/drivers/net/ethernet/intel/i40evf/i40e_common.c
index c688a0f..ae08437 100644
--- a/drivers/net/ethernet/intel/i40evf/i40e_common.c
+++ b/drivers/net/ethernet/intel/i40evf/i40e_common.c
@@ -565,8 +565,7 @@ i40e_status i40e_aq_send_msg_to_pf(struct i40e_hw *hw,
 		details.async = true;
 		cmd_details = &details;
-	status = i40evf_asq_send_command(hw, (struct i40e_aq_desc *)&desc, msg,
-				       msglen, cmd_details);
+	status = i40evf_asq_send_command(hw, &desc, msg, msglen, cmd_details);
 	return status;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
