i40e: use correct structure type name in sizeof
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Correct typo in the name of the type given to sizeof.  Because it is the
size of a pointer that is wanted, the typo has no impact on compilation or
execution.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).  The
semantic patch used can be found in message 0 of this patch series.
Signed-off-by: Julia Lawall
Tested-By: Jim Young
Signed-off-by: Jeff Kirsher
 drivers/net/ethernet/intel/i40e/i40e_main.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/intel/i40e/i40e_main.c b/drivers/net/ethernet/intel/i40e/i40e_main.c
index 51bc030..2ac8f45 100644
--- a/drivers/net/ethernet/intel/i40e/i40e_main.c
+++ b/drivers/net/ethernet/intel/i40e/i40e_main.c
@@ -6293,7 +6293,7 @@ static int i40e_vsi_alloc_arrays(struct i40e_vsi *vsi, bool alloc_qvectors)
 	if (alloc_qvectors) {
 		/* allocate memory for q_vector pointers */
-		size = sizeof(struct i40e_q_vectors *) * vsi->num_q_vectors;
+		size = sizeof(struct i40e_q_vector *) * vsi->num_q_vectors;
 		vsi->q_vectors = kzalloc(size, GFP_KERNEL);
 		if (!vsi->q_vectors) {
 			ret = -ENOMEM;
BtrLinux
Privacy Overview
