i2c/i2c-pasemi.c: Fix unsigned return type
The function has an unsigned return type, but returns a negative constant
to indicate an error condition.  The result of calling the function is
always stored in a variable of type (signed) int, and thus unsigned can be
dropped from the return type.
A sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@exists@
identifier f;
constant C;
 unsigned f(...)
*  return -C;
Signed-off-by: Julia Lawall
Acked-by: Olof Johansson
Signed-off-by: Benjamin Herrenschmidt
 drivers/i2c/busses/i2c-pasemi.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/busses/i2c-pasemi.c b/drivers/i2c/busses/i2c-pasemi.c
index 4174101..837b8c1 100644
--- a/drivers/i2c/busses/i2c-pasemi.c
+++ b/drivers/i2c/busses/i2c-pasemi.c
@@ -88,7 +88,7 @@ static void pasemi_smb_clear(struct pasemi_smbus *smbus)
 	reg_write(smbus, REG_SMSTA, status);
-static unsigned int pasemi_smb_waitready(struct pasemi_smbus *smbus)
+static int pasemi_smb_waitready(struct pasemi_smbus *smbus)
 	int timeout = 10;
 	unsigned int status;
BtrLinux
Privacy Overview
