i2c-smbus: Convert kzalloc to devm_kzalloc
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Converting kzalloc to devm_kzalloc simplifies the code and ensures that the
result, alert, is freed after the irq allocated by the subsequent
devm_request_irq.  This in turn ensures that when an interrupt can be
triggered, the alert structure is still available.
The problem of a free after a devm_request_irq was found using the
following semantic match (http://coccinelle.lip6.fr/)
@r exists@
expression e1,e2,x,a,b,c,d;
identifier free;
position p1,p2;
  devm_request_irq@p1(e1,e2,...,x)
  ... when any
      when != e2 = a
      when != x = b
  if (...) {
    ... when != e2 = c
        when != x = d
    free@p2(...,x,...);
    return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Jean Delvare
 drivers/i2c/i2c-smbus.c | 11 ++++-------
 1 file changed, 4 insertions(+), 7 deletions(-)
diff --git a/drivers/i2c/i2c-smbus.c b/drivers/i2c/i2c-smbus.c
index df3e0bf..92cdd23 100644
--- a/drivers/i2c/i2c-smbus.c
+++ b/drivers/i2c/i2c-smbus.c
@@ -142,7 +142,8 @@ static int smbalert_probe(struct i2c_client *ara,
 	struct i2c_adapter *adapter = ara->adapter;
 	int res;
-	alert = kzalloc(sizeof(struct i2c_smbus_alert), GFP_KERNEL);
+	alert = devm_kzalloc(&ara->dev, sizeof(struct i2c_smbus_alert),
+			     GFP_KERNEL);
 	if (!alert)
 		return -ENOMEM;
@@ -154,10 +155,8 @@ static int smbalert_probe(struct i2c_client *ara,
 	if (setup->irq > 0) {
 		res = devm_request_irq(&ara->dev, setup->irq, smbalert_irq,
 				       0, "smbus_alert", alert);
-		if (res) {
-			kfree(alert);
+		if (res)
 			return res;
 	i2c_set_clientdata(ara, alert);
@@ -167,14 +166,12 @@ static int smbalert_probe(struct i2c_client *ara,
 	return 0;
-/* IRQ resource is managed so it is freed automatically */
+/* IRQ and memory resources are managed so they are freed automatically */
 static int smbalert_remove(struct i2c_client *ara)
 	struct i2c_smbus_alert *alert = i2c_get_clientdata(ara);
 	cancel_work_sync(&alert->alert);
-	kfree(alert);
 	return 0;
BtrLinux
Privacy Overview
