i2c-s3c2410: Correct use of ! and &
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337, a bug was fixed that
involved converting !x & y to !(x & y). The code below shows the same
pattern, and thus should perhaps be fixed in the same way. In particular,
the result of !readl(i2c->regs + S3C2410_IICCON) & S3C2410_IICCON_IRQEN is
always 0.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E; constant C; @@
!E & !C
- !E & C
+ !(E & C)
Signed-off-by: Julia Lawall
Cc: Ben Dooks
Signed-off-by: Andrew Morton
Signed-off-by: Jean Delvare
drivers/i2c/busses/i2c-s3c2410.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/busses/i2c-s3c2410.c b/drivers/i2c/busses/i2c-s3c2410.c
index c772e02..1fac4e2 100644
--- a/drivers/i2c/busses/i2c-s3c2410.c
+++ b/drivers/i2c/busses/i2c-s3c2410.c
@@ -507,7 +507,7 @@ static int s3c24xx_i2c_doxfer(struct s3c24xx_i2c *i2c, struct i2c_msg *msgs, int
unsigned long timeout;
int ret;
- if (!readl(i2c->regs + S3C2410_IICCON) & S3C2410_IICCON_IRQEN)
+ if (!(readl(i2c->regs + S3C2410_IICCON) & S3C2410_IICCON_IRQEN))
return -EIO;
ret = s3c24xx_i2c_set_master(i2c); |
int ret;
return -EIO;
