i2c-pnx: Correct use of request_region/request_mem_region
request_mem_region should be used when ioremap is used subsequently.
release_region is then correspondingly replaced by release_mem_region.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
expression start,E;
- request_region
+ request_mem_region
  (start,...)
... when != request_mem_region(start,...)
    when != start = E
ioremap(start,...)
expression r.start;
- release_region
+ release_mem_region
  (start,...)
Signed-off-by: Julia Lawall
Cc: Vitaly Wool
Signed-off-by: Jean Delvare
 drivers/i2c/busses/i2c-pnx.c | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/busses/i2c-pnx.c b/drivers/i2c/busses/i2c-pnx.c
index ec15cff..6ff6c20 100644
--- a/drivers/i2c/busses/i2c-pnx.c
+++ b/drivers/i2c/busses/i2c-pnx.c
@@ -586,7 +586,8 @@ static int __devinit i2c_pnx_probe(struct platform_device *pdev)
 	alg_data->mif.timer.data = (unsigned long)i2c_pnx->adapter;
 	/* Register I/O resource */
-	if (!request_region(alg_data->base, I2C_PNX_REGION_SIZE, pdev->name)) {
+	if (!request_mem_region(alg_data->base, I2C_PNX_REGION_SIZE,
+				pdev->name)) {
 		dev_err(&pdev->dev,
 		       "I/O region 0x%08x for I2C already in use.\n",
 		       alg_data->base);
@@ -650,7 +651,7 @@ out_clock:
 out_unmap:
 	iounmap((void *)alg_data->ioaddr);
 out_release:
-	release_region(alg_data->base, I2C_PNX_REGION_SIZE);
+	release_mem_region(alg_data->base, I2C_PNX_REGION_SIZE);
 out_drvdata:
 	platform_set_drvdata(pdev, NULL);
 out:
@@ -667,7 +668,7 @@ static int __devexit i2c_pnx_remove(struct platform_device *pdev)
 	i2c_del_adapter(adap);
 	i2c_pnx->set_clock_stop(pdev);
 	return 0;
BtrLinux
Privacy Overview
