i2c-dev: Use memdup_user
Use memdup_user when user data is immediately copied into the allocated
region.  Note that in the second case, the ++i is no longer necessary, as
the last value is already freed if needed by the call to memdup_user.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: Jean Delvare
 drivers/i2c/i2c-dev.c | 22 ++++++----------------
 1 file changed, 6 insertions(+), 16 deletions(-)
diff --git a/drivers/i2c/i2c-dev.c b/drivers/i2c/i2c-dev.c
index b3fcb59..0b0427f 100644
--- a/drivers/i2c/i2c-dev.c
+++ b/drivers/i2c/i2c-dev.c
@@ -167,13 +167,9 @@ static ssize_t i2cdev_write(struct file *file, const char __user *buf,
 	if (count > 8192)
 		count = 8192;
-	tmp = kmalloc(count, GFP_KERNEL);
-	if (tmp == NULL)
-		return -ENOMEM;
-	if (copy_from_user(tmp, buf, count)) {
-		kfree(tmp);
-		return -EFAULT;
+	tmp = memdup_user(buf, count);
+	if (IS_ERR(tmp))
+		return PTR_ERR(tmp);
 	pr_debug("i2c-dev: i2c-%d writing %zu bytes.\n",
 		iminor(file->f_path.dentry->d_inode), count);
@@ -245,15 +241,9 @@ static noinline int i2cdev_ioctl_rdrw(struct i2c_client *client,
 			break;
 		data_ptrs[i] = (u8 __user *)rdwr_pa[i].buf;
-		rdwr_pa[i].buf = kmalloc(rdwr_pa[i].len, GFP_KERNEL);
-		if (rdwr_pa[i].buf == NULL) {
-			res = -ENOMEM;
-			break;
-		if (copy_from_user(rdwr_pa[i].buf, data_ptrs[i],
-				   rdwr_pa[i].len)) {
-				++i; /* Needs to be kfreed too */
-				res = -EFAULT;
+		rdwr_pa[i].buf = memdup_user(data_ptrs[i], rdwr_pa[i].len);
+		if (IS_ERR(rdwr_pa[i].buf)) {
+			res = PTR_ERR(rdwr_pa[i].buf);
 			break;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
