hwmon: (w83793) Fix checkpatch issues
Author: Guenter Roeck <linux@roeck-us.net>
Fixed:
ERROR: code indent should use tabs where possible
ERROR: do not use assignment in if condition
ERROR: space required after that ',' (ctx:VxV)
WARNING: braces {} are not necessary for any arm of this statement
WARNING: braces {} are not necessary for single statement blocks
WARNING: simple_strtol is obsolete, use kstrtol instead
WARNING: simple_strtoul is obsolete, use kstrtoul instead
Modify multi-line comments to follow Documentation/CodingStyle.
Also replaced " == " with " == ".
Translation was done with the following coccinelle script to limit risk.
identifier i;
constant C;
- C == i
+ i == C
Not fixed (false positive):
ERROR: Macros with complex values should be enclosed in parenthesis
Cc: Rudolf Marek
Signed-off-by: Guenter Roeck
 drivers/hwmon/w83793.c | 434 ++++++++++++++++++++++++++++---------------------
 1 file changed, 253 insertions(+), 181 deletions(-)
diff --git a/drivers/hwmon/w83793.c b/drivers/hwmon/w83793.c
index 742bf13..834e49d 100644
--- a/drivers/hwmon/w83793.c
+++ b/drivers/hwmon/w83793.c
@@ -1,34 +1,34 @@
-    w83793.c - Linux kernel driver for hardware monitoring
-    Copyright (C) 2006 Winbond Electronics Corp.
-                  Yuan Mu
-                  Rudolf Marek <r.marek@assembler.cz>
-    Copyright (C) 2009-2010 Sven Anders <anders@anduras.de>, ANDURAS AG.
-		  Watchdog driver part
-		  (Based partially on fschmd driver,
-		   Copyright 2007-2008 by Hans de Goede)
-    This program is free software; you can redistribute it and/or modify
-    it under the terms of the GNU General Public License as published by
-    the Free Software Foundation - version 2.
-    This program is distributed in the hope that it will be useful,
-    but WITHOUT ANY WARRANTY; without even the implied warranty of
-    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-    GNU General Public License for more details.
-    You should have received a copy of the GNU General Public License
-    along with this program; if not, write to the Free Software
-    Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA
-    02110-1301 USA.
+ * w83793.c - Linux kernel driver for hardware monitoring
+ * Copyright (C) 2006 Winbond Electronics Corp.
+ *	      Yuan Mu
+ *	      Rudolf Marek <r.marek@assembler.cz>
+ * Copyright (C) 2009-2010 Sven Anders <anders@anduras.de>, ANDURAS AG.
+ *		Watchdog driver part
+ *		(Based partially on fschmd driver,
+ *		 Copyright 2007-2008 by Hans de Goede)
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation - version 2.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA
+ * 02110-1301 USA.
-    Supports following chips:
-    Chip	#vin	#fanin	#pwm	#temp	wchipid	vendid	i2c	ISA
-    w83793	10	12	8	6	0x7b	0x5ca3	yes	no
+ * Supports following chips:
+ * Chip	#vin	#fanin	#pwm	#temp	wchipid	vendid	i2c	ISA
+ * w83793	10	12	8	6	0x7b	0x5ca3	yes	no
 #include <linux/module.h>
 #include <linux/init.h>
@@ -78,9 +78,9 @@ MODULE_PARM_DESC(nowayout,
 				__MODULE_STRING(WATCHDOG_NOWAYOUT) ")");
-   Address 0x00, 0x0d, 0x0e, 0x0f in all three banks are reserved
-   as ID, Bank Select registers
+ * Address 0x00, 0x0d, 0x0e, 0x0f in all three banks are reserved
+ * as ID, Bank Select registers
 #define W83793_REG_BANKSEL		0x00
 #define W83793_REG_VENDORID		0x0d
 #define W83793_REG_CHIPID		0x0e
@@ -110,8 +110,10 @@ static u16 W83793_REG_TEMP_MODE[2] = { 0x5e, 0x5f };
 #define TEMP_CRIT_HYST	2
 #define TEMP_WARN	3
 #define TEMP_WARN_HYST	4
-/* only crit and crit_hyst affect real-time alarm status
-   current crit crit_hyst warn warn_hyst */
+ * only crit and crit_hyst affect real-time alarm status
+ * current crit crit_hyst warn warn_hyst
 static u16 W83793_REG_TEMP[][5] = {
 	{0x1c, 0x78, 0x79, 0x7a, 0x7b},
 	{0x1d, 0x7c, 0x7d, 0x7e, 0x7f},
@@ -218,7 +220,8 @@ struct w83793_data {
 	char valid;			/* !=0 if following fields are valid */
 	unsigned long last_updated;	/* In jiffies */
 	unsigned long last_nonvolatile;	/* In jiffies, last time we update the
-					   nonvolatile registers */
+					 * nonvolatile registers
 	u8 bank;
 	u8 vrm;
@@ -233,7 +236,8 @@ struct w83793_data {
 	s8 temp[6][5];		/* current, crit, crit_hyst,warn, warn_hyst */
 	u8 temp_low_bits;	/* Additional resolution TD1-TD4 */
 	u8 temp_mode[2];	/* byte 0: Temp D1-D4 mode each has 2 bits
-				   byte 1: Temp R1,R2 mode, each has 1 bit */
+				 * byte 1: Temp R1,R2 mode, each has 1 bit
 	u8 temp_critical;	/* If reached all fan will be at full speed */
 	u8 temp_fan_map[6];	/* Temp controls which pwm fan, bit field */
@@ -268,17 +272,21 @@ struct w83793_data {
 	int watchdog_timeout; /* watchdog timeout in minutes */
-/* Somewhat ugly :( global data pointer list with all devices, so that
-   we can find our device data as when using misc_register. There is no
-   other method to get to one's device data from the open file-op and
-   for usage in the reboot notifier callback. */
+ * Somewhat ugly :( global data pointer list with all devices, so that
+ * we can find our device data as when using misc_register. There is no
+ * other method to get to one's device data from the open file-op and
+ * for usage in the reboot notifier callback.
 static LIST_HEAD(watchdog_data_list);
 /* Note this lock not only protect list access, but also data.kref access */
 static DEFINE_MUTEX(watchdog_data_mutex);
-/* Release our data struct when we're detached from the i2c client *and* all
-   references to our watchdog device are released */
+ * Release our data struct when we're detached from the i2c client *and* all
+ * references to our watchdog device are released
 static void w83793_release_resources(struct kref *ref)
 	struct w83793_data *data = container_of(ref, struct w83793_data, kref);
@@ -337,7 +345,14 @@ store_vrm(struct device *dev, struct device_attribute *attr,
 	  const char *buf, size_t count)
 	struct w83793_data *data = dev_get_drvdata(dev);
-	data->vrm = simple_strtoul(buf, NULL, 10);
+	unsigned long val;
+	int err;
+	err = kstrtoul(buf, 10, &val);
+	if (err)
+		return err;
+	data->vrm = val;
 	return count;
@@ -354,7 +369,7 @@ show_alarm_beep(struct device *dev, struct device_attribute *attr, char *buf)
 	int bit = sensor_attr->index & 0x07;
 	u8 val;
-	if (ALARM_STATUS == nr) {
+	if (nr == ALARM_STATUS) {
 		val = (data->alarms[index] >> (bit)) & 1;
 	} else {		/* BEEP_ENABLE */
 		val = (data->beeps[index] >> (bit)) & 1;
@@ -374,10 +389,14 @@ store_beep(struct device *dev, struct device_attribute *attr,
 	int index = sensor_attr->index >> 3;
 	int shift = sensor_attr->index & 0x07;
 	u8 beep_bit = 1 << shift;
-	u8 val;
+	int err;
-	val = simple_strtoul(buf, NULL, 10);
-	if (val != 0 && val != 1)
+	if (err)
+		return err;
+	if (val > 1)
 		return -EINVAL;
 	mutex_lock(&data->update_lock);
@@ -403,9 +422,14 @@ store_beep_enable(struct device *dev, struct device_attribute *attr,
 	struct i2c_client *client = to_i2c_client(dev);
 	struct w83793_data *data = i2c_get_clientdata(client);
-	u8 val = simple_strtoul(buf, NULL, 10);
+	int err;
+	if (err)
+		return err;
+	if (val > 1)
 		return -EINVAL;
@@ -449,8 +473,12 @@ store_chassis_clear(struct device *dev,
 	unsigned long val;
 	u8 reg;
+	int err;
-	if (kstrtoul(buf, 10, &val) || val != 0)
+	if (err)
+		return err;
+	if (val)
 		return -EINVAL;
@@ -473,11 +501,10 @@ show_fan(struct device *dev, struct device_attribute *attr, char *buf)
 	struct w83793_data *data = w83793_update_device(dev);
 	u16 val;
-	if (FAN_INPUT == nr) {
+	if (nr == FAN_INPUT)
 		val = data->fan[index] & 0x0fff;
-	} else {
+	else
 		val = data->fan_min[index] & 0x0fff;
 	return sprintf(buf, "%lu\n", FAN_FROM_REG(val));
@@ -491,7 +518,13 @@ store_fan_min(struct device *dev, struct device_attribute *attr,
 	int index = sensor_attr->index;
-	u16 val = FAN_TO_REG(simple_strtoul(buf, NULL, 10));
+	int err;
+	if (err)
+		return err;
+	val = FAN_TO_REG(val);
 	data->fan_min[index] = val;
@@ -513,7 +546,7 @@ show_pwm(struct device *dev, struct device_attribute *attr, char *buf)
 	int nr = sensor_attr->nr;
-	if (PWM_STOP_TIME == nr)
+	if (nr == PWM_STOP_TIME)
 		val = TIME_FROM_REG(data->pwm_stop_time[index]);
 	else
 		val = (data->pwm[index][nr] & 0x3f) << 2;
@@ -531,17 +564,21 @@ store_pwm(struct device *dev, struct device_attribute *attr,
 	    to_sensor_dev_attr_2(attr);
-	u8 val;
+	int err;
+	if (err)
+		return err;
-	if (PWM_STOP_TIME == nr) {
-		val = TIME_TO_REG(simple_strtoul(buf, NULL, 10));
+	if (nr == PWM_STOP_TIME) {
+		val = TIME_TO_REG(val);
 		data->pwm_stop_time[index] = val;
 		w83793_write_value(client, W83793_REG_PWM_STOP_TIME(index),
 				   val);
 	} else {
-		val = SENSORS_LIMIT(simple_strtoul(buf, NULL, 10), 0, 0xff)
-		      >> 2;
+		val = SENSORS_LIMIT(val, 0, 0xff) >> 2;
 		data->pwm[index][nr] =
 		    w83793_read_value(client, W83793_REG_PWM(index, nr)) & 0xc0;
 		data->pwm[index][nr] |= val;
@@ -563,7 +600,7 @@ show_temp(struct device *dev, struct device_attribute *attr, char *buf)
 	long temp = TEMP_FROM_REG(data->temp[index][nr]);
-	if (TEMP_READ == nr && index < 4) {	/* Only TD1-TD4 have low bits */
+	if (nr == TEMP_READ && index < 4) {	/* Only TD1-TD4 have low bits */
 		int low = ((data->temp_low_bits >> (index * 2)) & 0x03) * 250;
 		temp += temp > 0 ? low : -low;
@@ -580,7 +617,12 @@ store_temp(struct device *dev, struct device_attribute *attr,
-	long tmp = simple_strtol(buf, NULL, 10);
+	long tmp;
+	int err;
+	err = kstrtol(buf, 10, &tmp);
+	if (err)
+		return err;
 	data->temp[index][nr] = TEMP_TO_REG(tmp, -128, 127);
@@ -591,18 +633,18 @@ store_temp(struct device *dev, struct device_attribute *attr,
-	TD1-TD4
-	each has 4 mode:(2 bits)
-	0:	Stop monitor
-	1:	Use internal temp sensor(default)
-	2:	Reserved
-	3:	Use sensor in Intel CPU and get result by PECI
-	TR1-TR2
-	each has 2 mode:(1 bit)
-	0:	Disable temp sensor monitor
-	1:	To enable temp sensors monitor
+ * TD1-TD4
+ * each has 4 mode:(2 bits)
+ * 0:	Stop monitor
+ * 1:	Use internal temp sensor(default)
+ * 2:	Reserved
+ * 3:	Use sensor in Intel CPU and get result by PECI
+ * TR1-TR2
+ * each has 2 mode:(1 bit)
+ * 0:	Disable temp sensor monitor
+ * 1:	To enable temp sensors monitor
 /* 0 disable, 6 PECI */
 static u8 TO_TEMP_MODE[] = { 0, 0, 0, 6 };
@@ -622,11 +664,10 @@ show_temp_mode(struct device *dev, struct device_attribute *attr, char *buf)
 	tmp = (data->temp_mode[index] >> shift) & mask;
 	/* for the internal sensor, found out if diode or thermistor */
-	if (tmp == 1) {
+	if (tmp == 1)
 		tmp = index == 0 ? 3 : 4;
-	} else {
+	else
 		tmp = TO_TEMP_MODE[tmp];
 	return sprintf(buf, "%d\n", tmp);
@@ -642,7 +683,12 @@ store_temp_mode(struct device *dev, struct device_attribute *attr,
 	u8 mask = (index < 4) ? 0x03 : 0x01;
 	u8 shift = (index < 4) ? (2 * index) : (index - 4);
+	int err;
+	if (err)
+		return err;
 	/* transform the sysfs interface values into table above */
 	if ((val == 6) && (index < 4)) {
@@ -681,15 +727,14 @@ show_sf_setup(struct device *dev, struct device_attribute *attr, char *buf)
 	u32 val = 0;
-	if (SETUP_PWM_DEFAULT == nr) {
+	if (nr == SETUP_PWM_DEFAULT)
 		val = (data->pwm_default & 0x3f) << 2;
-	} else if (SETUP_PWM_UPTIME == nr) {
+	else if (nr == SETUP_PWM_UPTIME)
 		val = TIME_FROM_REG(data->pwm_uptime);
-	} else if (SETUP_PWM_DOWNTIME == nr) {
+	else if (nr == SETUP_PWM_DOWNTIME)
 		val = TIME_FROM_REG(data->pwm_downtime);
-	} else if (SETUP_TEMP_CRITICAL == nr) {
+	else if (nr == SETUP_TEMP_CRITICAL)
 		val = TEMP_FROM_REG(data->temp_critical & 0x7f);
 	return sprintf(buf, "%d\n", val);
@@ -703,31 +748,34 @@ store_sf_setup(struct device *dev, struct device_attribute *attr,
+	long val;
+	int err;
+	err = kstrtol(buf, 10, &val);
+	if (err)
+		return err;
+	if (nr == SETUP_PWM_DEFAULT) {
 		data->pwm_default =
 		    w83793_read_value(client, W83793_REG_PWM_DEFAULT) & 0xc0;
-		data->pwm_default |= SENSORS_LIMIT(simple_strtoul(buf, NULL,
-								  10),
-						   0, 0xff) >> 2;
+		data->pwm_default |= SENSORS_LIMIT(val, 0, 0xff) >> 2;
 		w83793_write_value(client, W83793_REG_PWM_DEFAULT,
 							data->pwm_default);
-		data->pwm_uptime = TIME_TO_REG(simple_strtoul(buf, NULL, 10));
+	} else if (nr == SETUP_PWM_UPTIME) {
+		data->pwm_uptime = TIME_TO_REG(val);
 		data->pwm_uptime += data->pwm_uptime == 0 ? 1 : 0;
 		w83793_write_value(client, W83793_REG_PWM_UPTIME,
 							data->pwm_uptime);
-		data->pwm_downtime = TIME_TO_REG(simple_strtoul(buf, NULL, 10));
+	} else if (nr == SETUP_PWM_DOWNTIME) {
+		data->pwm_downtime = TIME_TO_REG(val);
 		data->pwm_downtime += data->pwm_downtime == 0 ? 1 : 0;
 		w83793_write_value(client, W83793_REG_PWM_DOWNTIME,
 	} else {		/* SETUP_TEMP_CRITICAL */
 		data->temp_critical =
 		    w83793_read_value(client, W83793_REG_TEMP_CRITICAL) & 0x80;
-		data->temp_critical |= TEMP_TO_REG(simple_strtol(buf, NULL, 10),
-						   0, 0x7f);
+		data->temp_critical |= TEMP_TO_REG(val, 0, 0x7f);
 		w83793_write_value(client, W83793_REG_TEMP_CRITICAL,
 							data->temp_critical);
@@ -737,31 +785,31 @@ store_sf_setup(struct device *dev, struct device_attribute *attr,
-	Temp SmartFan control
-	TEMP_FAN_MAP
-	Temp channel control which pwm fan, bitfield, bit 0 indicate pwm1...
-	It's possible two or more temp channels control the same fan, w83793
-	always prefers to pick the most critical request and applies it to
-	the related Fan.
-	It's possible one fan is not in any mapping of 6 temp channels, this
-	means the fan is manual mode
-	TEMP_PWM_ENABLE
-	Each temp channel has its own SmartFan mode, and temp channel
-	control	fans that are set by TEMP_FAN_MAP
-	0:	SmartFanII mode
-	1:	Thermal Cruise Mode
-	TEMP_CRUISE
-	Target temperature in thermal cruise mode, w83793 will try to turn
-	fan speed to keep the temperature of target device around this
-	temperature.
-	TEMP_TOLERANCE
-	If Temp higher or lower than target with this tolerance, w83793
-	will take actions to speed up or slow down the fan to keep the
-	temperature within the tolerance range.
+ * Temp SmartFan control
+ * TEMP_FAN_MAP
+ * Temp channel control which pwm fan, bitfield, bit 0 indicate pwm1...
+ * It's possible two or more temp channels control the same fan, w83793
+ * always prefers to pick the most critical request and applies it to
+ * the related Fan.
+ * It's possible one fan is not in any mapping of 6 temp channels, this
+ * means the fan is manual mode
+ * TEMP_PWM_ENABLE
+ * Each temp channel has its own SmartFan mode, and temp channel
+ * control fans that are set by TEMP_FAN_MAP
+ * 0:	SmartFanII mode
+ * 1:	Thermal Cruise Mode
+ * TEMP_CRUISE
+ * Target temperature in thermal cruise mode, w83793 will try to turn
+ * fan speed to keep the temperature of target device around this
+ * temperature.
+ * TEMP_TOLERANCE
+ * If Temp higher or lower than target with this tolerance, w83793
+ * will take actions to speed up or slow down the fan to keep the
+ * temperature within the tolerance range.
 #define TEMP_FAN_MAP			0
 #define TEMP_PWM_ENABLE			1
@@ -777,12 +825,12 @@ show_sf_ctrl(struct device *dev, struct device_attribute *attr, char *buf)
 	u32 val;
-	if (TEMP_FAN_MAP == nr) {
+	if (nr == TEMP_FAN_MAP) {
 		val = data->temp_fan_map[index];
-	} else if (TEMP_PWM_ENABLE == nr) {
+	} else if (nr == TEMP_PWM_ENABLE) {
 		/* +2 to transfrom into 2 and 3 to conform with sysfs intf */
 		val = ((data->pwm_enable >> index) & 0x01) + 2;
-	} else if (TEMP_CRUISE == nr) {
+	} else if (nr == TEMP_CRUISE) {
 		val = TEMP_FROM_REG(data->temp_cruise[index] & 0x7f);
 	} else {		/* TEMP_TOLERANCE */
 		val = data->tolerance[index >> 1] >> ((index & 0x01) ? 4 : 0);
@@ -801,16 +849,20 @@ store_sf_ctrl(struct device *dev, struct device_attribute *attr,
-	u32 val;
+	long val;
+	int err;
+	if (err)
+		return err;
-		val = simple_strtoul(buf, NULL, 10) & 0xff;
+		val = SENSORS_LIMIT(val, 0, 255);
 		w83793_write_value(client, W83793_REG_TEMP_FAN_MAP(index), val);
 		data->temp_fan_map[index] = val;
-		if (2 == val || 3 == val) {
+		if (val == 2 || val == 3) {
 			data->pwm_enable =
 			    w83793_read_value(client, W83793_REG_PWM_ENABLE);
 			if (val - 2)
@@ -823,12 +875,11 @@ store_sf_ctrl(struct device *dev, struct device_attribute *attr,
 			mutex_unlock(&data->update_lock);
 			return -EINVAL;
 		data->temp_cruise[index] =
 		    w83793_read_value(client, W83793_REG_TEMP_CRUISE(index));
-		val = TEMP_TO_REG(simple_strtol(buf, NULL, 10), 0, 0x7f);
 		data->temp_cruise[index] &= 0x80;
-		data->temp_cruise[index] |= val;
+		data->temp_cruise[index] |= TEMP_TO_REG(val, 0, 0x7f);
 		w83793_write_value(client, W83793_REG_TEMP_CRUISE(index),
 						data->temp_cruise[index]);
@@ -838,9 +889,8 @@ store_sf_ctrl(struct device *dev, struct device_attribute *attr,
 		data->tolerance[i] =
 		    w83793_read_value(client, W83793_REG_TEMP_TOL(i));
-		val = TEMP_TO_REG(simple_strtol(buf, NULL, 10), 0, 0x0f);
 		data->tolerance[i] &= ~(0x0f << shift);
-		data->tolerance[i] |= val << shift;
+		data->tolerance[i] |= TEMP_TO_REG(val, 0, 0x0f) << shift;
 		w83793_write_value(client, W83793_REG_TEMP_TOL(i),
 							data->tolerance[i]);
@@ -871,7 +921,13 @@ store_sf2_pwm(struct device *dev, struct device_attribute *attr,
-	u8 val = SENSORS_LIMIT(simple_strtoul(buf, NULL, 10), 0, 0xff) >> 2;
+	int err;
+	if (err)
+		return err;
 	data->sf2_pwm[index][nr] =
@@ -906,7 +962,13 @@ store_sf2_temp(struct device *dev, struct device_attribute *attr,
-	u8 val = TEMP_TO_REG(simple_strtol(buf, NULL, 10), 0, 0x7f);
+	long val;
+	int err;
+	if (err)
+		return err;
+	val = TEMP_TO_REG(val, 0, 0x7f);
 	data->sf2_temp[index][nr] =
@@ -948,17 +1010,19 @@ store_in(struct device *dev, struct device_attribute *attr,
-	u32 val;
+	int err;
+	if (err)
+		return err;
+	val = (val + scale_in[index] / 2) / scale_in[index];
-	val =
-	    (simple_strtoul(buf, NULL, 10) +
-	     scale_in[index] / 2) / scale_in[index];
 	if (index > 2) {
 		/* fix the limit values of 5VDD and 5VSB to ALARM mechanism */
-		if (1 == nr || 2 == nr) {
+		if (nr == 1 || nr == 2)
 			val -= scale_in_add[index] / scale_in[index];
 	} else {
 		val = SENSORS_LIMIT(val, 0, 0x3FF);
@@ -1143,9 +1207,8 @@ static struct sensor_device_attribute_2 sda_single_files[] = {
 static void w83793_init_client(struct i2c_client *client)
-	if (reset) {
+	if (reset)
 		w83793_write_value(client, W83793_REG_CONFIG, 0x80);
 	/* Start monitoring */
@@ -1259,10 +1322,12 @@ static int watchdog_open(struct inode *inode, struct file *filp)
 	struct w83793_data *pos, *data = NULL;
 	int watchdog_is_open;
-	/* We get called from drivers/char/misc.c with misc_mtx hold, and we
-	   call misc_register() from  w83793_probe() with watchdog_data_mutex
-	   hold, as misc_register() takes the misc_mtx lock, this is a possible
-	   deadlock, so we use mutex_trylock here. */
+	 * We get called from drivers/char/misc.c with misc_mtx hold, and we
+	 * call misc_register() from  w83793_probe() with watchdog_data_mutex
+	 * hold, as misc_register() takes the misc_mtx lock, this is a possible
+	 * deadlock, so we use mutex_trylock here.
 	if (!mutex_trylock(&watchdog_data_mutex))
 		return -ERESTARTSYS;
 	list_for_each_entry(pos, &watchdog_data_list, list) {
@@ -1275,8 +1340,10 @@ static int watchdog_open(struct inode *inode, struct file *filp)
 	/* Check, if device is already open */
 	watchdog_is_open = test_and_set_bit(0, &data->watchdog_is_open);
-	/* Increase data reference counter (if not already done).
-	   Note we can never not have found data, so we don't check for this */
+	 * Increase data reference counter (if not already done).
+	 * Note we can never not have found data, so we don't check for this
 	if (!watchdog_is_open)
 		kref_get(&data->kref);
@@ -1556,9 +1623,8 @@ w83793_detect_subclients(struct i2c_client *client)
 	tmp = w83793_read_value(client, W83793_REG_I2C_SUBADDR);
-	if (!(tmp & 0x08)) {
+	if (!(tmp & 0x08))
 		data->lm75[0] = i2c_new_dummy(adapter, 0x48 + (tmp & 0x7));
 	if (!(tmp & 0x80)) {
 		if ((data->lm75[0] != NULL)
 		    && ((tmp & 0x7) == ((tmp >> 4) & 0x7))) {
@@ -1591,9 +1657,8 @@ static int w83793_detect(struct i2c_client *client,
 	struct i2c_adapter *adapter = client->adapter;
 	unsigned short address = client->addr;
-	if (!i2c_check_functionality(adapter, I2C_FUNC_SMBUS_BYTE_DATA)) {
+	if (!i2c_check_functionality(adapter, I2C_FUNC_SMBUS_BYTE_DATA))
 		return -ENODEV;
 	bank = i2c_smbus_read_byte_data(client, W83793_REG_BANKSEL);
@@ -1604,8 +1669,10 @@ static int w83793_detect(struct i2c_client *client,
 		return -ENODEV;
-	/* If Winbond chip, address of chip and W83793_REG_I2C_ADDR
-	   should match */
+	 * If Winbond chip, address of chip and W83793_REG_I2C_ADDR
+	 * should match
 	if ((bank & 0x07) == 0
 	 && i2c_smbus_read_byte_data(client, W83793_REG_I2C_ADDR) !=
 	    (address << 1)) {
@@ -1647,9 +1714,11 @@ static int w83793_probe(struct i2c_client *client,
 	INIT_LIST_HEAD(&data->list);
 	kref_init(&data->kref);
-	/* Store client pointer in our data struct for watchdog usage
-	   (where the client is found through a data ptr instead of the
-	   otherway around) */
+	 * Store client pointer in our data struct for watchdog usage
+	 * (where the client is found through a data ptr instead of the
+	 * otherway around)
 	data->client = client;
 	err = w83793_detect_subclients(client);
@@ -1660,8 +1729,8 @@ static int w83793_probe(struct i2c_client *client,
 	w83793_init_client(client);
-	   Only fan 1-5 has their own input pins,
-	   Pwm 1-3 has their own pins
+	 * Only fan 1-5 has their own input pins,
+	 * Pwm 1-3 has their own pins
 	data->has_fan = 0x1f;
 	data->has_pwm = 0x07;
@@ -1723,7 +1792,7 @@ static int w83793_probe(struct i2c_client *client,
 	/* check the temp1-6 mode, ignore former AMDSI selected inputs */
-	tmp = w83793_read_value(client,W83793_REG_TEMP_MODE[0]);
+	tmp = w83793_read_value(client, W83793_REG_TEMP_MODE[0]);
 	if (tmp & 0x01)
 		data->has_temp |= 0x01;
 	if (tmp & 0x04)
@@ -1733,7 +1802,7 @@ static int w83793_probe(struct i2c_client *client,
 	if (tmp & 0x40)
 		data->has_temp |= 0x08;
-	tmp = w83793_read_value(client,W83793_REG_TEMP_MODE[1]);
+	tmp = w83793_read_value(client, W83793_REG_TEMP_MODE[1]);
 	if (tmp & 0x01)
 		data->has_temp |= 0x10;
 	if (tmp & 0x02)
@@ -1823,9 +1892,11 @@ static int w83793_probe(struct i2c_client *client,
 		goto exit_devunreg;
-	/* Enable Watchdog registers.
-	   Set Configuration Register to Enable Watch Dog Registers
-	   (Bit 2) = XXXX, X1XX. */
+	 * Enable Watchdog registers.
+	 * Set Configuration Register to Enable Watch Dog Registers
+	 * (Bit 2) = XXXX, X1XX.
 	tmp = w83793_read_value(client, W83793_REG_CONFIG);
 	w83793_write_value(client, W83793_REG_CONFIG, tmp | 0x04);
@@ -1839,9 +1910,11 @@ static int w83793_probe(struct i2c_client *client,
 	/* Disable Soft Watchdog during initialiation */
 	watchdog_disable(data);
-	/* We take the data_mutex lock early so that watchdog_open() cannot
-	   run when misc_register() has completed, but we've not yet added
-	   our data to the watchdog_data_list (and set the default timeout) */
+	 * We take the data_mutex lock early so that watchdog_open() cannot
+	 * run when misc_register() has completed, but we've not yet added
+	 * our data to the watchdog_data_list (and set the default timeout)
 	mutex_lock(&watchdog_data_mutex);
 	for (i = 0; i < ARRAY_SIZE(watchdog_minors); i++) {
 		/* Register our watchdog part */
@@ -1921,9 +1994,9 @@ static void w83793_update_nonvolatile(struct device *dev)
 	int i, j;
-	   They are somewhat "stable" registers, and to update them every time
-	   takes so much time, it's just not worthy. Update them in a long
-	   interval to avoid exception.
+	 * They are somewhat "stable" registers, and to update them every time
+	 * takes so much time, it's just not worthy. Update them in a long
+	 * interval to avoid exception.
 	if (!(time_after(jiffies, data->last_nonvolatile + HZ * 300)
 	      || !data->valid))
@@ -1940,9 +2013,8 @@ static void w83793_update_nonvolatile(struct device *dev)
 	for (i = 0; i < ARRAY_SIZE(data->fan_min); i++) {
 		/* Update the Fan measured value and limits */
-		if (!(data->has_fan & (1 << i))) {
+		if (!(data->has_fan & (1 << i)))
 			continue;
 		data->fan_min[i] =
 		    w83793_read_value(client, W83793_REG_FAN_MIN(i)) << 8;
 		data->fan_min[i] |=
@@ -1997,9 +2069,8 @@ static void w83793_update_nonvolatile(struct device *dev)
 	    w83793_read_value(client, W83793_REG_TEMP_CRITICAL);
 	data->beep_enable = w83793_read_value(client, W83793_REG_OVT_BEEP);
-	for (i = 0; i < ARRAY_SIZE(data->beeps); i++) {
+	for (i = 0; i < ARRAY_SIZE(data->beeps); i++)
 		data->beeps[i] = w83793_read_value(client, W83793_REG_BEEP(i));
 	data->last_nonvolatile = jiffies;
@@ -2025,9 +2096,8 @@ static struct w83793_data *w83793_update_device(struct device *dev)
 	    w83793_read_value(client, W83793_REG_IN_LOW_BITS[IN_READ]);
 	for (i = 0; i < ARRAY_SIZE(data->fan); i++) {
 			continue;
 		data->fan[i] =
 		    w83793_read_value(client, W83793_REG_FAN(i)) << 8;
 		data->fan[i] |=
@@ -2067,8 +2137,10 @@ END:
 	return data;
-/* Ignore the possibility that somebody change bank outside the driver
-   Must be called with data->update_lock held, except during initialization */
+ * Ignore the possibility that somebody change bank outside the driver
+ * Must be called with data->update_lock held, except during initialization
 static u8 w83793_read_value(struct i2c_client *client, u16 reg)
@@ -2103,16 +2175,16 @@ static int w83793_write_value(struct i2c_client *client, u16 reg, u8 value)
 	new_bank |= data->bank & 0xfc;
 	if (data->bank != new_bank) {
-		if ((res = i2c_smbus_write_byte_data
-		    (client, W83793_REG_BANKSEL, new_bank)) >= 0)
-			data->bank = new_bank;
-		else {
+		res = i2c_smbus_write_byte_data(client, W83793_REG_BANKSEL,
+						new_bank);
+		if (res < 0) {
 			dev_err(&client->dev,
 				"set bank to %d failed, fall back "
 				"to bank %d, write reg 0x%x error\n",
 				new_bank, data->bank, reg);
 			goto END;
+		data->bank = new_bank;
 	res = i2c_smbus_write_byte_data(client, reg & 0xff, value);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
