hwmon: (w83627ehf) Use swap() in w82627ehf_swap_tempreg()
Author: Fabian Frederick <fabf@skynet.be>
Use kernel.h macro definition.
Thanks to Julia Lawall for Coccinelle scripting support.
Signed-off-by: Fabian Frederick
Signed-off-by: Jean Delvare
drivers/hwmon/w83627ehf.c | 26 +++++---------------------
1 file changed, 5 insertions(+), 21 deletions(-)
diff --git a/drivers/hwmon/w83627ehf.c b/drivers/hwmon/w83627ehf.c
index b10353b..697007a 100644
--- a/drivers/hwmon/w83627ehf.c
+++ b/drivers/hwmon/w83627ehf.c
@@ -1937,27 +1937,11 @@ static inline void w83627ehf_init_device(struct w83627ehf_data *data,
static void w82627ehf_swap_tempreg(struct w83627ehf_data *data,
int r1, int r2)
- u16 tmp;
- tmp = data->temp_src[r1];
- data->temp_src[r1] = data->temp_src[r2];
- data->temp_src[r2] = tmp;
- tmp = data->reg_temp[r1];
- data->reg_temp[r1] = data->reg_temp[r2];
- data->reg_temp[r2] = tmp;
- tmp = data->reg_temp_over[r1];
- data->reg_temp_over[r1] = data->reg_temp_over[r2];
- data->reg_temp_over[r2] = tmp;
- tmp = data->reg_temp_hyst[r1];
- data->reg_temp_hyst[r1] = data->reg_temp_hyst[r2];
- data->reg_temp_hyst[r2] = tmp;
- tmp = data->reg_temp_config[r1];
- data->reg_temp_config[r1] = data->reg_temp_config[r2];
- data->reg_temp_config[r2] = tmp;
+ swap(data->temp_src[r1], data->temp_src[r2]);
+ swap(data->reg_temp[r1], data->reg_temp[r2]);
+ swap(data->reg_temp_over[r1], data->reg_temp_over[r2]);
+ swap(data->reg_temp_hyst[r1], data->reg_temp_hyst[r2]);
+ swap(data->reg_temp_config[r1], data->reg_temp_config[r2]);
static void |
int r1, int r2)
- u16 tmp;
static void
