hwmon: Remove redundant spi driver bus initialization
Author: Lars-Peter Clausen <lars@metafoo.de>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_register_driver(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
identifier _driver;
struct spi_driver _driver = {
.driver = {
- .bus = &spi_bus_type,
Signed-off-by: Lars-Peter Clausen
Cc: Jean Delvare
Cc: Guenter Roeck
Cc: lm-sensors@lm-sensors.org
Signed-off-by: Guenter Roeck
drivers/hwmon/ad7314.c | 1 -
drivers/hwmon/ads7871.c | 1 -
2 files changed, 2 deletions(-)
diff --git a/drivers/hwmon/ad7314.c b/drivers/hwmon/ad7314.c
index 318e38e..5d760f3 100644
--- a/drivers/hwmon/ad7314.c
+++ b/drivers/hwmon/ad7314.c
@@ -160,7 +160,6 @@ MODULE_DEVICE_TABLE(spi, ad7314_id);
static struct spi_driver ad7314_driver = {
.driver = {
.name = "ad7314",
.owner = THIS_MODULE,
.probe = ad7314_probe,
diff --git a/drivers/hwmon/ads7871.c b/drivers/hwmon/ads7871.c
index 5231934..04450f8 100644
--- a/drivers/hwmon/ads7871.c
+++ b/drivers/hwmon/ads7871.c
@@ -227,7 +227,6 @@ static int __devexit ads7871_remove(struct spi_device *spi)
static struct spi_driver ads7871_driver = {
.driver = {
.name = DEVICE_NAME,
.driver = {
.name = "ad7314",
.driver = {
