hwmon: (nct6775) fix coccinelle warnings
Author: Fengguang Wu <fengguang.wu@intel.com>
drivers/hwmon/nct6775.c:3866:1-3: WARNING: PTR_RET can be used
 Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: coccinelle/api/ptr_ret.cocci
CC: Guenter Roeck
Signed-off-by: Fengguang Wu
Signed-off-by: Guenter Roeck
 drivers/hwmon/nct6775.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/hwmon/nct6775.c b/drivers/hwmon/nct6775.c
index fdbd632..7a1b6a7 100644
--- a/drivers/hwmon/nct6775.c
+++ b/drivers/hwmon/nct6775.c
@@ -3862,10 +3862,7 @@ static int nct6775_probe(struct platform_device *pdev)
 	hwmon_dev = devm_hwmon_device_register_with_groups(dev, data->name,
 							   data, data->groups);
-	if (IS_ERR(hwmon_dev))
-		return PTR_ERR(hwmon_dev);
-	return 0;
+	return PTR_ERR_OR_ZERO(hwmon_dev);
 #ifdef CONFIG_PM
