hwmon: (ltc4261) fix coccinelle warnings
Author: Fengguang Wu <fengguang.wu@intel.com>
drivers/hwmon/ltc4261.c:243:1-3: WARNING: PTR_RET can be used
Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: coccinelle/api/ptr_ret.cocci
CC: Guenter Roeck
Signed-off-by: Fengguang Wu
Signed-off-by: Guenter Roeck
drivers/hwmon/ltc4261.c | 5 +----
1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/hwmon/ltc4261.c b/drivers/hwmon/ltc4261.c
index 6c50db9..0becd69 100644
--- a/drivers/hwmon/ltc4261.c
+++ b/drivers/hwmon/ltc4261.c
@@ -240,10 +240,7 @@ static int ltc4261_probe(struct i2c_client *client,
hwmon_dev = devm_hwmon_device_register_with_groups(dev, client->name,
data,
ltc4261_groups);
- if (IS_ERR(hwmon_dev))
- return PTR_ERR(hwmon_dev);
- return 0;
+ return PTR_ERR_OR_ZERO(hwmon_dev);
static const struct i2c_device_id ltc4261_id[] = { |
data,
ltc4261_groups);
- return 0;
