hwmon: (k8temp) Adjust confusing if indentation
Move the if(err) statement after the if into the if branch indicated by its
indentation. The preceding if(err) test implies that err cannot be nonzero
unless the if branch is taken.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces5@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p4)
cocci.print_secs("after",p5)
Signed-off-by: Julia Lawall
Signed-off-by: Jean Delvare
drivers/hwmon/k8temp.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/hwmon/k8temp.c b/drivers/hwmon/k8temp.c
index 8bdf80d..b9bb3e0 100644
--- a/drivers/hwmon/k8temp.c
+++ b/drivers/hwmon/k8temp.c
@@ -252,12 +252,13 @@ static int __devinit k8temp_probe(struct pci_dev *pdev,
&sensor_dev_attr_temp3_input.dev_attr);
if (err)
goto exit_remove;
- if (data->sensorsp & SEL_PLACE)
+ if (data->sensorsp & SEL_PLACE) {
err = device_create_file(&pdev->dev,
&sensor_dev_attr_temp4_input.
dev_attr);
if (err)
goto exit_remove;
err = device_create_file(&pdev->dev, &dev_attr_name); |
if (err)
goto exit_remove;
dev_attr);
if (err)
goto exit_remove;
