hv: Change variable type to bool
Author: Peter Senna Tschudin <peter.senna@gmail.com>
The variable execute_shutdown is only assigned the values true and
false. Change its type to bool.
The simplified semantic patch that find this problem is as
follows (http://coccinelle.lip6.fr/):
@exists@
type T;
identifier b;
- T
+ bool
b = ...;
... when any
b = \(true\|false\)
Signed-off-by: Peter Senna Tschudin
drivers/hv/hv_util.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/hv/hv_util.c b/drivers/hv/hv_util.c
index cb82233..9113850 100644
--- a/drivers/hv/hv_util.c
+++ b/drivers/hv/hv_util.c
@@ -82,7 +82,7 @@ static void shutdown_onchannelcallback(void *context)
struct vmbus_channel *channel = context;
u32 recvlen;
u64 requestid;
- u8 execute_shutdown = false;
+ bool execute_shutdown = false;
u8 *shut_txf_buf = util_shutdown.recv_buffer;
struct shutdown_msg_data *shutdown_msg; |
u32 recvlen;
u64 requestid;
