HSI: omap_ssi: fix handling ida_simple_get result
Author: Andrzej Hajda <a.hajda@samsung.com>
The function can return negative value.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: Sebastian Reichel
 drivers/hsi/controllers/omap_ssi.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/hsi/controllers/omap_ssi.c b/drivers/hsi/controllers/omap_ssi.c
index f6d3100..27b91f1 100644
--- a/drivers/hsi/controllers/omap_ssi.c
+++ b/drivers/hsi/controllers/omap_ssi.c
@@ -323,11 +323,10 @@ static int __init ssi_add_controller(struct hsi_controller *ssi,
 		return -ENOMEM;
-	ssi->id = ida_simple_get(&platform_omap_ssi_ida, 0, 0, GFP_KERNEL);
-	if (ssi->id < 0) {
-		err = ssi->id;
+	err = ida_simple_get(&platform_omap_ssi_ida, 0, 0, GFP_KERNEL);
+	if (err < 0)
 		goto out_err;
+	ssi->id = err;
 	ssi->owner = THIS_MODULE;
 	ssi->device.parent = &pd->dev;
BtrLinux
Privacy Overview
