HSI: nokia-modem: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Sebastian Reichel
drivers/hsi/clients/nokia-modem.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/hsi/clients/nokia-modem.c b/drivers/hsi/clients/nokia-modem.c
index eb4dc63..9be4867 100644
--- a/drivers/hsi/clients/nokia-modem.c
+++ b/drivers/hsi/clients/nokia-modem.c
@@ -200,6 +200,7 @@ static int nokia_modem_probe(struct device *dev)
modem->ssi_protocol = hsi_new_client(port, &ssip);
if (!modem->ssi_protocol) {
dev_err(dev, "Could not register ssi-protocol device\n");
+ err = -ENOMEM;
goto error2;
+ err = -ENOMEM;
goto error2;
