HSI: cmt_speech: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Sebastian Reichel
 drivers/hsi/clients/cmt_speech.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/hsi/clients/cmt_speech.c b/drivers/hsi/clients/cmt_speech.c
index e9560ef..4983529 100644
--- a/drivers/hsi/clients/cmt_speech.c
+++ b/drivers/hsi/clients/cmt_speech.c
@@ -1028,6 +1028,7 @@ static int cs_hsi_start(struct cs_hsi_iface **hi, struct hsi_client *cl,
 	hsi_if->master = ssip_slave_get_master(cl);
 	if (IS_ERR(hsi_if->master)) {
+		err = PTR_ERR(hsi_if->master);
 		dev_err(&cl->device, "Could not get HSI master client\n");
 		goto leave4;
BtrLinux
Privacy Overview
