hostap_cs: fix misspelling of current function in string
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace a misspelled function name by %s and then __func__.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Signed-off-by: John W. Linville
 drivers/net/wireless/hostap/hostap_cs.c | 15 +++++----------
 1 file changed, 5 insertions(+), 10 deletions(-)
diff --git a/drivers/net/wireless/hostap/hostap_cs.c b/drivers/net/wireless/hostap/hostap_cs.c
index b6ec519..50033aa 100644
--- a/drivers/net/wireless/hostap/hostap_cs.c
+++ b/drivers/net/wireless/hostap/hostap_cs.c
@@ -381,18 +381,15 @@ static void prism2_pccard_genesis_reset(local_info_t *local, int hcr)
 	res = pcmcia_read_config_byte(hw_priv->link, CISREG_COR, &old_cor);
 	if (res != 0) {
-		printk(KERN_DEBUG "prism2_pccard_genesis_sreset failed 1 "
-		       "(%d)\n", res);
+		printk(KERN_DEBUG "%s failed 1 (%d)\n", __func__, res);
 		return;
-	printk(KERN_DEBUG "prism2_pccard_genesis_sreset: original COR %02x\n",
-		old_cor);
+	printk(KERN_DEBUG "%s: original COR %02x\n", __func__, old_cor);
 	res = pcmcia_write_config_byte(hw_priv->link, CISREG_COR,
 				old_cor | COR_SOFT_RESET);
 	if (res != 0) {
-		printk(KERN_DEBUG "prism2_pccard_genesis_sreset failed 2 "
-		       "(%d)\n", res);
+		printk(KERN_DEBUG "%s failed 2 (%d)\n", __func__, res);
 		return;
@@ -401,8 +398,7 @@ static void prism2_pccard_genesis_reset(local_info_t *local, int hcr)
 	/* Setup Genesis mode */
 	res = pcmcia_write_config_byte(hw_priv->link, CISREG_CCSR, hcr);
 	if (res != 0) {
-		printk(KERN_DEBUG "prism2_pccard_genesis_sreset failed 3 "
-		       "(%d)\n", res);
+		printk(KERN_DEBUG "%s failed 3 (%d)\n", __func__, res);
 		return;
 	mdelay(10);
@@ -410,8 +406,7 @@ static void prism2_pccard_genesis_reset(local_info_t *local, int hcr)
 				old_cor & ~COR_SOFT_RESET);
 	if (res != 0) {
-		printk(KERN_DEBUG "prism2_pccard_genesis_sreset failed 4 "
-		       "(%d)\n", res);
+		printk(KERN_DEBUG "%s failed 4 (%d)\n", __func__, res);
 		return;
BtrLinux
Privacy Overview
