HID: roccat: Drop cast
Author: Himangi Saraogi <himangi774@gmail.com>
This patch removes the cast on data of type void* as it is not needed.
The following Coccinelle semantic patch was used for making the change:
@r@
expression x;
void* e;
type T;
identifier f;
  *((T *)e)
  ((T *)x)[...]
  ((T *)x)->f
- (T *)
  e
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Jiri Kosina
 drivers/hid/hid-roccat-lua.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/hid/hid-roccat-lua.c b/drivers/hid/hid-roccat-lua.c
index 6adc0fa..65e2e76 100644
--- a/drivers/hid/hid-roccat-lua.c
+++ b/drivers/hid/hid-roccat-lua.c
@@ -61,7 +61,7 @@ static ssize_t lua_sysfs_write(struct file *fp, struct kobject *kobj,
 		return -EINVAL;
 	mutex_lock(&lua->lua_lock);
-	retval = roccat_common2_send(usb_dev, command, (void *)buf, real_size);
+	retval = roccat_common2_send(usb_dev, command, buf, real_size);
 	mutex_unlock(&lua->lua_lock);
 	return retval ? retval : real_size;
BtrLinux
Privacy Overview
