HID: Move dereferences below a NULL test
If the NULL test is necessary, then the dereferences should be moved below
the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E,E1;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
... when != E=E1
when != i
if (E == NULL||...) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Signed-off-by: Jiri Kosina
drivers/hid/hid-core.c | 6 ++++--
1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/hid/hid-core.c b/drivers/hid/hid-core.c
index f2c21d5..5eb10c2 100644
--- a/drivers/hid/hid-core.c
+++ b/drivers/hid/hid-core.c
@@ -1075,14 +1075,16 @@ EXPORT_SYMBOL_GPL(hid_report_raw_event);
int hid_input_report(struct hid_device *hid, int type, u8 *data, int size, int interrupt)
- struct hid_report_enum *report_enum = hid->report_enum + type;
- struct hid_driver *hdrv = hid->driver;
+ struct hid_report_enum *report_enum;
+ struct hid_driver *hdrv;
struct hid_report *report;
unsigned int i;
int ret;
if (!hid || !hid->driver)
return -ENODEV;
+ report_enum = hid->report_enum + type;
+ hdrv = hid->driver;
if (!size) {
dbg_hid("empty report\n"); |
unsigned int i;
int ret;
return -ENODEV;
if (!size) {
