HID: fix memory leak on error patch in debug code
Error handling code following a kzalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Cc: Jiri Kosina
Signed-off-by: Andrew Morton
Signed-off-by: Jiri Kosina
 drivers/hid/hid-debug.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/hid/hid-debug.c b/drivers/hid/hid-debug.c
index a331a18..06e87dc 100644
--- a/drivers/hid/hid-debug.c
+++ b/drivers/hid/hid-debug.c
@@ -909,6 +909,7 @@ static int hid_debug_events_open(struct inode *inode, struct file *file)
 	if (!(list->hid_debug_buf = kzalloc(sizeof(char) * HID_DEBUG_BUFSIZE, GFP_KERNEL))) {
 		err = -ENOMEM;
+		kfree(list);
 		goto out;
 	list->hdev = (struct hid_device *) inode->i_private;
BtrLinux
Privacy Overview
