gpu: host1x: Use a signed return type for do_relocs()
Author: Markus Elfring <elfring@users.sourceforge.net>
The return type "unsigned int" was used by the do_relocs() function
despite the fact that it will eventually return a negative error code.
Use a signed integer instead to accomodate for error codes.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Thierry Reding
 drivers/gpu/host1x/job.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpu/host1x/job.c b/drivers/gpu/host1x/job.c
index 63bd63f..1919aab 100644
--- a/drivers/gpu/host1x/job.c
+++ b/drivers/gpu/host1x/job.c
@@ -225,7 +225,7 @@ unpin:
 	return 0;
-static unsigned int do_relocs(struct host1x_job *job, struct host1x_bo *cmdbuf)
+static int do_relocs(struct host1x_job *job, struct host1x_bo *cmdbuf)
 	int i = 0;
 	u32 last_page = ~0;
BtrLinux
Privacy Overview
