GPU-DRM-Radeon: Delete an unnecessary check before drm_gem_object_unreference_unlocked()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_gem_object_unreference_unlocked() function tests whether
its argument is NULL and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Alex Deucher
 drivers/gpu/drm/radeon/radeon_display.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/gpu/drm/radeon/radeon_display.c b/drivers/gpu/drm/radeon/radeon_display.c
index 5f1cd69..1efab5f 100644
--- a/drivers/gpu/drm/radeon/radeon_display.c
+++ b/drivers/gpu/drm/radeon/radeon_display.c
@@ -1324,9 +1324,7 @@ static void radeon_user_framebuffer_destroy(struct drm_framebuffer *fb)
 	struct radeon_framebuffer *radeon_fb = to_radeon_framebuffer(fb);
-	if (radeon_fb->obj) {
-		drm_gem_object_unreference_unlocked(radeon_fb->obj);
+	drm_gem_object_unreference_unlocked(radeon_fb->obj);
 	drm_framebuffer_cleanup(fb);
 	kfree(radeon_fb);
BtrLinux
Privacy Overview
