GPU-DRM-OMAP: Delete unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The following functions test whether their argument is NULL and then
return immediately.
* backlight_device_unregister
* drm_gem_object_unreference_unlocked
Thus the test around the calls is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Daniel Vetter
Link: http://patchwork.freedesktop.org/patch/msgid/72ff4670-4f3d-c7ed-4f37-e49f2bbc7aba@users.sourceforge.net
 drivers/gpu/drm/omapdrm/displays/panel-dsi-cm.c | 3 +--
 drivers/gpu/drm/omapdrm/omap_fb.c               | 4 ++--
 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/gpu/drm/omapdrm/displays/panel-dsi-cm.c b/drivers/gpu/drm/omapdrm/displays/panel-dsi-cm.c
index 1b0cf2d..0eae8af 100644
--- a/drivers/gpu/drm/omapdrm/displays/panel-dsi-cm.c
+++ b/drivers/gpu/drm/omapdrm/displays/panel-dsi-cm.c
@@ -1284,8 +1284,7 @@ static int dsicm_probe(struct platform_device *pdev)
 	return 0;
 err_sysfs_create:
-	if (bldev != NULL)
-		backlight_device_unregister(bldev);
+	backlight_device_unregister(bldev);
 err_bl:
 	destroy_workqueue(ddata->workqueue);
 err_reg:
diff --git a/drivers/gpu/drm/omapdrm/omap_fb.c b/drivers/gpu/drm/omapdrm/omap_fb.c
index 983c8cf..31f5178 100644
--- a/drivers/gpu/drm/omapdrm/omap_fb.c
+++ b/drivers/gpu/drm/omapdrm/omap_fb.c
@@ -115,8 +115,8 @@ static void omap_framebuffer_destroy(struct drm_framebuffer *fb)
 	for (i = 0; i < n; i++) {
 		struct plane *plane = &omap_fb->planes[i];
-		if (plane->bo)
-			drm_gem_object_unreference_unlocked(plane->bo);
+		drm_gem_object_unreference_unlocked(plane->bo);
 	kfree(omap_fb);
BtrLinux
Privacy Overview
