GPU-DRM-Exynos: Delete an unnecessary check before the function call “vunmap”
Author: Markus Elfring <elfring@users.sourceforge.net>
The vunmap() function performs also input parameter validation.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Sean Paul
Link: http://patchwork.freedesktop.org/patch/msgid/a5a79711-10a3-e304-a897-892ebdf2ff9f@users.sourceforge.net
 drivers/gpu/drm/exynos/exynos_drm_fbdev.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/gpu/drm/exynos/exynos_drm_fbdev.c b/drivers/gpu/drm/exynos/exynos_drm_fbdev.c
index 67dcd68..fb49443 100644
--- a/drivers/gpu/drm/exynos/exynos_drm_fbdev.c
+++ b/drivers/gpu/drm/exynos/exynos_drm_fbdev.c
@@ -269,8 +269,7 @@ static void exynos_drm_fbdev_destroy(struct drm_device *dev,
 	struct exynos_drm_gem *exynos_gem = exynos_fbd->exynos_gem;
 	struct drm_framebuffer *fb;
-	if (exynos_gem->kvaddr)
-		vunmap(exynos_gem->kvaddr);
+	vunmap(exynos_gem->kvaddr);
 	/* release drm framebuffer and real buffer */
 	if (fb_helper->fb && fb_helper->fb->funcs) {
BtrLinux
Privacy Overview
