GPU-DRM: Delete unnecessary checks before drm_property_unreference_blob()
Author: Markus Elfring <elfring@users.sourceforge.net>
The drm_property_unreference_blob() function tests whether its argument
is NULL and then returns immediately.
Thus the tests around the calls are not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Link: http://patchwork.freedesktop.org/patch/msgid/563C8B3E.405@users.sourceforge.net
Signed-off-by: Daniel Vetter
 drivers/gpu/drm/drm_atomic.c        | 9 +++------
 drivers/gpu/drm/drm_atomic_helper.c | 5 ++---
 2 files changed, 5 insertions(+), 9 deletions(-)
diff --git a/drivers/gpu/drm/drm_atomic.c b/drivers/gpu/drm/drm_atomic.c
index aeee083..91825e6 100644
--- a/drivers/gpu/drm/drm_atomic.c
+++ b/drivers/gpu/drm/drm_atomic.c
@@ -316,8 +316,7 @@ int drm_atomic_set_mode_for_crtc(struct drm_crtc_state *state,
 	if (mode && memcmp(&state->mode, mode, sizeof(*mode)) == 0)
 		return 0;
-	if (state->mode_blob)
-		drm_property_unreference_blob(state->mode_blob);
+	drm_property_unreference_blob(state->mode_blob);
 	state->mode_blob = NULL;
 	if (mode) {
@@ -363,8 +362,7 @@ int drm_atomic_set_mode_prop_for_crtc(struct drm_crtc_state *state,
 	if (blob == state->mode_blob)
 		return 0;
 	if (blob) {
@@ -419,8 +417,7 @@ int drm_atomic_crtc_set_property(struct drm_crtc *crtc,
 		struct drm_property_blob *mode =
 			drm_property_lookup_blob(dev, val);
 		ret = drm_atomic_set_mode_prop_for_crtc(state, mode);
-		if (mode)
-			drm_property_unreference_blob(mode);
+		drm_property_unreference_blob(mode);
 		return ret;
 	else if (crtc->funcs->atomic_set_property)
diff --git a/drivers/gpu/drm/drm_atomic_helper.c b/drivers/gpu/drm/drm_atomic_helper.c
index e5aec45..dc27c81 100644
--- a/drivers/gpu/drm/drm_atomic_helper.c
+++ b/drivers/gpu/drm/drm_atomic_helper.c
@@ -2184,7 +2184,7 @@ EXPORT_SYMBOL(drm_atomic_helper_connector_dpms);
 void drm_atomic_helper_crtc_reset(struct drm_crtc *crtc)
-	if (crtc->state && crtc->state->mode_blob)
+	if (crtc->state)
 		drm_property_unreference_blob(crtc->state->mode_blob);
 	kfree(crtc->state);
 	crtc->state = kzalloc(sizeof(*crtc->state), GFP_KERNEL);
@@ -2252,8 +2252,7 @@ EXPORT_SYMBOL(drm_atomic_helper_crtc_duplicate_state);
 void __drm_atomic_helper_crtc_destroy_state(struct drm_crtc *crtc,
 					    struct drm_crtc_state *state)
 EXPORT_SYMBOL(__drm_atomic_helper_crtc_destroy_state);
BtrLinux
Privacy Overview
