gpio/sa1100: Prepare sa1100_gpio_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: Linus Walleij
Cc: Alexandre Courbot
Cc: linux-gpio@vger.kernel.org
drivers/gpio/gpio-sa1100.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/gpio/gpio-sa1100.c b/drivers/gpio/gpio-sa1100.c
index 3fa22da..e847a4c 100644
--- a/drivers/gpio/gpio-sa1100.c
+++ b/drivers/gpio/gpio-sa1100.c
@@ -173,9 +173,9 @@ static struct irq_domain *sa1100_gpio_irqdomain;
* and call the handler.
static void
-sa1100_gpio_handler(unsigned int irq, struct irq_desc *desc)
+sa1100_gpio_handler(unsigned int __irq, struct irq_desc *desc)
- unsigned int mask;
+ unsigned int irq, mask;
mask = GEDR;
do { |
static void
mask = GEDR;
do {
