gpio/ep93xx: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle:
struct irq_data *d;
expression E1;
-__irq_set_handler_locked(d->irq, E1);
+irq_set_handler_locked(d, E1);
Signed-off-by: Thomas Gleixner
Cc: Jiang Liu
Cc: Julia Lawall
Cc: Linus Walleij
Cc: Alexandre Courbot
Cc: linux-gpio@vger.kernel.org
 drivers/gpio/gpio-ep93xx.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/gpio-ep93xx.c b/drivers/gpio/gpio-ep93xx.c
index 45684f3..8664cf0 100644
--- a/drivers/gpio/gpio-ep93xx.c
+++ b/drivers/gpio/gpio-ep93xx.c
@@ -208,7 +208,7 @@ static int ep93xx_gpio_irq_type(struct irq_data *d, unsigned int type)
 		return -EINVAL;
-	__irq_set_handler_locked(d->irq, handler);
+	irq_set_handler_locked(d, handler);
 	gpio_int_enabled[port] |= port_mask;
BtrLinux
Privacy Overview
