gpio/ep93xx: Prepare ep93xx_gpio_f_irq_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: Linus Walleij
Cc: Alexandre Courbot
Cc: linux-gpio@vger.kernel.org
 drivers/gpio/gpio-ep93xx.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/gpio-ep93xx.c b/drivers/gpio/gpio-ep93xx.c
index 8664cf0..dc0c409 100644
--- a/drivers/gpio/gpio-ep93xx.c
+++ b/drivers/gpio/gpio-ep93xx.c
@@ -100,13 +100,15 @@ static void ep93xx_gpio_ab_irq_handler(unsigned int irq, struct irq_desc *desc)
-static void ep93xx_gpio_f_irq_handler(unsigned int irq, struct irq_desc *desc)
+static void ep93xx_gpio_f_irq_handler(unsigned int __irq,
+				      struct irq_desc *desc)
 	 * map discontiguous hw irq range to continuous sw irq range:
 	 *  IRQ_EP93XX_GPIO{0..7}MUX -> gpio_to_irq(EP93XX_GPIO_LINE_F({0..7})
+	unsigned int irq = irq_desc_get_irq(desc);
 	int port_f_idx = ((irq + 1) & 7) ^ 4; /* {19..22,47..50} -> {0..7} */
 	int gpio_irq = gpio_to_irq(EP93XX_GPIO_LINE_F(0)) + port_f_idx;
BtrLinux
Privacy Overview
