gpio-tz1090: Replace commas with semi-colons
Author: James Hogan <james.hogan@imgtec.com>
Replace commas with semicolons between irqchip callback initialisation
statements in tz1090_gpio_bank_probe. The commas appear to be a subtle
remnant of when the irqchips were statically initialised.
Thanks to Thomas Gleixner for spotting it while whipping up a coccinelle
script.
Reported-by: Thomas Gleixner
Signed-off-by: James Hogan
Cc: Alexandre Courbot
Cc: linux-gpio@vger.kernel.org
Cc: linux-metag@vger.kernel.org
Signed-off-by: Linus Walleij
 drivers/gpio/gpio-tz1090.c | 28 ++++++++++++++--------------
 1 file changed, 14 insertions(+), 14 deletions(-)
diff --git a/drivers/gpio/gpio-tz1090.c b/drivers/gpio/gpio-tz1090.c
index 23e0613..5246a60 100644
--- a/drivers/gpio/gpio-tz1090.c
+++ b/drivers/gpio/gpio-tz1090.c
@@ -488,26 +488,26 @@ static int tz1090_gpio_bank_probe(struct tz1090_gpio_bank_info *info)
 	gc->chip_types[0].handler		= handle_level_irq;
 	gc->chip_types[0].regs.ack		= REG_GPIO_IRQ_STS;
 	gc->chip_types[0].regs.mask		= REG_GPIO_IRQ_EN;
-	gc->chip_types[0].chip.irq_startup	= gpio_startup_irq,
-	gc->chip_types[0].chip.irq_ack		= irq_gc_ack_clr_bit,
-	gc->chip_types[0].chip.irq_mask		= irq_gc_mask_clr_bit,
-	gc->chip_types[0].chip.irq_unmask	= irq_gc_mask_set_bit,
-	gc->chip_types[0].chip.irq_set_type	= gpio_set_irq_type,
-	gc->chip_types[0].chip.irq_set_wake	= gpio_set_irq_wake,
-	gc->chip_types[0].chip.flags		= IRQCHIP_MASK_ON_SUSPEND,
+	gc->chip_types[0].chip.irq_startup	= gpio_startup_irq;
+	gc->chip_types[0].chip.irq_ack		= irq_gc_ack_clr_bit;
+	gc->chip_types[0].chip.irq_mask		= irq_gc_mask_clr_bit;
+	gc->chip_types[0].chip.irq_unmask	= irq_gc_mask_set_bit;
+	gc->chip_types[0].chip.irq_set_type	= gpio_set_irq_type;
+	gc->chip_types[0].chip.irq_set_wake	= gpio_set_irq_wake;
+	gc->chip_types[0].chip.flags		= IRQCHIP_MASK_ON_SUSPEND;
 	/* edge chip type */
 	gc->chip_types[1].type			= IRQ_TYPE_EDGE_BOTH;
 	gc->chip_types[1].handler		= handle_edge_irq;
 	gc->chip_types[1].regs.ack		= REG_GPIO_IRQ_STS;
 	gc->chip_types[1].regs.mask		= REG_GPIO_IRQ_EN;
-	gc->chip_types[1].chip.irq_startup	= gpio_startup_irq,
-	gc->chip_types[1].chip.irq_ack		= irq_gc_ack_clr_bit,
-	gc->chip_types[1].chip.irq_mask		= irq_gc_mask_clr_bit,
-	gc->chip_types[1].chip.irq_unmask	= irq_gc_mask_set_bit,
-	gc->chip_types[1].chip.irq_set_type	= gpio_set_irq_type,
-	gc->chip_types[1].chip.irq_set_wake	= gpio_set_irq_wake,
-	gc->chip_types[1].chip.flags		= IRQCHIP_MASK_ON_SUSPEND,
+	gc->chip_types[1].chip.irq_startup	= gpio_startup_irq;
+	gc->chip_types[1].chip.irq_ack		= irq_gc_ack_clr_bit;
+	gc->chip_types[1].chip.irq_mask		= irq_gc_mask_clr_bit;
+	gc->chip_types[1].chip.irq_unmask	= irq_gc_mask_set_bit;
+	gc->chip_types[1].chip.irq_set_type	= gpio_set_irq_type;
+	gc->chip_types[1].chip.irq_set_wake	= gpio_set_irq_wake;
+	gc->chip_types[1].chip.flags		= IRQCHIP_MASK_ON_SUSPEND;
 	/* Setup chained handler for this GPIO bank */
 	irq_set_handler_data(bank->irq, bank);
BtrLinux
Privacy Overview
