Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace calls to devm_request_mem_region and devm_ioremap with a
direct call to devm_ioremap_resource instead and modify error
handling.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more
clear.
A simplified version of the Coccinelle semantic patch that is used to
make this change is as follows:
@nm@
expression myname;
identifier i;
struct platform_driver i = { .driver = { .name = myname } };
expression dev,res,size,e1,e;
expression nm.myname;
-if (!devm_request_mem_region(dev, res->start, size,
- \(res->name\|dev_name(dev)\|myname\)))
- return ...;
... when != res->start = e1
e =
-devm_ioremap(dev,res->start,size);
+devm_ioremap_resource(dev,res);
if
-(e == NULL)
+(IS_ERR(e))
-return ...;
+return PTR_ERR(e);
Further, updated error handling by hand as devm_ioremap_resource
gives appropriate error messages, so remove unnecessary error
messages.
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: Linus Walleij
drivers/gpio/gpio-timberdale.c | 21 ++++-----------------
1 file changed, 4 insertions(+), 17 deletions(-)
diff --git a/drivers/gpio/gpio-timberdale.c b/drivers/gpio/gpio-timberdale.c
index f0164ec..85ed608 100644
--- a/drivers/gpio/gpio-timberdale.c
+++ b/drivers/gpio/gpio-timberdale.c
@@ -237,12 +237,6 @@ static int timbgpio_probe(struct platform_device *pdev)
return -EINVAL;
- iomem = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- if (!iomem) {
- dev_err(dev, "Unable to get resource\n");
- return -EINVAL;
tgpio = devm_kzalloc(dev, sizeof(struct timbgpio), GFP_KERNEL);
if (!tgpio) {
dev_err(dev, "Memory alloc failed\n");
@@ -252,17 +246,10 @@ static int timbgpio_probe(struct platform_device *pdev)
spin_lock_init(&tgpio->lock);
- if (!devm_request_mem_region(dev, iomem->start, resource_size(iomem),
- DRIVER_NAME)) {
- dev_err(dev, "Region already claimed\n");
- return -EBUSY;
- tgpio->membase = devm_ioremap(dev, iomem->start, resource_size(iomem));
- if (!tgpio->membase) {
- dev_err(dev, "Cannot ioremap\n");
- return -ENOMEM;
+ iomem = platform_get_resource(pdev, IORESOURCE_MEM, 0);
+ tgpio->membase = devm_ioremap_resource(dev, iomem);
+ if (IS_ERR(tgpio->membase))
+ return PTR_ERR(tgpio->membase);
gc = &tgpio->gpio; |
return -EINVAL;
- if (!iomem) {
- return -EINVAL;
if (!tgpio) {
- DRIVER_NAME)) {
- return -EBUSY;
- return -ENOMEM;
gc = &tgpio->gpio;
