gpio: pxa: using for_each_set_bit to simplify the code
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using for_each_set_bit() to simplify the code.
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Acked-by: Haojian Zhuang
Acked-by: Eric Miao
Signed-off-by: Linus Walleij
 drivers/gpio/gpio-pxa.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/gpio/gpio-pxa.c b/drivers/gpio/gpio-pxa.c
index 528de0f..bf9371f 100644
--- a/drivers/gpio/gpio-pxa.c
+++ b/drivers/gpio/gpio-pxa.c
@@ -413,12 +413,10 @@ static void pxa_gpio_demux_handler(unsigned int irq, struct irq_desc *desc)
 			gedr = gedr & c->irq_mask;
 			writel_relaxed(gedr, c->regbase + GEDR_OFFSET);
-			n = find_first_bit(&gedr, BITS_PER_LONG);
-			while (n < BITS_PER_LONG) {
+			for_each_set_bit(n, &gedr, BITS_PER_LONG) {
 				loop = 1;
 				generic_handle_irq(gpio_to_irq(gpio_base + n));
-				n = find_next_bit(&gedr, BITS_PER_LONG, n + 1);
 	} while (loop);
BtrLinux
Privacy Overview
